The large knob to set the washing cycle is broke. How do I remove it? It won't just pull off
  • 4 more comments
  • bkangaroo5 Dec 31, 2008
    didn't work...what else ya got?
  • bkangaroo5 Jan 01, 2009
    Kenmore Elite 110 series. Top loading. I would really appreciate any help!!
    I'm wondering if the knob is stripped inside . No matter which way I turn it, it just keeps turning but won't come off. Any ideas on how get it off if it is stripped
    It's a 2 part knob. The dial & guard part #8541465. The timer knob is #8541457. These connect into the timer motor which is part #8541110. But I can't get to the motor yet
    Kenmore Elite 110.26962501. Is that what you're looking for?
  • suzieqcasey Jan 18, 2009
    omg i cant get the cycle knob off.... i have tried pulling and pushing in then turning to the left to spin off... nothing works.. help.
    this is a maytag top loader pav2300aww rev 17 series 17591168ca
    thanks
    Scholar:
  • 140 Answers
Unscrew it counter clock wise.
Posted on Dec 31, 2008
  • 5 more comments
  • David Robinson Dec 31, 2008
    What make and model of washer?
  • David Robinson Jan 01, 2009
    Push the knob in like you were going to set the wash to the cycle you wanted to wash on. Turn the knob to the left. If it doesn't unscrew try to the right. This how they come off. I've done it numerous time. Let me know what happens.
    I'm going to check my spech sheets.
    I need the Sears part number please.
    I'm sorry. I meant the part number of the washer.
    Yep, thanks.
    Sorry about the bad intel. That knob pulls off. No ifs ands or buts. Pull. Let me know what happens. Happy New Year!
What is the capicity of a GE WWA7600S washer
Here is the user's manual:
http://genet.geappliances.com/DocSearch/pdf/49-9810.PDF
They never talk about weight or capacity other than
Setting the Controls
Use the Suggested Fabric and Cycle Settings guide ~ Select Rinse Temperature.
to help you make the proper selections.
~ Select Wash Spin Speed.
~ Push Cycle Selector knob in and turn clockwise to
your selected wash setting. If you wish to change setting
~ Select Water Level. ~ Pull Cycle Selector knob + START out to start the washer.
SMALL: Washer is less than 1/3 full of clothes.
MEDIUM: Between 1/3 and 1/2 full.
LARGE: Between 1/2 and 2/3 full.
This washer will pretty much take anything you can throw at it. It was a competetor of the Maytag large capacity washers. As long as you follow the loading guide above you are not going to hurt it.
Thanks for choosing FixYa,
Kelly
Oct 17, 2010 | GE Washing Machines
WHDSR209DWW on/off button will not engage to spin the cycle selector dial
The cycle selector is not engaged onto the timer shaft. Need to remove the on/off knob by removing the plastic "U" clip. Remove the cycle selctor knob and check that the steel spring clip on the selector is fully seated. Re-install the cycle selector onto the timer shaft aligning the selector key with the with tthe notch on the timer shaft. Re-install the on/off knob.
The cycle selector and on/off combination is a poor design. Users press the on/off knob in and turn clockwise to set the wash cycle. If you're not gentle this action wears the teeth on the timer shaft and the user has to press harder and harder to set the wash cycle. This pressing causes the cycle selector to be pushed off the timer shaft and you can no longer operate the machine.
VERY IMPORTANT:
Stop using the on/off knob to set the wash cycle. Press on the cycle selector to set the wash cycle. Use the on/off knob only for starting or stopping the machine. Don't press or pull too hard on the on/off knob or you will wind up pushing the cycle selector off the timer shaft.
Jan 12, 2010 | General Electric WHDSR209DWW Top Load...
Soap dispenser cover won't close
It sounds like it may be stuck between cycle steps.(this sometimes happens if the washer is open during a cycle)Try and run it through one full wash cycle as it is.Then check to see if the soap door will close.If not,the lack may be broken
Jan 09, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Apr 22, 2008 | Whirlpool LTE6234D Top Load Stacked...
LG WD-8013F wont spin
Hi deppgirl,
I checked the lint filter at the front bottom left hand side and it was full of junk.  Once emptied it worked a treat.  Pull the flap down and turn the large knob anti-clockwise and pull to remove.  Good luck.
Mar 29, 2008 | Washing Machines
Frigidaire Washer Model FWT449GFS1
needlenose pliers grabbing the center shaft (white plastic around a brass center around a screw), turned counterclockwise will free the remainder of the broken knob and allow you to remove it and then screw on the new part.
Mar 23, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Timer setting
choose the load size on the timer for what your putting in large small medium etc match the water fill large small med etc select wash rinse temp to you pref add soap bleach fabric softner pull out the knob make sure the lid is closed
Feb 18, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
120 people viewed this question
Top Washing Machines Experts
