Question about RCA Televison & Video
Loud screeching noise when it powers on
Over the last month or so I had heard a noise coming from my tv faintly but you could not hear it over the volume unless you really focused in on it... today I turned the power on on the tv and its making a very loud screeching whining sound i shut the tv off and it continues for a couple of minutes and then stops... also the color is all messed up on the picture... if anyone could be of help that would be greatly appreciated.. thank you
  • drlfries Dec 31, 2008
    Thanks so much for your help. My husband is crazy and took the entire TV apart and found the part that was making the screeching noise but he didn't know what it was called. He brought the part to a TV repair place and it is the colorwheel. The guy at the shop told him that the RCA tv's have samsung parts inside. So he had the part replaced for $200 and is now going to put it all back together. I found a great site where someone explains step by step with pictures how to replace your own samsung colorwheel. If you would have someone come to check it out the whole thing would've cost like $500 or so. Here's the link in case anyone has the same problem and is handy and can do it themselves. Thanks! http://www.jangro.com/a/2006/07/24/samsu...
    Master:
  • 505 Answers
Sounds like picture bulbs maby %30 i think it may need to go in for a check up they can pin point the problem hope ive been somewhat helpful thanks viper
Posted on Dec 31, 2008
It wont turn on.
If the power light does not come on and it makes a screeching noise, most likely its broken. I would contact the manufacturor, in case some warranty left.
Jan 11, 2014 | Acer AL2216W LCD Monitor
Heard a pop when I turned on tv and now nothing
don't leave it on and have it looked at---most likely is if it uses a lamp that may be the problem but if not it may be in the power supply.
May 20, 2012 | Sony KDF-E55A20 55 in. LCD Television
Loud screeching noise upon starting
It is your serpentine belt slipping on one of the metal pulleys and the friction is causing the high pitch screech. The belt may need to be tightened or replaced, which is an easy fix.
Jul 28, 2010 | 2003 Chevrolet Monte Carlo
A loud buz slash humming noise that only goes away when the sound
If the installation is as bad by Foxtel as mine was, that is your problem. In my case a loop was created when the filter was left loose in the junction box which was resting against signal booster. Find the point where your Foxtel enters your property. Open the junction box. Check that none of the components are touching each other.
Apr 06, 2010 | Philips 47PFL5704D 47 in. LCD TV
Loud screeching noise coming from car after stops.
the screeching noise is most likely caused by a slipping belt or pully. transmission probably needs fluid and filter changed.
Jun 02, 2009 | 1990 Ford Tempo
98 gs300 loud screeching noise that last for about 5-10 seconds
The only four rotating items under the hood are
engine
power steering pump
A/C compressor
and smog emission pump.
==== I would check the fluid level on the power steering first. Check for pink fluid leak on the ground,
==== Check the A/C system with the wheel turn to one side and APPLY ALL LOADS.
Example: high beam on,A/C max,radio on and deforster on.
This will give you system a stress test.
All eyes on the pully and locate to part that generate the loud screeching noise.
My bet is on the power steering pump.
Please post more info on the comment window.
I will follow up on it.
Feb 12, 2009 | 1998 Lexus Gs 400
In the last month my plasma TV has developed a buzz that is really annoying as its the only thing i hear now. It can be heard sitting infront of the TV up to 5 metres away. It comes and goes but is there...
It could be the transformer, need to get it serviced. Nothing will happen but the noise will get louder and more annoying. Most of the time the transformers have a plastic plug to conceal the magnetics and the coil. The glue on the plastic loosens and can create the buzzing noise.
Aug 09, 2008 | Computers & Internet
Loud periodic buzzing
Are you sure this noise is not just the ice maker trying to cycle without water? If it is not turned off it will dry cycle every 15 min or so.
Jan 18, 2008 | Samsung RB2155 Bottom Freezer Refrigerator
Powers off by itself
Usually leaky power supply diode and two bad caps-----need service # and chassis # from sticker on back of set .....T.
Jan 22, 2007 | RCA 32V420T 32" TV
Televison & Video Logo
751 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
