Question about Apple iPod 4th Generation MP3 Player
Ipod worked great until it needed charging now its locked up
It screen has darkened and it will not turn back on it's like it is frozen and won't unlock.you can barely see where it says connected but it is not moving and i have ejected it but it will not do anything HELP!!!
  • 342 Answers
Try resetting the iPod with it connected to your computer. It should case it to refresh and light up and start charging/connecting to your computer. If this does not resolve your issue, please do let me know :)
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
Posted on May 19, 2009
Nano ipod will not charge and battery is low and on lock and wont disengage! help please.thanks
Important: If your iPod is frozen or won't turn on, it may be because iPod is paused or the Hold switch is in the locked position. If so, a lock symbol appears on the screen. Slide the Hold switch to the unlocked position and check the screen.
To reset an iPod with a Click Wheel: . Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Jul 11, 2010 | Audio Players & Recorders
Screen frozen on slide to power off
Turn iPod touch off and turn it on again.
If the iPod will not turn off, try to reset it. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until either the Apple logo or battery symbol appears. If the battery symbol appears, continue to charge iPod touch until it is fully charged.
If this doesn't work, try restoring the iPod
Nov 18, 2009 | Apple iPod touch
I plugged in my i pod and came back a hour later and the screen was black and was frozen and none of the buttons would work
you will need to reset your ipod this will not delete songs. 1 Toggle the Hold switch on and off (slide it to HOLD and then back again).
2 Press and hold Menu and the Center button for at least 6 seconds, until the
Apple logo appears.
If iPod nano won’t turn on or respond
â Make sure the Hold switch isn’t set to HOLD.
â The iPod nano battery might need to be recharged. Connect iPod nano to your
computer or to an Apple USB Power Adapter and let the battery recharge. Look for
the lightning bolt icon on the iPod nano screen to verify that iPod nano is receiving
a charge.
To charge the battery, connect iPod nano to a USB 2.0 port on your computer.
Oct 21, 2009 | Apple iPod nano MP3 Player
Screen frozen and slid bar is locked
Hold the lock and home button until the apple sign shows up then start over.Your welcomed
Sep 02, 2009 | Apple iPod touch
Hi. I plugged in my iPod nano 4th generation to charge it. It opened iTunes as it usually does and I could see my iPod in my device list. I left it to charge as normal. I came back a while later and my...
Try doing this: Toggle the hold switch and put it back in the off position. Then press and hold the center button and the menu button simultaneously for ten seconds and the apple symbol should come up on the screen. Then it should work like normal. Hope this helps!
Mar 22, 2009 | Apple iPod nano
Ipod nano 4th generation 8gb purple wont turn off
the ipod turn itself of when inactiv normaly after 20 to 40 sec
Jan 28, 2009 | Apple iPod nano
Frozen screen
First, make sure the lock slider is in the proper position.  I know, obvious, but you'd be surprised how often this happens.
Next, slide the lock slider to locked and then back.  Then press and hold the Menu and Select (center) button for 6-8 seconds.  Try a couple times if it doesn't work the first time.  The ipod should reset and work.
If that didn't work, you can reset your ipod.  But first, try connecting the ipod to your computer and see if it goes into sync mode. If so, wait for iTunes to load and then eject your ipod in iTunes and see if it works again.
To reset your ipod, slide the lock slider to locked and then back.  Next hold the Play/Pause Button and the Menu button for 6-8 seconds.  You may have to try this a couple times.  The ipod should reset.
The last thing to do is to let your ipod discharge completely by leaving it at the frozen screen.  Once your ipod is out of battery, reconnect it to you computer or a power adapter and let it charge.  Then try to access it again or repeat the steps above.
Nick
Jan 22, 2009 | Apple iPod nano
Ipod nano frozen
there are 2 basic ways the harder one is:
leave it on all night until it runs out of power then charge it and it should work
The easy way:
hold the menu and select button down for a while until the apple logo apears, if it dosnt work follow the harder way
Nov 28, 2008 | Apple iPod nano 3rd Generation
Frozen screen and different format
Hold the Menu and Center Button until the screen goes blank.
you will then see the apple logo and you should be set.
Nov 29, 2007 | Apple iPod nano
Troubleshoot nano
this is charly187 i solved my frozen problem with out loosing anything on the ipod nano just hold the center button and the menu button together for 10 seconds and it should reset.
Nov 06, 2007 | Apple iPod nano
Apple iPod 4th Generation MP3 Player Logo
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
