Question about Toshiba 42HL167 42 in. LCD Television
Only getting sound but no picture!
We hook up our DVD player (video, audio hook ups) to our Toshiba Flat screen tv and get full sound but no picture
  • 8,596 Answers
Well, i had a look at the back of that Toshiba TV - make sure that the red, white, and yellow cables are hooked into the Video-1 slot of the Toshiba and that the Toshiba channel is changed to Video 1.
Then check your nameless DVD player and make sure the red, white, and yello cables are all hooked to OUTPUT slots that are in the same column or row - if I had you DVD manufacturer and model #, I could suggest some additional steps to check. Also, make sure your dvd player is in dvd playback mode.
-Tha Mp3 Doctor
Posted on Dec 31, 2008
How do i hook up a dvd player yo a 55" emerson flat screen tv
Use a n AV Cable, Yellow (Video) white (Audio) Red (Audio) and plug into DVD AV OUTPUT and plug into TV AV 1 or AV 2 Inputs and then select the AV Input you are using on your TV Via your TV Menu and you shall have sound and Picture.
Happy Movie entertainment.
Jul 31, 2014 | Televison & Video
How to hook up receiver to tv and dvd player
There are Blu ray DVD player that have audio out.
• Connect these audio out ( red and white ) to receiver aux audio in.
Sounds will be heard on your receiver.
Aug 05, 2012 | Audio Players & Recorders
Connecting dvd player to a television need a diagram t.u
If you are going to hook up the DVD player to your TV through RCA cords, see the picture below.
Hook up the yellow RCA cord at the Video-in at the back of the TV and the other end at the Video out of the DVD player to get the video.
Hook up the red RCA cord at the Audio-in(right channel) at the back of the TV and the other end at the Audio-out of the DVD player.
Hook up the white/black RCA cord at the Audio-in(left channel) at the back of the TV and the other end at the Audio-out of the DVD player.
Red and white/black RCA cord is for the sound.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Sep 07, 2011 | Televison & Video
How do I hook up a DVD player to a proscan 32 inch flat screen tv?
to connect your TV to your DVD, you will be needing a RCA wire (Yellow, white and Red wire). The yellow stands for video (visual/display), while the read and white stands for audio (sound).
Look at the back of your DVD, look out for Video Out, connect the yellow wire there. Also look out for Audio Out L & R, connect the white and red wire there.
Then turn the back of your TV, you will find Video, and Audio IN, Connect the other part of the wires from the DVD to the DVD, that is, Video for video and audio for audio.
Once you have connected the wires, turn on your TV, and your DVD player, press source on your TV remote to AV, and you will see your DVD displaying on your TV.
That's to hook up your DVD to your TV. Follow instructions carefully and you won't have any problem.
Good luck.
Apr 17, 2010 | Proscan 32LA30Q Television
New toshiba lcd has sound, is getting all cable
What kind of video connections are you using to hook up the cable and the dvd player? Also does the menu of the tv come up normally? Once I have more information I can assist you further. Worst case scenario you will end up needing to return it for a replacement where you bought it from but lets do a little troubleshooting first.
Thank you,
Nov 20, 2009 | Toshiba 22LV610 LCD TV
I have a 42 inch Insignia plasma tv. I only hook
If you have the audio cables hook up correctly to where the video cable from DVD is connected to, it should be RED and WHITE wires for audio. Then go to on screen audio setup menu to see if the speakers is turn off in the menu. Also try hooking up the powered PC speakers to the AUDIO LINE out RCA jacks to see if you get the sound OK there.
Nov 03, 2009 | Insignia 15 in. Flat Panel LCD HDTV
When i hook up dvd player to a insignia plasma tv i get a picture & sound but it is in black& do i get to be color
if you connect composit video from your DVD player to the "Y" jack of the tv then you will get only a black and white picture .. the composit video out of your DVD has to be connected to the composit video input of the TV .. or if you have component outputs on your DVD then you can hook those up to the "three" component inputs of the tv .. (you have to have all three hooked up plus 2 audio cables ..
Oct 23, 2009 | Insignia 42" Flat-Panel Plasma HDTV
Flat screen to dvd connection help!
It depends on the TV.
On my Phillips TV this is switchable via the TV setup menu, and you get no sound with HDMI unless you change that setting.
The reason it's switchable is that the HDMI input is usually common with one of the component-video inputs (AV3 on mine). (cost saving move)
Thus if the menu is set to hdmi, then the audio goes thru hdmi. If it's set to 'component' then it goes thru the RCA patch cable.
Oct 07, 2009 | Televison & Video
Picture but no sound only loud hum
You have to double check the inputs of the video in as well as the audio in on the TV set. they come from the video and audio output on the DVD player. Good Luck
Jun 28, 2007 | Samsung DVD-V9650 DVD/VCR Player
Toshiba 42HL167 42 in. LCD Television Logo
301 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
