Question about HP Business Notebook NX9110 Notebook
Laptop turning off
I have had this problem with my Hp for a few months now. I go to start it up, it can be anywhere from the windows start up screen to 20 minutes running and it turns off like the battery is flat. I tried to remove the battery and just have mains power but it still does it (even having the battery in and disconnecting the mains it switches off automatically). Only thing I can think of is the power adapter... any thoughts?????? please!! az
  • Anonymous Nov 29, 2007
    My Compaq/HP nx9110 has a similar shut down problem. The side fan comes on for the first three seconds and then turns off. The rear fan keeps running OK. The computer can run for 10 seconds or three hours. After a few attempts at starting the air coming from the side fan is quite warm but that side fan still only runs for three seconds. It doesn't matter whether I use just battery power or mains power.
    I have blown both fans to clear then, the rear fan was a bit dusty. This did improve the running times a lot. I've tried running FanSpeed but it doesn't appear to see either fan or some of the other temperatures.
    Regards Chris.
    Novelist:
  • 198 Answers
Hello, This usually indicates a heating problem. You can do the following tests to furthermore reduce the "suspects" list. If the power adaptor is damaged, or you think may cause that you can simply check the green led on it. These power adaptors are actually ac/dc convertors that have some electronic protections incorporated. If for some reason they get damaged they woun't be able to provide the required current to keep the laptop powered up and they will turn off. Also if the laptop is damaged and drains more power then usuall the adapter will automatically cut off power due to a internal failsafe protection. In any of these cases you can notice that the green led turns off even if the adapter is still plugged in. A service intervention is required here because most likely the problem is with the laptop requiring more current then usual, not the adaptor being damaged and not able to provide. Another thing you can check is the way this problem occurs. Try powering laptop using only battery power one time, and only ac power another time. If the problem still appears, it is not related to the power source being used, and combined with the first test, gives you a pretty shure way to know that batteries and charger are pretty much OK. Now my personal "main suspect". To prove you my point, do the following test. Use both battery and ac power for this one. Turn on the laptop and check the clock to see how much time it will stay on while running iddle, without you doing anything to it. Just keep it on. You will get a time value. Then another time check to see how much time it will stay off when you use it very intensly for playing video games, using as much programs as possible at the same time or playing a movie and in the same time playing music from another program. I guess in this case, it will turn off a lot faster than first case. The reason is this: All HP laptops (pretty much all laptops) have a failsafe device built into them that measures the processor's main temperature. If this rises above a certain safety level that device will simply power off the laptop to avoid processor overheating. Normally as you can gues, this isn't suposed to happen because the cooling system of your laptop should take care of the extra heat. However, over time, the cooling system can become inefective due to dust stuck into it, blocking the air ducts or reducing the spin speed of the small cooler inside. Because of this, the cooling system can't perform at nominal eficiency and overheating becomes a problem. In this case, you will have to go to a service center, but don't worry, it's not an expensive repair. They would most probably have to simply clean up the cooling fan or the air ducts in order to have the cooling system work properly again. Where to go? If your laptop is in warantty and you have this option, send it to a hp authorised service. If not... avoid them because they are expensive. TRy a smaller generic "laptop service" not the larger ones working for corporation. The smaller ones are more cheaper and there is absolutely no difference in the quality of the work being done, having noted the simplicity of the problem. If you however need more assistance, I can gladely assist. Also please excuse my poor english as I live in a non-english speaking country. Good luck and please rate any answer received from the members of this site.
Posted on May 04, 2007
I press start on laptop, windows 7 will not load up, i have to press F8 a few times to load ,windows 7
Try a cold start, unplug, remove battery, hold down on/off button for 10 seconds, replace battery, plugin, push on/off button, try to start normally. If that fails do a system resotre/ recovery.
Nov 04, 2012 | HP Computers & Internet
Grey screen but everything else works as normal Initially, on the windows startup (Bios) and the welcome screen, the colour is fine, everything is there. But after a few seconds logged in, everything turns...
That sounds like a problem with your GPU, this is very common with Nvidia graphics cards when built onto motherboards for mobile devices. First contact HP to see if you have any warranty with them, if not then you can either look for a company that specialises in board repair in your area or if you are brave try a DIY fix. Search 'motherboard DIY reflow' on google or youtube to see an example. Hope this helps,
www.PuterCare.com
Jul 21, 2010 | HP G60 Notebook
Laptop will not boot up. Gives 2 options...start windows normally or go to repair and recovery mode. neither works. It is only 6 months old and worked fine for a few months then stopped.
Looks like you have had whats called a crash.?
If first experience, no prod, turn on, await screen , if it shows, click "Start Windows"
Hopfully end of matter.
Advise you backup your important data/files to external HDD, incase there is a more serious problem wait to rear its unwelcome head?
Fingers crossed. Good Luck!
Nov 14, 2009 | Computers & Internet
Screen goes black after Windows Vista boot
Hello There is chance of serious problem with the screen of the Your laptop. This problem is often seen in case of HP laptop which are more then 6-7 months old. So if the laptop is under warranty they(customer care) will replaced the screen for free. If not the will charge few $ and provide you with original screen. Please check with the vendor from where you have bought your laptop. Regards Gizokieth
Oct 06, 2009 | HP Pavilion dv2310us Notebook
My laptop screen has turned pink and green and grainy
hi sonny my laptop is a dell inspiron 14 r 4010 and its doing the same thing as well. How do i fix that?
May 21, 2009 | Philips 55PW9363 55" Rear Projection...
Hp 6225 Pavillion Will not fully turn on.
If you can go to their website, and search your machine, I am sure you will see that this is a known issue with several models. They are offering a free one time fix even if out of warranty. I know this because I just got the box to ship my wifes laptop back for the same thing.
Jan 01, 2009 | HP Pavilion dv9000z Notebook
Optima EP721 DLP and HP Pavillion dv 6000 laptop
if you are wanting to connect ur laptop to an external display then you have to go the control panel, then display properties and change the resolution since ur laptop screen's resolution and external display's resolution might be different. most of the computers with vista automatically adjust that but in xp, u might have to do it yourself.
Oct 27, 2008 | Dell Latitude D600 Notebook
Dim screen
A New Backlight, or new bulbs for your backlight..
Jun 09, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Presario v2000
When you first turn the laptop on, wait for the Compaq screen to go then press F8 a few times.
A Windows Start screen will appear
Select "Last Known Good Configuration" and press enter twice.
Apr 13, 2008 | HP Compaq Presario V2000 Notebook
HP Business Notebook NX9110 Notebook Logo
69 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
