Question about HP OfficeJet G55 All-In-One InkJet Printer
How to set the printer to print banners on continuous paper?
I have some of the old computer paper that is continuous to print banners on. I don't see how to setup the printer to accept banner paper. Help?
Depending on your printer, you may have to use a 3rd party software that tells your printer to print continuously. If your printer does not support printing full banners without a break in pages you might have to check into getting a printer specially designed for this. Many consumer printers are not meant for custom print jobs, they just use standard paper sizes. If you have your manual, I would refer to that first, but if nothing is mentioned in the manual chances are good that your printer does not support continuous printing.
Posted on Dec 31, 2008
I need to pull an 11" x 48" sheet through my printer
That will never work as the printer looks for pages that are standard sizes. If it comes across something that is larger, the printer reports a paper jam. Making banners is best done on dot matrix printers using listing paper. Otherwise on a home printer, you use the banner setting in your creation software, MS Word, MS Publisher, and you print as separate pages and stick them together or stick them on a backing sheet.
Oct 22, 2015 | Epson WorkForce WF-2540 All-in-One Inkjet...
There are 6 print settings which do I use for best quality printing on HP Opaque Scrim paper banner style
That would be my choice and what will it do if it doesn't suit you . just waste some paper and ink
Jun 18, 2015 | HP designjet z3100ps gp large format photo...
Epson WF - 7520
My EPSON 7520 printer can't print the 1m banner I buy for that purpose, it's new, I design the banner & set up to print, before print when I check for preview it's divided for 4 portion. how can I fixe it? the last size the printer it takes 27cm * 42cm long, but I need to print 27cm * 100cm what can I do? I need help.
Jul 07, 2013 | Office Equipment & Supplies
My Lexmark 4600 printer has a paper jam. do not know how to unjam it.
How to clear and avoid paper jams
Follow these instructions to remove and/or avoid paper jams and misfeeds in your Lexmark X3500, X4500, X4600 & X4800 Series All-In-One.
Paper jam in the printer
Remove the paper manually
  1. Press pattlnk_10282008_1820-power-icon.gif to turn off the printer.
  2. Firmly grasp the paper, and gently pull it out.
  3. Press pattlnk_10282008_1820-power-icon.gif to turn the printer back on.
NOTE: Check inside the printer to ensure that all the paper is removed. Any small pieces of paper left in the printer will continue to cause paper jams.
Paper jam in the paper support
Paper or specialty media misfeeds
These are possible solutions if paper or specialty media misfeeds or skews, or if multiple sheets feed or stick together.
Try one or more of the following:
Check paper condition
  • Use only new, unwrinkled paper.
Check paper loading
  • Load a smaller amount of paper into the printer.
  • Load paper with the print side facing you. (If you are not sure which side is the printable side, see the instructions that came with the paper.)
Remove each page as it is printed
  • Remove each page as it exits, and let it dry completely before stacking.
Adjust the paper guides
  • When using media less than 8.5 inches wide
  • To rest against the edges of the paper or media, making sure it does not buckle
Printer does not feed paper, envelopes, or specialty media
These are possible solutions. Try one or more of the following:
Check for paper jams
  • Check for and clear any paper jams. For more information, see "Paper jam in the printer" and "Paper jam in the paper support" above.
Check media loading
  • Verify that the specialty media is loaded correctly.
  • Try loading one page, envelope, or sheet of specialty media at a time.
Check printer default and pause settings
  1. Click:
    • In Windows XP (default Start menu): Start pattlnk_10282008_1829-right-arrow.gif Printers and Faxes.
    • In Windows XP (Classic Start menu): Start pattlnk_10282008_1829-right-arrow.gif Settings pattlnk_10282008_1829-right-arrow.gif Printers and Faxes.
    • In Windows Vista (default Start Menu): pattlnk_10282008_1829-vista-start-button.gifpattlnk_10282008_1829-right-arrow.gifControl Panel pattlnk_10282008_1829-right-arrow.gif Printers (under Hardware and Sound).
    • In Windows Vista (Classic Start menu): pattlnk_10282008_1829-vista-start-button.gifpattlnk_10282008_1829-right-arrow.gif Settings pattlnk_10282008_1829-right-arrow.gif Printers.
  2. Double-click the print queue device.
  3. Click Printer.
    • Make sure no check mark appears next to Pause Printing.
