Question about Zanussi IZ12 Front Load Washer
Drum filling with water when machine switched off
Hi, My machine seems to be filling with water even when it is switched off. For example, I finish a wash and remove the clothes. The clothes are relatively dry and the drum is completely empty of water. Then a few days later I notice that water is lodged in the bottom of the drum. If I open the overflow cap on the bottom of the machine the water comes out and eventually it is all drained off. I can only assume that the overflow container is filling with water and when it is too full the water goes into the drum. What I don't understand is where is the water coming from if the machine is switched off? Any solutions welcom Tim
  • Kenny Norful Jan 07, 2008
    I replaced the both water supply hoses because one was leaking behind the connection. After one washing cycle water continued to slowly leak into the drum while the machine was off. One note I replaced the water supply hoses with ones that are suppose to sut-off the water supply if a leak is detected.
  • Anonymous May 05, 2008
    My Whirlpool Duet front-loading washer also fills with water when it is not in use. Over a 3-day time period the drum gets to over halfway full. I have to start the washer to drain the water before opening the door . . . learned that the hard way when I was surprised by the water pouring out. Why is this happening. We've had the washer about 3 years and this just started 2 weeks ago. I've been turning the water off manually after completing a load to prevent it from happening.
    President:
  • 1,462 Answers
What you refer to as the overflow cap is the cover to the filter which you should remove regularly and check. however nothing to do with your problem. the water could be coming from two sources: first, if the drain is plumbed in under the sink, water can flow into the machine every time you empty the sink. the cure is to put the drain hose up as far as possible in a swan neck. secondly, the intake water valves could be leaking and the only cure then is to replace them
Posted on May 04, 2007
Water keeps filling even when not in use
hi Jeremy.
Why does my washing machine keep filling up with water when not in use? Ensure that the waste pipe of the washing machine is higher at one point than the drum of the machine, this will prevent water running back into the machine. Normally this would fill the machine with dirty water. Or it could be a faulty water inlet valve, which will fill the machine with clean water.22 Sep 2007
why is my washing machine filling up with water when off ...
forums.moneysavingexpert.com/showthread.php?t=558300 Search for: Why does my washing machine keep filling up with water when not in use?
if you want to read up more then go to this link.
Washing Machines keeps filling even when not in use Google Search
Nov 18, 2017 | Washing Machines
Washing machine will not stop filling up with water
Is the machine siphoning off water as it fills? If it is check the height of the drain hose and make sure it is above the height of the normal level of water that would be in te drum when washing, if the hose is to low the drum will siphon off the water on its own and continue to fill. If the machine is not siphoning off water while filling then you may have a blocked pressure hose or the pressure hose bottle may be blocked not allowing the pressure switch to activate. there may even be a small hole in the pressure switch hose. Check the thin pressure hose that goes from the bottom of the drum to the pressure switch.
Dec 27, 2012 | Indesit W 123 Front Load Washer
Bosch wfd2460 washing machine..fault water pouring out of machine drum even though mchine is switched off and door was open, please help
This is symptomatic of a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill! It's not closing correctly and closed is its 'default' and no power position.
Sorry but it needs replacing and a service call ;-0(
Good luck,
John C
Mar 21, 2011 | Bosch Washing Machines
Normally the machine used to start after taking required amount of water. Now the machine starts only after the whole drum is completely filled with water making it difficult to turn. Even later when it...
Washing machines stop filling when water pressure from the bottom of the tub goes up a plastic tube and into the water level switch. If the tube is obstructed with debris or anything foreign, the switch will fail to stop the water from overfilling. It is possible that the switch is defective, of course. Check the tube for obstructions, kinks, or a loose connection.
If it is the switch, have your make and model handy and look up the part here:
http://www.repairclinic.com
Good luck.
Mar 03, 2011 | Washing Machines
Washer leaking water
Hi there.i have a feeling that maybe the thin tube that runs from the water level pressure switch has come off the righthand side of the bowl & water is coming out of it.if thats the case the machine would never stop filling even at lowest setting.can you let me know what you find.
Jun 03, 2010 | Whirlpool LSR5132PQ Top Load Washer
Hotpoint WT761 washing machine - Error code F-10 The machine is filling with water, then signalling F-10, then pumping the water out. So the fill solenoid and the pump are working OK. If I set the machine...
Thats strange, F10 means no cold fill.
Ok back to basics, you can check the pressure switch by taking off the tube and gently blowing into it and I mean gently, you should hear a click if its ok - make sure the other end is'nt blocked, blow it out with a cycle pump near the drum end
Sep 19, 2009 | Washing Machines
Doesnot stop filling water
To javed_iqb904, does the drum actually fill or does it seem like that water is draining out as it's filling?
To neonllama19, if it fills with the tap on and the machine off, it sounds like a defective water valve. If it never stopped filling it sounds like a defective pressure switch or hose to the pressure switch is loose or diconnected.
Jan 08, 2009 | Frigidaire GLTF1670A Front Load Washer
Hotpoint WF321 during rinse and spin, will not go into full spin as machine keeps filling with water.
you should check your pressure switch hose for a pin hole or better still just replace the hose and it should sort your problem out good luck hamstel
Nov 05, 2008 | Washing Machines
Washing Machine Hoover H100M fills too much water in the drum.
this is 1 of 2 solutions  2 this problem the first thing to check is the vacuum system or it is a split in the pressure switch hose
Mar 05, 2008 | Hoover AAA140 Front Load Washer
Water level
The level of water in the drum is controlled by a pressure switch. This switch is attatched to the drum via an air tube which pushes air into the pressure switch as the machine fills with water. There could be a blockage in the pressure chamber attatched to the drum or the pressure switch is faulty.
Oct 31, 2007 | GE Energy Star WCVH6260F Front Load Washer
Zanussi IZ12 Front Load Washer Logo
764 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
