Question about HP Compaq d530 PC Desktop
ATA HDD on IDE connector with a SATA drive on a SATA connector?
My d530 has the Intel 865G chipset that gave early support for SATA, providing two SATA connectors on the mobo. I want to increase hard drive capacity while keeping the original Maxtor ATA/133 HDD as a primary.
So can I leave my Maxtor plugged into it's primary IDE mobo connector and simply plug a new SATA drive into one of the SATA connectors? The Intel 865G chipset only supports speeds up to 150, so a 300 rated drive will have to be slowed to 150 with a jumper to be recognized by XP. Some suppliers advise that drive warranties are voided if you use a jumper to slow it's speed, even when suggested to do so by the manufacturer.
Thanks,
Mark
  • Mark
    Mark Dec 31, 2008
    Tigerdirect.ca has 3 pages of SATA-300 drives, but only a single 150. No wonder as the 150 was the "intro" speed, not much if any faster than the PATA-133 drives.
  • Mark
    Mark Dec 31, 2008
    I'm a little hesitant to push my d530 that far, and for good reason: from an HP "Product Technology Brief" published May 2003, "Although the 865G chipset does support SATA, HP engineering does not believe the entire solution is ... ready for mainstream corporate deployment. Essentially, the current maturity of the SATA subsystem (controller/driver/HDD) does not meet HP’s robustness and error recovery requirements and hence will not be made available until after the d530 launch."
    Anyone try this with a d530 or with any mobo with the Intel 82801EB Serial ATA 24D1 controller?
    President:
  • 1,179 Answers
Yes you can do this but rather that buy a sata II hdd just buy a sata hdd. Might even be a little cheaper. Once you install go into the system bios & enable the sata drive. Hope this helps & please remember to rate my answer. Thanks.
Posted on Dec 31, 2008
    President:
  • 2,692 Answers
Yes. You can leave the ATA-IDE and add SATAsCan you not still buy a 150?
Where are the Sata ports onboard D845GV5R
this chipset not support sata
this chipset supports only ide hdd interface
Sep 02, 2016 | Computers & Internet
Can't setup OS in SATA HDD in Intel d945gccr
Hi.
XP will not install until you go into the BIOS and find the menu page (probably by moving across the top level of tabs) where the SATA hard drives are configured. On that page you will see the ports and at least one, maybe all, will be Enabled. Close to that will be the port mode, usually setable individually for each port. Choices may include IDE (or PATA) Emulation, SATA, AHCI. Set your port to IDE emulation. Now look at the bottom for the key to Save and Exit - often the F10 key, press that key and select OK, the computer will restart and you should now be able to install Windows XP without any problems.
To get into the BIOS you have to press the Del or Esc key when you first turn the computer on.
Regards.
Feb 04, 2013 | Intel D945GCCR Motherboard
WHAT HD & SIZE RECOMMENDED FOR MY GATEWAY 500S PC WITH OS XP?
You cannot use a SATA (serial ATA HDD in this machine. You need a PATA (parallel ATA) HDD, also known as IDE, ULTRA IDE, ULTRA ATA. This has a 40-pin ribbon connector & a 4-pin power connector.
Sizes generally available would be 80GB up to 250GB, although very few PATA drives are now sold since SATA is the new standard.
Jan 25, 2013 | Gateway GT5220 PC Desktop
I have a an INTEL Motherboard Model DH55HC. I am installing a basic Internal DVD writer (DVR-A18M) Interface ATA/ATAPi-7. I have the power cable from the POWER SUPPLY in the correct plug. I attach the...
That motherboard doesnt support ATA it supports upto 6 SATA devices which is actually better and faster. You will need to take your DVD/RW back and ask to swap for a SATA and also make sure you buy a SATA cable and good thing is these are actually cheaper and faster. Its actually a very nice motherboard dont be disappointed. Cheers from Scott and plz vote
Jan 24, 2011 | Intel DH55HC Motherboard
Can i use a sata hard drive with my ga 7vklm mobo
The Gigabyte GA-7VKMP motherboard does not support serial ATA SATA drives. Open the link provided; http://tw2005.giga-byte.com/Motherboard/Products/Products_GA-7VKMP.htm
2 x ATA 66/100/133 bus master IDE ports
1 x FDD, 2 x HDD and 1 x CD audio input
IrDA(1x5) and COM2 on board
GBT standard front panel
2 x USB2.0 connectors (support 4 ports by cable)
You can connect the adapter below to an opened IDE port and connect a SATA 1.5 drive to your system.
http://www.satagear.com/SATA-MM-A1_SATA_Adapter.html
This should allow you're SATA drive to transfer data faster than the 133MHz standard IDE speed.
