Question about Linksys Wireless-N WRT150N Router
Port forward problem
I am trying to play warcraft3 and can not get onto battle.net i already set the comp for a static ip and went into the router and set the ports is there something that i might be missing?
  • 142 Answers
You shouldnt need to put in a static ip. just put all the setting back to normal. Definately forward the ports. but allow the program through the routers and the computers firewall.
Posted on Dec 31, 2008
How do i open my nat for my motorola sbg900
for static IPs: check your router settings. router should be in "bridged" mode so that all the devices have own static "lan" ips like 192.168.0.1 / 192.168.0.255 router will have one lan ip static and one global ip(one it gets from service provider) you must manually give one address of 192.168.0.1 / 192.168.0.255 for your xbox. then give correct subnetmask (default 255.255.255.0) and gateway routers lan ip (default 192.168.0.254) you can aslo put routehrs lan ip as default dns if needed dmz or port forwarding is a tool in your router settings you can assign outside ports to specific ip i have only done manual port forwarding, not sure how dmz works.
Feb 26, 2011 | Arris SURFboard SBG900 Wireless Router...
Port forwarding for model number F7D5301
To setup port forwarding on this router your computer needs to have a static ip address. Or you can take alook at our Static IP Address guide to setup a static ip address. When you are finished setting up a static ip address, please come back to this page and enter the ip address you setup in the Static IP Address box below. Open a web browser like Internet Explorer or Firefox. Enter the internal IP address of your router in the address bar of your browser. If you do not know your routers internal IP address please read our How To Find Your Routers IP Address guide.
The address bar has http://www.fixya.com/AnswerQuestions.aspx#top in it. Just replace all of that with the internal IP address of your router. By default the IP address should be set to 10.1.1.1.
We do not currently know the default username and password for your router.
Click the NAT button near the left of the page.
You should now see a new menu. In this new menu, click Port Forwarding.
Enter the name of the program into the Description box. It doesn't really matter what you put into this box, but something that will remind you why these ports are being forwarded would be a good idea.
Enter the port to forward into the Public Port and the LAN Port boxes.
Use the Protocol Type drop down box to select the protocol type of the ports you are forwarding.
Enter the ip address to forward these ports to into the LAN IP Address box. If you are forwarding ports so you can run a program on your computer, you should enter your computer's ip address into that box.
Put a checkmark in the Enable checkbox.
When you're finished, click Save Setting near the top of the screen to save your changes.
And that's it! You're done!
Feb 05, 2011 | Belkin Basic Wireless Router
My xbox is connected to my internet via connecting my xbox to my laptop. I tried changing the nat settings by doing all the methods, you name it: port forwarding, DMZ, UPNP, and it STILL DOES NOT *******...
I know what you're going through as it is common on Belkin routers. There are actually some good solutions to this found on youtube for simple instruction to help demostrate but I'm gleaned you already have done some of the advanced steps. Here is my question did you ever set your xbox 360 with a static ip address and then add it to the firewall/virtual server settings. You put the static ip address in and the xbox 360 ports.
Dec 22, 2010 | Zyxel P660HW-D1 Router
I can't play my PS3 & Comp. at the same time with my router
try assigning a static IP address in the range of belkin router for your computer and PS3...that is 192.168.2.X (where X = 2 to 254)
the default gateway should be 192.168.2.1.... Log into your router and enable DMZ for the IP address assigned to your PS3...Goto Virtual servers in the router setup page and open the concerned ports for playing games in your computer(enter computer IP here in virtual servers)....the common gaming ports would be,
port 80 TCP,UDP
port 88 TCP,UDP
port 3074 TCP,UDP
port 53 TCP,UDP
click apply changes and try playing now... you can also restart the router for working better.... enjoy....
