Question about Maytag MGR5751AD Gas Kitchen Range
Maytag Oven Door is locked
My cleaning lady cleaned my stove - now the oven door is locked and won't open - she she sahe may have pressed buttons but it is locked up. Please help!
  • Jyackle5
    Jyackle5 May 11, 2010
    Try holding the clear/stop for 10 sec.
  • Anonymous Mar 20, 2014
    my oven doors ar locked and its says off
  • 3 Answers
I had the same problem.  Unplugging the oven didn't solve it, as the same "F9" message appeared when restarted.
Here's what worked:  start a cleaning cycle, and then hit cancel.  I leaned on the door just a little, the latch stopped making the "clicking" noise, and then the lock light turned off and the door opened.
Posted on Jan 30, 2009
  • 231 Answers
Suggestion from => http://www.fixya.com/support/t135369-oven_door_unlock
The first step I would recommend you to do is to turn the circuitbreaker on, then set up the oven clock. Start the self clean for anyamount of time, wait about 30 seconds and push the cancel button. Mostof the time it helps to eliminate the problem.
I've read other places that turning the fan off will unlock the oven.
Posted on Dec 31, 2008
Maytag Oven model MER5755QAQ has lock on the display and the oven will not operate.
If one of the position switches on the latch assembly is not reading, the control will sometimes lock because it "thinks" a clean cycle has been initiated, if replacing the control did not fix the lock icon, test the switch... Incorrect temp probe and thermostat failures can also make a control "think" it is in a clean cycle. Maytag Range Stove Oven Door Lock Motor and Switch Assembly WP74008702 Maytag Range Stove Oven High Limit Thermostat 74008715
Jul 06, 2016 | Maytag Kitchen Ranges
Door is lock
How to unlock Kenmore oven - YouTube
? 1:07
www.youtube.com/watch?v=xnwnLi8Ld5I
Jun 30, 2013 - Uploaded by Imi Chitterman Kenmore oven lock and unlock after self cleaning. ... What should I do to get my oven door open please? I pressed the start button but it didn't ...
How To Fix Oven Door That Doesn't Open After Self Clean ...
www.partselect.com/.../Range-Stove-Oven/Door-Will-Not-Open-After-S...
If the door will not unlock at the end of the clean cycle then you may have a problem with the oven temperature sensor. Most electronic control ovens will display ...
Nov 05, 2015 | Kitchen Ranges
Maytag Frigidaire Electric selfcleaning oven slide in type 30 inch wide purchase in 2003 --cleaning lady cleaned oven,unable to pull open oven door -door is jamed shut ???
Hello
Let oven completely cool then try.Locks out for safety because of extremely high temperatures involved in self clean mode.
Feedback appreciated
Aug 05, 2011 | Frigidaire FEB24S2AS Single Oven
Range
un plug the stove and plug it back in.
Dec 08, 2008 | Maytag Kitchen Ranges
My self-clean Maytag electic stove (7 to 8 years old) will not clean because when you set clean on the touch pad the automatic door locking device moves to lock the door, and does pull the door in briefly,...
I fixed the problem simply by pressing the clean button when the oven was warm, not cold.
For some reason not explained in the instruction manual, the oven door safety locked properly and automatically when the oven was warm. I don't know why, but I'll take it!!
Dec 07, 2008 | Maytag Kitchen Ranges
Oven locked so I can't shut door/operate oven
Thanks a million, solved the problem like a charm. For those that can't find it, it is on the left side orf the OVEN, not the stove. Once you open the door, you'll find it on the frame's upper left side corner, can't miss it. Good luck
Oct 27, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Oven Lock stuck open before start of self-cleaning cycle
push in on the oven light switch and hit clean then cancel you have to hold the oven light switch thats what tells the eoc the door is closed if this dont work reply to me
Jun 05, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Locked oven door
Look for a button or sensor which the door would press when closed.
If you find it hold it down for a minute, this should reset the lock
if it doesn't it may do when you let go
May 12, 2008 | Kenmore 95680 / 95681 / 95682 / 95684...
Self cleaning
You can go to the Maytag web site and download the manual.  www.maytag.com, or go to http://shared.whirlpoolcorp.com/assets/pdfs/literature/8113p293.pdf
and download the manual CAUTION
• It is normal for parts of the ovens to become hot during a self-clean cycle.
• To prevent damage to oven doors, do not attempt to open the doors when LOCK is displayed.
• Avoid touching doors, windows or oven vent area during
a clean cycle.
Do not use commercial oven cleaners on the oven finish or around any part of the ovens.  They will damage the finish or parts.
Do not leave baking/pizza stone in the oven during self-clean.
The self-clean cycle uses above-normal cooking temperatures
to automatically clean the oven interior.
The oven should be cleaned regularly by wiping up spillovers
to prevent excessive smoke and flare-ups.  Do not allow a
heavy build-up of soil to accumulate in the oven.
During the cleaning process, the kitchen should be well
ventilated to get rid of normal odors associated with cleaning.
Before Self-Cleaning
1. Turn off the oven light before cleaning as the light may burn out during the clean cycle.
2. Remove broiler pan, all pans, and oven racks from the oven.  The oven racks will discolor and may not slide easily after a self-clean cycle if they are not removed.
3. Clean oven frame, door frame (area outside of gasket, and around the opening in the door gasket) with a nonabrasive
cleaner such as Bon Ami* or detergent and water.  The self-cleaning process does not clean these areas.  They should be cleaned to prevent soil from baking on during the clean
cycle.  (The gasket is the seal around the oven door and window.)
4. To prevent damage, do not clean or rub the gasket around the oven door.  The gasket is designed to seal in heat during the clean cycle.
5. Wipe up excess grease or spillovers from the oven bottom. This prevents excessive smoking, flare-ups or flaming during the clean cycle.
6. Wipe up sugary and acidic spillovers such as sweet potatoes, tomato, or milk-based sauces. Porcelain enamel is acid-resistant, not acid-proof.  The porcelain finish may discolor if acidic or sugary spills are not wiped up before a self-clean cycle.
Important:
• Oven temperature must be below 400° F to program a clean cycle.
Only one oven can be cleaned at a time.
• Both oven doors lock when either oven is being cleaned.
To set Self-Clean:
1. Close the oven door.
2. Press the Clean pad.
    • CLEAN flashes.
    • SET and UPPER or LOWER flash in the display.
3. Press the Autoset pad.
    • “MEd” (Medium Soil, 3 hours) is displayed.
4. Press the Autoset pad to scroll through the self-cleaning settings.
     “HVy” (Heavy Soil, 4 hours)
     “MEd” (Medium soil, 3 hours)
     “LITE” ( Light Soil, 2 hours)
Choosing the soil level of the oven automatically programs the self-cleaning time.
5. After four seconds, the oven will start cleaning.
    • If the door is not closed, beeps will sound and ‘door’ will display.         If the door is not closed within 30 seconds, the self-cleaning       operation will be canceled and the display will return to the time of day.
    • CLEAN will appear in the display.
    • LOCK will flash in the display.  Once the door locks, LOCK will
      remain steady.
    • The cleaning time will start counting down in the display.
Nov 27, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MGR5751AD Gas Kitchen Range Logo
702 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