Cheers'
Mike
Aug 10, 2010 | Gigabyte GA-7VKMP Motherboard
How much i can upgrade my d530 ultra slim desktop RAM and HDD
You can install up to a max 2 GB RAM and can add a 2nd hard disk
See the following Specs for your computer.
dotclear.gif HP Compaq Business d530 Ultra-Slim (Pentium 4 2.8GHz, 256MB RAM, 40GB HDD, XP Pro) Type Personal computer
  • Product Form Factor Ultra-slim desktop
  • Built-in Devices Speaker
  • Width 12.4 in
  • Depth 13.1 in
  • Height 2.8 in
  • Weight 15.4 lbs
  • Color Silver
Processor
  • Type Intel Pentium 4 2.8 GHz
  • Installed Qty 1.0
  • Max processors supported 1.0
Cache Memory
  • Type L2 cache
  • Installed Size 512.0 KB
  • Cache Per Processor 512 KB
Mainboard
  • Chipset type Intel 865G
  • Data bus speed 533.0 MHz
RAM
  • Installed Size 256.0 MB / 2.0 GB (max)
  • Technology DDR SDRAM
  • Memory Speed 333.0 MHz
  • Memory Specification Compliance PC2700
  • Form Factor DIMM 184-pin
  • Upgrade Rule Max 2 x 1 GB module
Storage Controller
  • Type 1.0 x IDE - Integrated - PCI
  • Controller interface type ATA-100
Storage Controller (2nd)
  • Type 1 x Serial ATA - Integrated
  • (2nd) storage controller interface type Serial ATA-150
Storage
  • Floppy drive type None
  • Hard Drive 1.0 x 40.0 GB - Standard - ATA-100 - 7200.0 rpm
  • Hard Drive (2nd) None x None
Dec 08, 2009 | HP Compaq Business d530 Ultra-Slim PC...
Suport hdd sata intel d865gbf?
The Intel D865GBF motherboard.
Supports 2 Serial ATA (SATA) connectors, see page 39 in your manual.
The serial ATA SATA ports will support Version 1.5GBs SATA drives not 300GBs
If you no longer have your manual, download it from Intel. Click on the link below;
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22d865gbf%22
Mike
Oct 15, 2009 | Intel D865GBF Motherboard
Msi 848p neo v motherboard problems.
Once you reset the bios everything goes to manufactures default settings. You will need to make some changes within the bios. You'll need the help of the manual. See page 3-20.
If your operating system is loaded on to the ATA IDE drive make sure you set bios settings as follows:
Connect the ATA IDE to MB primary master IDE port.
Connect the ATA SATA drive to the MB's first SATA port.
ATA Configuration
Set as, [P-ATA+S-ATA]
S-ATA Keep [Enabled] Set to [Yes] This enables the SATA controller.
P-ATA Keep [Enabled] Set to [Yes] This enables the IDE controller.
On-chip IDE configuration, "ATA Configuration = [P-ATA+S-ATA]".
Next go to Boot menu. Make sure the ATA IDE drive is chosen as boot device three.
First boot device [Floppy] (If you have a floppy disk drive connected.)
Second boot device would be [DVD/CD-ROM] drive. This should be connected to the MB's secondary IDE port & the DVD/CD-ROM drives Master/Slave jumper, set to Master.
Third boot device [ATA IDE drive]
If your boot drive is the SATA drive than set: third boot device to the SATA drive.
(Hard disk drive with operating system loaded on it).
Save your changes & exit the bios.
Keep in mind all ATA SATA drives are seen as Master drives. SATA drives are seen by the SATA controller & in order by their connection to the SATA port number.
Save & exit the bios. The system will auto restart. Windows should start.
Jul 25, 2009 | MSI Computers & Internet
Does my d530 CMT have a SATA connector?
Answers to your questions:
1. Yes
2. Very likely
3. a Google search should show you what the connectors look like.
4 HP/Compaq do a good job of providing documentation. Go to hp.com and put in your system information. You should be able to locate motherboard diagrams there. If you can't let me know and I'll try to locate them.
Dec 29, 2008 | HP Compaq d530 PC Desktop
What new HDD will match my Maxtor DiamondMax Plus 8?
Mark,
You can use any size HDD in your computer as a slave and it does not have to be an exact match for the maxtor. You will however need the make sure that the connections on the new drive match. For example SATA drives will not attache to an IDE cable and vice versa. The drive that you mentioned is an IDE style drive so unless your MOBO has SATA connectors on it you will need to buy an IDE/EIDE drive.
HP Compaq d530 PC Desktop Logo
335 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
