Question about Panasonic NV-FJ620 VHS/S-VHS playback VCR
VC recorder keeps on driving
Hi, This morning my wife could not get a cassette to eject. I took the cover off the recorder and 'muscled' it out. However, seems like I damaged the loading arm cog. Fortunately I was able to get a replacement here in Adelaide SA and install it. I had to mess around with the timing of the two loading arm cogs to get it to accept a cassette, but finally seemed to get it working OK.
Now when a cassette is inserted, none of the controls seem to function - it won't stop playing or eject the cassette. The player just seems to continually drive the tape slowly, even when the ON/OFF button has been hit. I have to turn the machine off and manually wind it out.
The drive belt seems to be OK - this was suggested as a possible cause of the not-ejecting problem. Can't see any other obvious problems.
Can you suggest a cause and solution to the problem.
  • William Dec 31, 2008
    I would appreciate if you could add this information:
    Where is the sensor located, and what does it look like?
  • William Jan 01, 2009
    I think the problem is that the loading arm cogs are not in the correct timing position. Can anyone suggest how to time them correctly?
    An expert who has written 3 tips or uploaded 2 video tips.
  • 242 Answers
Retime the gears and clean everything
Posted on Jul 18, 2010
  • 1,199 Answers
I beleave your sensor that tells the player weather a tape is in there or not needs replaced ~ It sounds like it doesent know the tape is not there aand will not shut down! (replace tape sensor)
Please rate my answer and help keep this site free!
Posted on Dec 31, 2008
How can I get my tape to eject?Sharp VC-A560. Played my taped, rewound, but tape would not eject. Tried to play again and it would not play.What can I do?
Unplug from wall outlet - find the wheel that ejects the tape when you slowly turn it. It's usually on the right side when the cover is open. Avoid touching any metal parts.
Mar 01, 2015 | Sharp VC-A560U VHS VCR
Trying to do a timer recording to a Toshiba SD-V296KU DVD Video Player/Video Cassette Recorder. all seems to go with the recorder device but when I do the playback it is a blank screen. Is that because the...
I have a Toshiba DVD Video Player/video Cassette recorder - the problem is that when I set the VCR to record for an hour it will record for less than that hour and eject the tape. Help!
Mar 01, 2011 | Sansui HDLCD-4212 LCD TV
DVDR/VCR Combo_ZV450MW8a. When I insert the VHS cassette...
Had the same problem. took cover off, cleaned the recording heads. Also look on the left and right of casett chassie.You'll see to thin green strips sticking up with a black elctronic device. Chech to see if it is aimed at the clear plastic pin near the little black plastic gear in the middle. mine was out of alignment on the left one. Works know. Good luck
Jan 24, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
VCR ejecting my cassettes
Try removing the top cover & have a look to see what happens when you put the tape in & press play/rewind etc. Is the take up spool (right hand spool) turning properly or is there slack tape not being taken into the cassette? Are the heads spinning ? I think your problem is more likely to do with the tape not travelling smoothly around the tape path. Possibly the clutch gears need cleaned or the soft brakes may not be dis-engaging properly.
Jul 19, 2009 | Televison & Video
Will not accept cassette - keeps responding "eject cassette"
Had the same problem and took the battery out of the camera to reset. Worked fine after that.
Mar 28, 2009 | Canon ZR300 Mini DV Digital Camcorder
Eject the tape from a Dictaphone 1243 voice recorder
The top cover slides down, and then the cassette should easily lift out.
Mar 15, 2009 | Dictaphone 1243 Handheld Cassette Voice...
Panasonic video recorder malfunction
It sounds like you need a service manual - it tells you how to remove stuck tapes etc.If you need a service manual for this model, which is helpful for checking things/disasembly/assembly, you can obtain a free one from:-
Dec 31, 2008 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
My ZR30mc video recorder will not eject cassette
Take the side panel off to see whether the tape is damaged and will not retreat into the cassette ( this will prevent ejection ). Remove old damaged cassette and insert new one. If the unit chews the new cassette camera should go in for VTR service.
Sep 01, 2007 | Canon ZR30MC Mini DV Digital Camcorder
Panasonic NV-FJ620 VHS/S-VHS playback VCR Logo
114 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
