Question about GE Profile PDS22MHR Bottom Freezer Refrigerator
Troubleshooting ? Do not have owners guide
The digital reading to set the temperature does not show. How do I reset to show the reading so I can set the temperature on the refridgerator and bottom freezer.
    President:
  • 2,692 Answers
Troubleshooting guide
no year? really?
its in the operators guide, why not read it in the glove box.
same answer every car made/
hear find it and read it.
its all there 97 up
http://justgivemethedamnmanual.com/honda/honda-cr-v-owners-manuals/
posted this 100 times.
Mar 03, 2014 | Honda CR-V Cars & Trucks
Frigidaire GLHS269ZCB4 after power outage Freezer not cooling fridge warmer hear the fan click and short cycle
Hello Wayne, thank you for allowing me to assist you. Was the freezer unplugged during the power outage? If it was, here are some simple troubleshooting steps you need to take:
It is best to unplug the unit and wait for the power to come back on.
Next, turn the control to off (or digital display), plug the unit in and reset control to factory-suggested setting.
Do not open freezer door unnecessarily if freezer is off for several hours. Make sure the refrigerator plug is tightly pushed into electrical outlet and not plugged into a GFI.
If your unit has no power and it is not due to a power outage, check the following:
Verify that the temperature control is set to the OFF position.
Set temperature controls to proper setting suggested by your owner's guide; or set to the halfway point and adjust it up or down as needed.
If these basic troubleshooting tips prove ineffective, the power loss may have possibly caused a communication problem with the control board, temperature control or wiring harness. At this point, I would recommend having a service technician to diagnose the problem before investing in unnecessary parts.
Aug 23, 2013 | Frigidaire FRS26KR4A Side by Side...
Freezer reset button
Hello Stella, based on the symptoms you are describing it sounds like the temperature control is in the OFF position. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Did you try activating the freezer by pressing the UP arrow until display shows "4" or desired setting and allowing 24 hours for temperature to stabilize? For future reference you can lock the control to keep from accidently changing the temperature setting. If so, I recommended resetting the unit by either unplugging it or flipping the household circuit breaker off. It is important to wait roughly ten minutes, then turn the freezer on and redo the previous steps. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you.
Aug 05, 2013 | Frigidaire Freezers
Lffh21f7hwa
Hello Michael - Sounds like the temperature control was accidently turned OFF. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try activating the freezer by pressing the UP arrow until display shows "4" or desired setting. Allow 24 hours for temperature to stabilize. For future reference you can lock the control to keep from accidently changing the temperature setting. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you.
Jul 01, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Control on whirlpool EEZ8OHD055V Blinks twice, no hot water
1) Call Whirlpool. 1-877-817-6750
Have them send 2 new thermistors (temperature sensors located above each element), and then install according to the instructions they give you.
2) Sounds like you have the American brand older energy-smart electric water heater with grey control box on top
Copy following link to exactly identify product and resources
http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html#energy-old
3) Two flashes is 'high water temperature shut down.
Buy cheap multimeter from hardware store. Install battery. Set to read ohm, the upside down horseshoe symbol.
Use multimeter set to read ohms, and test thermistors
Copy following link for general service manual showing error #2 and thermistor resistance chart on page 10
http://waterheatertimer.org/pdf/Energy-Smart-troubleshooting-guide.pdf
Oct 07, 2012 | Water Heaters
Yellow app dash light, the far right side next to the temperature gauge, what is this showing?
If you go to www.motorcraftservice.com
click on owners guides on the left side of the page
Pick 2004 F150 from drop down menu
Pick owner guide 1st printing
When the page loads go to page 8 and start reading from there
This explains and shows all dash lights and what they are for
Hope this helps
Aug 27, 2010 | 2004 Ford F150
Why does my camera show horizontal lines on the pictures taken by the camera with blurred black and white pictures
OK, I read that sometimes the horizontal lines in some cameras comes from the external memory contacts being dirty. If your camera doesn't have an external memory card, then it's got to be an internal board anomaly.
Under FAQ's I did not see a reference to horizontal lines.
select 'RESET' in the 'SETUP' menu it says in the troubleshooting section of the manual.
http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Digital-Cameras/Lumix-Digital-Cameras/How-To-Guides/model.DMC-TZ1S.H#ts
Jul 23, 2010 | Panasonic Lumix DMC-TZ1 Digital Camera
LG 32 LX1D won't turn on.
Unplug it from the wall for about an hour and see if it resets itself. Otherwise you will need to do troubleshooting insdie the set.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Jul 08, 2010 | LG 32LX1D 32 in. LCD Television
My oven is locked out and I cannot get it to work
Is the digital clock/timer set correctly? Sometimes after a powercut I have to reset this to get the oven controls back into manual mode. Follow this link to the user guide for your oven and have a read. Re set the timer and should be ok....hopefully! http://safemanuals.com/user-guide-instructions-owner-manual/AEG-ELECTROLUX/B1180-4-M%20UK%20R05-_E
May 08, 2010 | AEG B1180-4 Electric Single Oven
OVEN NEVER REACHES TEMPERATURE SETTING
I read my wonderful "user's guide". In the section, Controls at a Glance, I found OVEN TEMPERATURE ADJUSTMENT OPTION & followed 5 easy sets. It worked!!!
Nov 11, 2008 | Maytag MGS5870 Gas Kitchen Range
Open Questions:
See all GE Profile PDS22MHR Bottom Freezer Refrigerator Questions
GE Profile PDS22MHR Bottom Freezer Refrigerator Logo
129 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
