Question about Health & Beauty
Replacing lithium batteries in bathroom scales
I have replaced the two batteries but cannot get rid of the 88:88 on the view panel. How can I get back to the blank screen
SOURCE: electronic bathroom scale lithium battery spent
I had a problem changing the battery too. I just couldn't get it out and was afraid of prying too hard because I might break it. So I called customer service to ask them (a bit extreme) but they basically just told me to take a small screwdriver (I used a hair pin) and pop it out. I tried again by pushing down on the opposite side instead of lifting and it popped right out. The battery is just a small electronic one like in a car's keyless entry controller.
Posted on Dec 10, 2008
r321567499
  • 74 Answers
SOURCE: taylor digital bathroom scale
This link allows you to trouble shoot directly with the company... I hope this helps. http://www.taylorusa.com/advantage/root/contact.html
Posted on Jan 07, 2009
SOURCE: Reset digital bathroom scales
I cannot reset my digital scale to lbs. it is a conair ww body mass scale
Posted on Oct 18, 2009
skaterkid307
  • 86 Answers
SOURCE: How can I fix the Taylor LIthium Scale?
take it to were you got it or instuctions show u
Posted on Feb 20, 2010
SOURCE: Taylor Lithium 7006 bathroom scale: The scale quit
It needs 2 batteries.
Posted on Sep 27, 2010
I need a manual for simply bathroom body analysing scale
Could someone tell me the battery needed for the Simply Bathroom body analysing scale - model 4528?
Thanks
Apr 16, 2012 | Health & Beauty
My scale showed Lo, no reading, then I replaced battery, now shows nothing, dead. What do I do next?
The Instruction Book for your scale can be found here:
http://www.taylorusa.com/media/IBs/7506_ib.pdf
Sounds like no power. Check for correct battery replacement; may need to verify that your replacement batteyr is still good.
Battery Replacement
1. Use 3 volt CR2032 lithium battery (as installed).
2. Open the battery compartment on the bottom of the scale.
3. Remove the old battery from the compartment.
4. Place the new battery with the "+" sign up into the battery compartment.
5. Replace the battery compartment cover.
Apr 23, 2011 | Taylor 7506 Glass Lithium Digital Bathroom...
7506 Glass digital lithium scale battery replacement. I need the battery no. please...
The lithium battery is a 3-Volt CR2032. The manual for the scale is available here: http://www.taylorusa.com/media/IBs/7506_ib.pdf . Additional information and a link to the manual is available here: http://www.taylorusa.com/weight-management/glass-electronic-scales/glass-lithium-electronic-scale.html .
I hope this helps.
Apr 19, 2011 | Taylor 7506 Glass Lithium Digital Bathroom...
I have a Thinner glass/brass round bathroom scale and I cannot find the battery location. I purchased this about 10 years ago from Frontgate but they couldn't help me. Can you?
I have a 10 year old Thinner bathroom scales also. Apparently the manufacturer designed it to make battery replacement hard so you'd buy a new scales. To replace the battery, if your unit is similar to mine, turn it over, remove all the screws and separate the top and bottom. You'll see the glass window that shows the weight. It is held in place by four tabs that are slightly twisted. Straighten them, lift the glass assembly clear without straining the wires, and turn it over to reveal the round black battery case. It is secured by three small screws and clear epoxy. Remove the epoxy with a knife blade, remove the screws, and separate the two halves of the case on one side being careful not to separate the other side where there is a metal connection piece. Using the knife tip, remove the CR2032 battery and replace it with a new one (available at Radio Shack or similar stores). Reassemble in reverse order; no need to replace epoxy. My scales worked fine after that.
Jan 09, 2011 | Conair WW81 Weight Watchers Body...
Changed the lithium battery 6 weeks ago it was
Remove the batteries and clean both ends of the batteries with a pencil eraser. Do the same with the contact points in the scale. This should help. Bathrooms are damp, you may want to set it elswhere for reliable use.
Jun 06, 2010 | Taylor Chrome & Glass Lithium Digital...
Looking fo battery for taylor lithium bathroom scale.
Varta - Piles Lithium - Bouton CR2032 3V - Non rechargeables ask your store made by varta
Mar 02, 2010 | Home
I can't find the battery number to replace my battery in my taylor 7321 bathroom scale. Is there a way to find out what battery to buy?
yes call the manufacutere or go to the store where you purchased it from and they can supply you with a the proper company and phone number
Jan 05, 2010 | Taylor 7321 400 Pound Lithium Scale
We have a Taylor 7542 Bathroom Scale. I need to
I called Taylor; the Model 7542 take a 3v CR2032 battery available at Walgreen's, CVS, WalMart, etc.
Feb 23, 2009 | Taylor & Digital Scale Lithium Scale
Taylor digital bathroom scale
Oct 15, 2008 | Health & Beauty
Health & Beauty Logo
348 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