    • If a check mark does not appear next to Set As Default Printer, you must select the print queue device for each file you want to print.
Banner paper jams
There are many possible solutions. Try one or more of the following:
Clear banner paper jams
  2. Remove the jammed banner paper from the printer.
Review banner printing checklist
  • Use only the number of sheets needed for the banner.
  • Select the following settings to enable the printer to feed paper continuously without jamming:
    1. With a document open, click File pattlnk_10282008_1829-right-arrow.gif Print.
    2. Click Properties, Preferences, Options, or Setup.
    3. Select the Paper Setup tab.
    4. From the Paper Size area, select Banner.
    5. Select Letter Banner or A4 Banner as the paper size.
    6. Select Portrait or Landscape.
    7. Click OK.
    8. Click OK or Print.
Mar 26, 2011 | Lexmark 4600 Multi Function Printer Option...
Canon W8400 printing.
Hi Did you get an answer I have the same problem.
May 24, 2010 | Canon imagePROGRAF W8400 InkJet Printer
Printing a spreadsheet
You should tell us your "Operating System, Spreadsheet Program and Printer" for us to give you a difinitive answer. Whithout this info I will attempt to give you a general answer.
In your spreadsheet program, go to "File" and select "Page Setup" and set your paper size and set your margines and Portrait/landscape option. Your spreadsheet display should show you the paper limits for printing each page. Adjust the columns to the paper size. Highlight all the columns and rows you want to print. Find the menu option to set print area and click it. Now the computer will send the paged information to the printer and print as many pages as needed to cover the print area.
May 31, 2009 | Apple Office Equipment & Supplies
Constant yellow blinking light, no paper jam
I found this on the HP support site:
The power light is on, and the resume light is blinking.
c00109831.gifc01272271.gifc00109834.gif The printer might be waiting to complete a print job or to receive data from your computer.
Wait for the printer to finish the current task. The printer is waiting for the ink to dry on freshly printed paper.
  1. Remove the paper with fresh ink.
  2. Press the resume button.
The printer might be out of paper.
  1. Load paper in the paper tray.
The printer might have a paper jam.
Clear the paper jam. If the resume light continues to blink after the paper jam is cleared,
if the print carriage is stuck or making a grinding noise, then follow these steps.
  1. Lift the top cover of the printer.
  2. Turn the printer off and then on again.
  3. Unplug the power cable from the back of the printer when the grinding noise starts. Unplug the power cable from the wall outlet.
  4. Movethe print carriage toward the middle of the printer (this proceduremight take a couple of tries to get the timing correct).
  5. Remove the print cartridges and close the top cover.
  6. Plug the power cord into the back of the printer. Plug the power cord into the wall outlet.
  7. Open the top cover, reinstall the print cartridges, and then close the top cover.
The printer may be ready to eject banner paper.
Press the resume button to eject the banner paper.
Mar 14, 2009 | HP DeskJet 5550 InkJet Printer
Need to print banner type pictures
No, it is tells you it can print to 19", that is all it will do. I suspect buffering the image and feeding it to the print head is the problem. Make 3 x 16" and join them.
In the old days we used a dot matrix printer and continuous stationery, listing paper.
Jul 19, 2017 | Epson Stylus Photo 1400 Printer
Printing issue..please help
That sounds like a banner sheet, in your menus, Specifically a print menu you will find a section with reports, it should be caled banner sheet.
They may have another name for it. But disable that. Also go ont the driver on your computer and look to turn the banner sheet off.
Some call it a print acrivity sheet also.
make sure those pages are turned off on both the printer and on the print driver on the computer.
Feb 24, 2008 | Brother MFC 210C All-In-One InkJet Printer
Banner Printing
Hi Thank you so much for the best information wth banner design. i got my banner design method on here @ from the domain name processing, with the free services of hosting, and mosr services like, * Photo Album
* Quick Blogcast
* Hosting with site builder
* Personalized Email Account
* Starter Web Page
* "For Sale" Page
* Parked Page w/ Domain
* Domain Forwarding & Masking
* 100-Pack Email Forwarding
* Total DNS Control
* Change of Registration
* Status Alerts
* Domain Locking
Jun 18, 2007 | HP Deskjet 6940dt InkJet Photo Printer
HP OfficeJet G55 All-In-One InkJet Printer Logo
583 people viewed this question
Ben Johnson
