Hello, my dryer will not start, I checked the voltage at the incoming terminal, and it was correct. All of the thermal safety's have continuity through them. The light comes on in the dryer, and when I push the door switch it goes out. The timer does work, if you set it it begins to count down. The lint trap is clean and the belt seems good. When I look at the back of the start button, I have two blue wires, one pink/black wire, and a black wire to the buzzer. When I turn on the timmer, I get 120V at the blue wire that connects the switch to the timmer. When I push the start button, I get 120V to the blue wire that connects to the motor, and I still have it at the blue wire that connects to the timmer. I never get 120V at the pink/black wire terminal. Could the start switch be bad? or is it the motor? Thank You
SOURCE: Will not start; makes no noise
check the humidity sensor this will prevent the motor from starting
SOURCE: Dryer will not turn on
Make sure you have power to the unit. Check the start switch as well. Hope this helps!
SOURCE: Dryer won't start, checked thermal fuses and start switch.
It sounds like you have been through most of the areas too look.
One thing to make sure of is that you have a full 240 volts. An electric dryer can measure 120 volts. from L1 to common and 120 volts from L2 to common but you also need to make sure you have 240 volts from L1 to L2 on the meter, one leg of the breaker or one of the two fuses could be blown.
If this is alright you only have a couple components left. The timer contacts and the drive motor. Either of these could be causing the issue.
To check the motor with the power disconnected check for continuity between switch terminal 5 and the Green(black) wire on the motor. If you have no continuity the motor is bad. Check for continuity between the terminal 6 and the yellow wire on the motor, if you have no continuity there the motor is bad. Check for continuity between terminal 1 and 2 on the motor if you you do not have continuity the motor is bad.
The timer should have continuity between the Yellow and Grey wire terminals for the motor to start.
I hope this helps
Testimonial: "Great advice, thank you for your help."
SOURCE: Dryer was working perfectly then
check the thermal switch it is located on the top of the heat chamber in the back of the mach. you lift the top of the dryer and it will be on top in the back right there will be to the thermal swith and the high limit thermostat they have to be replace as a set
SOURCE: Maytag Gas Dryer has power
I had the same problem. Here's a quick test you need to do. It will take two individuals (unless you're extremely talented) Open the dryer door and push in the door switch... and hold it in. Have the other person push on (and hold) the start button on the console. At that same time everyone is pushing the switches take a free hand and reach into the dryer and try to spin it. Sometimes just a little push (assistance) is all it takes and..... bingo the dryer starts up! If that's the case... your motor is on its way out or it's gone. Usually due to the bearings on the motor being badly worn.