Mar 09, 2010 | Belkin F5D7234-4 Router
I have a Belkin Wireless router and I have a PS3
Actually you don't need to forward ports when playing online games. The router should automatically locate the ports for the game because it has UPnP function. Here's what you can do. Disable the port forwarding and DMZ that you set on the router. Look for the UPnP function of the router and disable, Save it. Enable it again, then save. Now power cycle your router. If you have Static IP on the PS3 network settings, try to set it first to automatic IP and automatic DNS.
Hope that helps.
Sep 23, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Belkin 54 g wireless router....cant find on the net. need to port forward to host blizzard.net games HELP!
Make sure your private IP address is statically set.  Your public IP address is obtained from your ISP and is what other users will be connecting to.  You can not manipulate your public IP address so if your ISP is running DHCP, it is very possible that your public address is changing.  Also if you are frequently disconnecting your modem, it is possible your ISP is leasing you a new public IP address each time.  So try to keep things as static as possible.  As far as the battle net stuff.
Diablo, Warcraft II Battle.net Edition, and StarCraft:
Allow port 6112-6119 TCP and UDP out and in
Diablo II:
Allow port 6112 TCP out and allow established sessions in
Allow port 4000 TCP out (realm games)
Allow port 4000 TCP out and in (hosting open games only)
Warcraft III:
Allow port 6112 TCP in (hosting custom games)
Allow port 6113-6119 TCP out and in (hosting custom games if you've changed the default port in the Options/Gameplay screen)
If you are still having problems after you open up the required ports, try opening 116(TCP) and 118(TCP). I don't really know if these ports are required or not.
I have had people tell me that opening up those two ports have helped them connect to battle.net.
Hope that helps.  For manipulating ports in your router I suggest consulting your user manual, or online FAQ.  Save your router config before applying any changes, and always remember, opening up ports subjects you to different types of security threats so be aware that is a risk you are taking.
Mar 12, 2009 | Belkin Computers & Internet
Need help getting onto Battle.net World of Warcraft
http://www.topazcandy.com/tech-candy/2009/4/30/firewalls-world-of-warcraft-and-you-part-1-norton-security.html
pay special attention to how to remove firewalls.. if you had one previously you gotta perform the steps to remove it again
Oct 29, 2008 | Nokia 7610
Router-battle.net(warcraft 3 frozen throne)
forward port 6112 on your router, if you have no idea regarding port forwarding, kindly visit portforward.com and make sure that your warcraft3 installer is licensed. Hope this help you.
Sep 28, 2008 | Computers & Internet
Ftp - port forwarding
Hello.. If you already have the port numbers needed and static IP on your computer, you can do the following steps to open them on your router:
1. connect a computer to the router wired.
2. Launch an internet browser and type in http://192.168.2.1. Use the user name and password that you have set for your router.
3. Click on the Firewall tab, then Port Forwarding
4. For the Protocol, specify if the port you will open is TCP or UDP.
5. Set the port numbers on both WAN and LAN port range then set the Static IP address on the textbox then click add. After doing that, check if you have an apply,save or ok button and click on that.
Here is the site for the user guide of your router.
If you do not know how to set a static IP on the computer, you can do the steps from this link. This depends on the operating system of the computer you are using. Make sure to set an IP address in the range of 192.168.2.x (x being a number from 2- 200).
Jul 30, 2008 | U.S. Robotics USRobotics USR5461 Wireless...
Port forwording
ok port forward if any has router this is easy ill get too others in momment
routers port forwarding features type in ip address in internet explorer search bar at top
router ip's start like this 192. type the whole ip in
this will ask you for password and that usually is the word "password" or "admin" threw that you can set the router port forward by going down the list
now for comps with out routers
goto control panel
then network connections
right click on your connection
goto properties
goto advanced
goto settings
you will be directed to windows fire wall
goto exceptions add program or port you want to forward
basically port forwarding is a program that keeps 2 comps from having conflict with each other running the same program and helps in monitoring ports for intrussions
Dec 05, 2007 | Westell Wirespeed LiteLine 6100...
Linksys Wireless-N WRT150N Router Logo
56 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
