Question about Dishwashers
No power to New Frigidare dishwasher
Hi, I have a new Frigidare dishwasher. I connected the power correctly (black to black, white to white, and the ground screwed to the junction box). I turned the breaker on, but I get no power. I tested the power coming in and it is hot. I thought that there was something wrong with the unit, so I returned it to the store and got another one. I have the same problem with this new washer also. Is there something that I am doing wrong?
  • 148 Answers
There should be a cut off at the dishwasher .. usually a light switch or something similar that cuts power at the dishwasher only. Check to make sure that you have that turned on.
Posted on Dec 31, 2008
Where on dishwasher is power supply? like how do we connect to power?
You connect your incoming 120v supply to the black and white wires on your d/w. the black and white wires are located at the bottom of your d/w on the right hand side in a small box. You may need 1/4in nut driver to open the box and there you will find your white(neutral) and black(hot power) wires located
thanks.
Dec 12, 2010 | Maytag 24 in. MDB5651A Built-in Dishwasher
HI, I HAVE A SYLVANIA MODEL SA 170 , I CAN´T SEE THE NUMBERS WHEN I´M IN FROM THE SCREEN, IT´S APPEARS VERY DARKS
If I understand correctly, you have Sylvania 170 timer and the display doesn't light up.
If you have different problem, add a comment.
A) If this is existing installation and timer display worked correctly before, then it sounds like timer malfunctioned or power to timer is interrupted. Check breaker, and then pull out timer and test for power.
B) If this is new installation, then 2 possible things:
1) Timer defective: exchange for new one.
2) Timer not wired correctly.
Review wiring:
Timer replaces single pole switch.
Single pole switch has two wires
Timer has 3 wires: Blue Black White
Timer has additional wire to run internal clock and to light up display.
If timer not wired correctly, then display will not light up.
Here is correct wiring:
a) Two wires from switch.
b) Connect timer-blue wire to one of the switch wires. Choose either one for now. You will have to choose other wire if display doesn't light up.
c) Connect timer-black wire to other switch wire.
d) Timer-white wire does NOT connect to either switch wire. Look in back of electric box. There are white wires twisted together and covered with wire nut. These are neutral wires. Connect timer-white wire to neutral wires. This will power the clock and display.
e) If your box does not have the white wires described in d), then connect timer-white wire to bare ground wire.
f) Turn power ON. Does display light up?
g) If display lights up, switch is wired correctly.
h) If display does not light up, then reverse timer-blue wire and timer-black wire shown in step b) and c).
Dec 02, 2010 | Zip Heaters Sylvania SA170 15 Amp Zip-Set...
MY DISH washer electric supply wires are cutdown and water pipe of dishwasher cutoff and i want its diagram input which is help full to connect the circut
Hi .. the electrical input to the dishwasher should be a 3 wire cable, black, white, green/bare. The connection is generally into a small metal box just behind the kick plate on the right side of the front of the washer. The cable gets run thru a cable connector to keep the presure off the connection. The connection is black to black, white to white, green/bare to a ground screw in the connection box.
Jun 21, 2010 | Smeg 24 in. DWF614SS Stainless Steel...
My dishwasher did not come with power cord. what kind of cord do it need and how do i connect the cord? On the new cord how will i know which one to connect to the white and black wire? The dishwasher is...
120 Volt 16 gauge, 3 wire power cord.
Brass Screw is Black, White Screw is is Common, Green is Ground....Try Home Deport for a cord. If no screws are on the dishwasher, use wire nuts and elec. tape
Jun 13, 2010 | Whirlpool 24 in. DU930PWP Built-in...
I put up a new ceiling fixure which is controlled by a wall switch. The light now won't swirch off....... I attached the fixture's 2 black wires to the black and the black with a white stripe wire in the...
One of those cables in the ceiling is a power cable from the electrical panel . the other is a wire to the wall switch. if you have a meter then you can connect them correctly .. BUT ,, basic connection would be .. the two black house wires together ,, then a white wire to each of the fan wires .. that puts the fan/light on the switch control.
To be totally correct the white power wire should connect to the white fan unit wire.
Nov 16, 2009 | Westwind Classic Hugger Polished Brass 52"...
I lost my manual and i can't fiqure out how to connect the dishwasher. i see the light that shows what to wash but the power buttom is not on
When you say connect, I assume you mean you are installing or reinstalling a dishwasher. With the power off, you always connect the black wire with the black wire on the dihswasher. This is the HOT or the LINE wire. The white wire hooks to the white which is the COMMON wire, and the bare copper wire connects to the green screw or green wire and is the GROUND. If you are using a pig tail (plug in connection) the common wire will usually have a line or series of lines going the length of the wire. Just be sure you identify the correct wire because a dishwasher will run with the hot and the common connected backwards which can create a dangerous situation if a short develops inside the dishwasher. Use wire nuts twisted on snugly and enclose all wiring connections in the connection box. Hope this helps! Ken
May 03, 2009 | GE Dishwashers
My frigidare diswasher is leaking from a left side black hose
Check the hose first - it could be split or damaged esprcially if it's old. Check all the clamps to be sure they are tight. Chack all connections to the dishwasher and drain spur under the sink. Check the drain trap fro any leaks.
Mar 27, 2009 | Frigidaire Dishwashers
Frigidare Gallery Pro Dishwasher Control Panel Power
It can be the problem with the transformer. Try replacing it with another one.
Dec 14, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
I have a kenmore dishwasher and it stopped in the middle of a cycle and water is in the bottom. No response from the dishwasher, plug is ok and not tripped. Is there a reset button or not?
When the dishwasher stops in mid cycle and there is no console lights illuminated, then more times than not the thermal fuse has gone out. The thermal fuse is located on the power supply board which is located inside of the console. you must remove the console in order to gain access to the power supply board. the thermal fuse is white and has to wires connected to it. a black wire and a black wire w/white stripe. disconnect the power at the panel box first, before you start. you then remove the old fuse, by "plucking it up" w/ a small flat head screw driver. then you remove the two wires connected to the fuse and place the new fuse in the spot ot the old fuse and place the wires on the new fuse. any order of placement will work. There is a fuse kit that will handle the electrical surges that may have cause the fuse burn out in the first place.
Apr 12, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
146 people viewed this question
Top Dishwashers Experts
