Question about Micro Innovations CPQ321MM Computer Speakers
Volume control Trying to locate a volume control for CPQ321MM Compaq/Micro Innovations multi-media speaker set. It's a 50K dual control, pc mount, single shaft, 6 inline pins, width 7/16 inch, length 5/8 inch.
SOURCE: Micro Innovations IC100C Personal Web Camera only showing black. Please advise!
I got the same issue
Posted on Jan 17, 2008
SOURCE: I Need driver to install web camera Micro Innovation IC200C
http://www.driverfiles.net/Cameras/Micro-Innovations/IC200C/download/page,sh,36528,298,17.html
Posted on Oct 30, 2008
  • 14 Answers
SOURCE: need driver for micro innovations
Hello! you can download the driver at
http://pcdrivers.com.br/ic100c-driver/download-384.html
Posted on Dec 22, 2008
Yazz226
  • 497 Answers
SOURCE: i have lost the drivers (micro innovations P/N: IC 100C webcam)
http://www.camera-drivers.com/drivers/230/230815.htm
http://www.driverfiles.net/page,show,36525,298,17,.html#
i hope this helps
Thanks for using Fixya
Have a nice day!
Posted on Mar 16, 2009
mi-support
  • 3 Answers
SOURCE: I have a micro innovations
To install the CM10401, please following these steps;
Important: Make sure your webcam is disconnected during the software installation.
1 - Download and install the driver software. Here is a link to the driver download page... CM10404 DRIVER DOWNLOAD
2- Restart your PC.
3- Connect the webcam and following the on-screen instructions.
4- Test your webcam.
Posted on Sep 28, 2009
I can barley hear my dragon 10.1 even at full volume
If you are talking about speaker volume, not earphone volume, chances are you have a defective speaker assembly unit which must be replaced.
Jan 09, 2015 | Dragon Touch Touch R10 10.1 Google Android...
Volume controls?
The quick specs from HP does not show a volume control. Most laptops are designed this way. All volume controls will be located on screen unless you have touch lights across the top of the keyboard, which in that case there would be 3 speaker icons (one is mute, and the others are volume Up/Down).
Feb 16, 2013 | HP Compaq 6720s Notebook
Sound (volume) of media player is at maximum but still very soft.
Go to your volume control via Control Panel or double click on speaker icon on task bar and check sound settings and computer volume or check your speaker's volume. Otherwise your speaker at fault.
Aug 25, 2011 | Computers & Internet
Can i download the driver for micros innovations m600d computer speakers? I have deleted it
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 24, 2011 | Micro Innovations MM600D Computer Speakers
3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop: Want to increase volume on speakers...
go to start. all programs. accessories. entertainment.volume control. adjust the volume in there.
May 05, 2010 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Sound is low how do i turn it up
First of all, if you have volume controls on the keypad, please make sure you turn the volume up from that location.
Next, locate the Speaker icon next to the time in the lower right corner of the screen. Double or single Click on that and make sure the volume slide bar is all the way to the top. If you right click, you may be able to select volume mixer or something similar, there you will find multiple volume settings, turn all up.
Finally, if you are having this problem when using a media player (Windows Media Player, VLC, Quicktime, etc), there will be a separate volume control within the player itself. They are usually a slide bar underneath the video or graphics display. Turn this up also.
Please note that Laptop speakers are notoriously of poorer quality and lack the wattage of desktop speakers. In turn, it may not be a problem with your laptop. You may need to look into purchasing an inexpensive set of external speakers.
Feb 25, 2010 | Dell Inspiron 2200 Notebook
Sound abscence
go into volume control and see if the settings for the speakers are turtned up and on. double click the volume icon and it will open the volume properties. go from there.
Nov 24, 2009 | HP Compaq nx6110 PC Laptop
No sound
speakers do not require drivers unless they connect via usb. Sound cards and sound chipsets do require a driver but you have to identify the sound device first.
Apr 30, 2009 | Micro Innovations CPQ321MM Computer...
Cpq321mm microinv. desk top speaker system . I need to know what voltage the power supply is as i have put mine in a box of 35 different ones
AC Adaptor Model RGA57122000 Input 120 VAC, output 12 VAC 2000mA. I have this very set and just now took the info off the unit.
Dec 29, 2008 | Micro Innovations CPQ321MM Computer...
Micro Innovations CPQ321MM Computer Speakers Logo
Top Micro Innovations Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Micro Innovations Audio Player and Recorder Expert? Answer questions, earn points and help others
