Question about SanDisk Sansa e200 MP3 Player
UNIT WILL NOT COME ON AND UNIT WILL NOT CHARGE.
THE UNIT WILL NOT COME ON AND AFTER CHARGING OVERNIGHT, THE UNIT STILL WILL NOT COME ON. IS THE PROBLEM THE BATTERY OR IS THE PROBLEM IN ANOTHER AREA OF THE UNIT?
WILLIAM H. CAIN
VIRGO44@EARTHLINK.NET
(843) 399-0313
  • Anonymous Jan 02, 2009
    There is no pin hole for reset. The um for the Sansa e200R does not indicate or mention reset.
    Problem Solver:
  • 12 Answers
Reset the player following the user manual instructions (usually a small pin hole on the player)
Posted on Jan 02, 2009
  • chayton6
    chayton6 Jan 04, 2009
    You may have already tried this, but press and hold the menu button for 15 to 20 seconds.
Will not charge and actually seems to discharge when plugged in to auto charger
Charge the unit overnight with a high power usb charger, 2A or above. If it turns on after that, check your auto charging cable. It should have a red led that illuminates if it has power. If it does not, then it is either the cable or a fuse blown in your car. If the gps still does not turn on after chargning overnight, you have a batter issue. Amazon sells battery kits.
Apr 06, 2015 | Garmin nuvi 2599LMTHD 5" GPS with Built-In...
My NUVI 55 keeps turning off and on
Charge the unit overnight with a high capacity usb charger, 2A or higher. If the probably persists, you have either a batter issue (Amazon sells battery kits) or your car charging system is defective. Your device is not getting enough charge to stay on.
Mar 31, 2015 | Garmin nuvi GPS
I recently puchased an EGET MO-H04CD portable oxygen concentrator and I am having problems charging the Lithium batteries that were supplied with the unit. There are no instructions on how long you have to...
Red light normally means that the battery needs charging. The green flashing light can mean the battery is charging or has charged, and the same with the solid green light. Green in this case is good.
Charge the unit overnight and see what the indicator state is. It should not take more than 8 hours of charging for a Li-ion battery. Once you know what the full state light looks at, then you can tell what the charging indicator looks like.
In all cases, ensure you are using the proper charger with the unit.
May 14, 2011 | Health & Beauty
The phone is dead but the machine still answer calls
Make sure the battery is inserted correctly in the cordless handset and that it is left on the charging cradle to fully charge overnight.
If the battery still does not power the phone even after charging, then the battery may be permanently depleted. Try buying a new battery for the unit. Be sure to fully charge the new battery as well before using.
Good luck.
Apr 17, 2011 | Uniden EXA 7950 Cordless Phone
Have a Motorola 2 way walkie talkies but misplaced the manual on how to operate the unit. Bought these at Canadain Tire about 5 yrs. ago. Not sure if 1XTN4004B or CH600 is the model number. Please advise...
Haven't been able to locate a user guide for the multi-unit charger. However, it is pretty much plug-in-n-play. It can charge a battery inside a radio, or also accommodate a battery alone in each of 6 cups. As for replacement parts, they are not available, and you cannot purchase the multi-unit tray separate from the power supply. This is a slow rate charger and would take 10 hours to charge your batteries (or overnight). Radios/batteries should only be placed on the charger when nearly depleted. (Consider your charge a place your radios go to bed overnight.)
If you are having difficulty with charging, clean your battery contacts on the exterior of the radio and inside the charger cups with a pencil eraser.
This tray can act as a radio cloning station. See page 23 about cloning in the XTN radio user guide: http://www.123radios.com/manuals/xtnmanual.pdf
Best regards.
Jan 09, 2011 | Motorola XTN-Series Multi-unit Charging...
My garmin 765 T won't turn on- I have charged it overnight
If you are charging your unit with the USB cable STOP - use only a wall plug. The unit will not charge using the USB cable. If you don't have the wall unit - try charging it with the car plug charger for 15 minutes. Just let the car charge it running or not. You will see it work. Once it is charge over half way - the rest will charge up. It is a problem Gamin is working on.
May 05, 2010 | Garmin nuvi 765T GPS Receiver
I have had this charging overnight but it won't charge. What should I do?
Hello Friend,
It depends on what you mean by charging overnight.
1. When you connect the charger, it shows on the phone that it's charging but after a while if you unplug the charger, it's still not charged: if it's the case, that means the battery is dead and needs to be replaced.
2. When you connect the charger, it doesn't show the phone charging: in this case it can be the charger brocken or the phone charge connector is faulty. you can verify that by moving the charger connector a little bit and see if it will start charging, if not you can try with another charger. if it doesn't charge even with another charger, at this time i will say for sure that the phone charge connector is faulty and needs a repair.
Best Regards,
Oct 30, 2009 | Toshiba e310 Pocket PC
Not charging headst
Let it charge for 12h or overnight(even if no light) ,light will be up when unit charge itself to some point .
Aug 19, 2009 | Samsung WEP460 Bluetooth Headset
NEW PURCHASE AND PLUGGED INTO AUTO TURNED ON AND GARMIN LOGO APPEARED AND THEN SCREEN WENT BLACK. DOES NOT WANT TO STAY ON. INTSTRUCTIONS SAY UNIT WILL PROMPT BUT NOTHING HAPPENS. IS THERE SOMETHING ELSE...
Yes!!! Please charge the unit overnight. You didn't say what model you have. If it's a 2xx series, plug in the charger and move the on/off switch momentarily to the left until you see the screen say charging. Set the unit down and the screen will go off. If you touch the screen again, it will come on. After charging is done, when you touch the screen it will say charging is complete. Remove the charger. If its' a 3xx or 6xx product, hold down the on/off power button until you get the charge screen.
- Jim
SHARCNET-USA
Dec 11, 2008 | Garmin GPS
Garmin Nuvi 760
Sounds like you both have a battery problem. I experienced a similar problem when trying to charge via the USB-cable connected to my computer.
Ended up buying an original charger (expensive) and the charging went smooth.
The car charger should in any case work fine, so probably your battery is not very healthy.
Try holding your finger on the battery symbol for about 10 sec. The unit will then switch to a technical page. There you can observe the battery and charging voltage. When I plug in my computer USB-cable, I read around 4,4V and that is not sufficient for charging my battery.
When connected to the original charger, this voltage rises to about 5V which gives a nice charge. When unplugging charger, the unit displays the battery capacity. If the charging voltage is OK, but battery capacity drops quickly after you unplug charger cable, the battery is probably bad. (Of course you have to charge is for some time) I think around 4V battery voltage give 100% capacity. 3,9V gives about 90% capacity.
This will not solve your problem, but can give you an idea about what is wrong.
Good luck.
Oct 28, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
SanDisk Sansa e200 MP3 Player Logo
47 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
