Question about Kenmore 33464 / 33465 / 33469 Gas Single Oven
Oven will not heat to temperature setting
Set it for 500 to get to 350. New 24 inch wide oven. Kenmore 30522
  • Anonymous Feb 27, 2009
    I can not get the oven to cook at 350 degrees, it wont reach that, but if I go past 400 - it works. Whats up with that?
Called a Sears Tech to check it out. He found it was the control board/clock/timer. He said it was the first one he had seen go bad, and was happy I had the part number from your site, as it did not yet appear on his computer.
Posted on Jan 02, 2009
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
Kenmore 7909445 oven not reaching specified temperature?
The User's Manual says that the minimum temperatures for most settings is 170F. If those are also the defaults, the oven controls might have forgotten their settings and might need to be reset. If resetting the controls doesn't work, you might want to try checking the temperature sensor; sensors go more frequently than control panels do. I have included a link to the User's Manual I found.
http://www.saferproducts.gov/Common/Pages/DisplayDocument.aspx?documentId=294072
May 23, 2014 | Kenmore Ovens
I hit the bake button on my oven and after 10 secs it says preheat and thats all that happens nothing else no heat at all
Your oven will continue to indicate that it is preheat mode until the thermostat senses the proper set temperature. If you are getting no heat then you will need to address that issue. This could be many things but the most notorious would be the heating element. Could be the control panel as well. Some ovens have a knob for preheat, bake and clean with a separate knob to adjust the temperature. Make sure both are set properly.
Regards, Tony
Apr 07, 2011 | Kenmore Ovens
I have a Thermador wall oven (POMW301/02) when bake is selected, heats up very slowly until the pre-heat light goes off. And then the oven light stays on but it doesn't hold the set temperature. While it...
Due to the nature of the self-cleaning cycle heating the oven to above normal temperatures what likely happened is that the temperature sensor went bad. The sensor is a small rod about 6 inches long and 1/4 inches wide that sits in the back of the oven. You can remove it from the back side of the oven which will need to be pulled from the wall. Replacing it should solve the problem.
Let me know how this works out for you.
Benjamin
Dec 28, 2009 | Ovens
Model # c970-47821-3 shuts off when it heats up and displays F2 or F3?
F2-F3 is a bad temperature sensor.
Unplug the range. Open the oven door.Remove the racks. Look up high on the back wall of the oven to locate the temperature sensor. It is metal and about 4 inches long and thin.Remove the 1 or 2 screws holding it in. Pull it out of the hole carefully. Unplug it. Install a new sensor.
Dec 22, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
My Whirlpool oven no longer heats to the set temperature.
Temp probe/thermometer inside oven dirty, or off attachment, or defective. On some models, a small screw head adjustment is provided to calibrate thermometer under dial knob. Else, I would just set dial 50 degrees higher rather than expense of new thermometer or dial.
Mar 02, 2009 | Ovens
Kenmore 24" built-in oven wont heat
HI THANKS FOR THE QUESTION oN SOME MODELS THERES A FEATURE THAT IF YOU USED THE TIMER OR THE TIMER SETTINGS MAY HAVE BEEN ACCIDENTLY BEEN CHANGED CHECK TO SEE IF YOU HAVE THE KEEP WARM SETTING ON THE TIMER OR A BURNT OUT BAKE ELEMENT THANKS THEAPPLIANCE DOC
Sep 12, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
F5 error on a Kenmore Gas Oven
f5 is a door lock code there is a problem with your door latch. its should lock the door at a crtain temperature and its not.
Mar 31, 2007 | Kenmore 30169 Electric Single Oven
Kenmore 33464 / 33465 / 33469 Gas Single Oven Logo
297 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
