Question about Toshiba Satellite A215-S7422 Notebook
Screen gets testing guaranteed system
  • jobobalo Dec 31, 2008
    please ignore this question
First thing I would do is test the hard drive to make sure it is good. If new, that does not guarantee that it is good. Use a hard drive adapter that allows you to connect it to the USB port of another computer and run a full test.
Mar 24, 2016 | Maxtor Computers & Internet
Power cord replacement provide you with the total height of replacement laptop LCD screen line excellent. All of the LCD video cable carefully tested, great condition and guaranteed to work 100%.
Jul 15, 2013 | Computers & Internet
Laptop memory problems
are they of the same brand name and type of ram
Eg: hynix ddr3 low density
they might not be compatible with each other
or one of the ram slots might not be right
if you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
you should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible
hope this helps
Sep 16, 2012 | Acer TravelMate 6410 Series Laptop Charger...
The "print screen"key on my windows pro. xp does
Yes, it is possible, just follow my instructions and get your solution.
Click on Start and open All programs/ Programs and then click on Accessories and now click on Accessibility and now click on On Screen Keyboard.
Now you can use print screen (prc) just click on it through you mouse and it will work 100% guaranteed.
Rate me Please.
Feb 10, 2011 | Microsoft Windows XP Professional
Charging system fault
Yup, that won't be enough as it is normal battery voltage. You need 13.8 to 14.8 or so. Pull the alternator and get it bench tested. Alternators have diodes inside (one way valve for electricity, that converts alternating current to direct current, which your car is). and these diodes fail and leak. There is a set that turns on the regulator that fail..
All will have the same result. rebuild the alternator.
If it bench tests okay, be sure to guarantee good ground cuicuit.
Jul 15, 2010 | 1999 Chevrolet Corvette
Visco LCD TV 37" screen. Power light comes on but won't go backoff. Screen has gone blank
backlight may have gone as it doed in computer monitors
if you cab bring it yourself to a repaire and the one will give you an estimate free
if you need to buy a new one get one with the guarantee as the tecknology is yet to be improved and the life span of these monitors is no longer than two years
samsun usually offer a three year guarantee free but if you get another make or a better one akways invest in a purchase up a guarantee
Sep 27, 2009 | Televison & Video
Acer aspire bl50, turned it
it looks like having problem in your HDD, either your OS hasbeen currupted or you have physical problem in your HDD. Thats great your system is under guarantee. Just call your vendor and tell him about your problem......... n cheer-up
Mar 30, 2008 | Computers & Internet
Aspire? T180
If the PC does not to any beep then usually is a problem with the motherboard.
If the PC does a certain number of beeps on startup, then tell me how many beeps to troubleshoot the problem.
If the computer does single beep on startup as usual, then may be the monitor, monitor cable or graphic adapter.
Simple thing that you can do it yourself is disconnecting computer power cable from power outlet for 15 -12 mins. ac connect it back, this will solve troubles caused by electrostatic charges.
Also check video cable connections to monitor.
If you have another computer also test the monitor on other computer.
If the main unit is not booting (CD drives and internal fans often start up even if the Motherboard is blown). Then yo need to open the pc and test component inside.
If you have practice in fixing hardware you can start removing RAM modules and testing them, then buy a tester board for the MB and do a diagnostic test on motherboard.
Other options are taking PC to service or getting a new PC.
If the PC is still under guarantee, then contact Acer to validate your guarantee and get the machine to an authorised service centre.
Mar 16, 2008 | Acer Aspireā„¢ T180 PC Desktop
Toshiba Satellite A215-S7422 Notebook Logo
22 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
