Question about Xerox XG-91D 19" LCD Monitor
When I turn on the monitor it lights up but...
If I push the menu button or one of the navigation buttons the back light goes out and the blue light for the power flashes. That is all I know. I plan on opening it up and trying to diagnose it myself but I do not know anything about these monitors so it will be a crap shoot. if you could help me with any ideas or a solution I would appreciate it.
    Problem Solver:
  • 3 Answers
I've had similar problems with mine and I did send it back to Zerox for repair while I took vacation in Thailand. They sent it back with no notice as to what was wrong. It has been working fine since Feb 07 I called them today and ask what they did to my unit. The reply was replaced an "inverter". Does this make sense Silverdragon? Being from New Zealand do you have an interest in sailing. You might visit my boat design website www.RunningTideYachts.com
Posted on Sep 24, 2007
  • Xerox Master
  • 12,061 Answers
I have found usually it is in the Power Section of the unit. Usually in the area of the main Heatsink and it is often the Electrolytic Capacitors.. not always but Often.. replacing thses on Spec is what I do anyway and often thats the fix.. Or otherwise simply "Shotgun" (replace all regardless) of the Discrete components on the Power Board with same or better components. Of course check the connections and Backlight etc B4 doing any of this.
Posted on Aug 01, 2007
RESET DELL MONITOR E1709WC
Instructions
    • 1 Push the "Menu" button on the front or side of your Dell monitor. The button's icon resembles a miniature monitor. This will open the main monitor setting menu. Push the button again to exit the main menu and open the OSD menu.
    • 2 Push the "Down Arrow" button on the monitor to scroll through the OSD menu. Stop at "Factory Reset." Push the "Menu" button to open the factory reset menu.
    • 3 Push the "Down Arrow" button to select "Position Settings Only" to reset the monitor's horizontal and vertical screen settings. Press the "Menu" button to activate the setting changes.
    • 4 Push the "Down Arrow" button to select "Color Settings Only" to reset the monitor's red, blue and green color settings. Press the "Menu" button to activate the setting changes.
    • 5 Push the "Down Arrow" button to select "All Settings" to restore the monitor to its original factory settings. Press the "Menu" button to activate the setting changes.
    • 6 Push the "Up Arrow" button to select "Exit" to leave the monitor reset menu. Press the "Menu" button to exit the OSD menu. Push the "Menu" button again to exit the main settings menu.
Aug 02, 2012 | Dell Computers & Internet
Why does my HP vs17 monitor screen keep going to blank black screen like it turned off but did'nt.....blue power button light is still on? Everything is running but no picture.....keeps happening everytime...
this old monitor has 2 issues.
1: it has CCFL tubes that love to burn out (backlamps)
most this old are long go, yell,dim.,blinking or DEAD.
2: push the menu button on front of mon. turn off power saver.
3: if the PC goes to sleep, or hibernete mode (parked)
then that is 100% normal
if you dont like feature then go to windows control panel
click power, ICON and turn off all monitor sleep /hibernate modes.
that assumes windows, no OS stated.
if the lamps are dead,
use flash light pointed to sceen, see data. ? bingo for bad CCFT tubes.
as seen here
http://www.pcdied.com/monitors.html#flashlighttest
Jan 12, 2018 | HP Vs17 17" LCD Flat Panel Monitor
My LG e2350 monitor won't turn on. When I push on the power button, nothing happens except that one of the light on the left lights up.
there's a button on the far left, that which when you press should light up the power LED. i know it's weird, but it does that.
just hold that for a period of i don't know how long, maybe 10 seconds til the power LED goes off. wait a while, then press the power button again. that worked for my friend's monitor that had teh exact same problem as yours.
you probably fiddled with the menu buttons before this. and pressed the "input" setting.
Dec 19, 2010 | LG Flatron L1515S 15" LCD Monitor
My monotor its all black but u can
This should be an (LCD) screen. They are the ones that usually have this kind of problem. You will need to take it to have it checked if the problem is the VGA signal cable leading to the monitor. They will check if it is properly connected or has gone bad. It is very unlikely that the screen is bad. When this VGA signal cable goes bad it could result in a totally blank screen.
Sep 13, 2009 | Dell Computers & Internet
Dell E171FP Monitor goes black after 2 secs
Hi, I don't think the problem is with your monitor. Your monitor sounds like it's doing exactly what it's supposed to do. The monitor is supposed to turn off if there's no cable attached, which means there's no signal input. When the screen goes black, does the power light stay on and turn orange? or does it go off as well? I would recommend that you lower your screen resolution to 1280x1024 or lower in the Display Properties window, then remove your primary monitor, and connect the monitor to your desktop computer. You should see it light up when connected. The monitor auto-senses when there's a computer attached to the cable and when there's a signal. If it doesn't see a signal, it goes black to save power.
Jun 17, 2009 | Dell E171FP 17" Flat Panel LCD Monitor
Side Buttons - Not Responding (wrong input?)
These buttons can stick, when you press the buttons do they click
if not then it is stuck in.
Jan 27, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
3yr old got ahold of monitor
ok, get to the event where you get this to happen "...then turn it back on the monitor does come on normally...", but just after power-up, press the F8 key to go to safe mode. If nothing visible, press ENTER anyway...get to safe mode yet?
Oct 27, 2007 | Computers & Internet
Blueish screen
Follow these steps to solve the problem... Make sure that the moniter power button is off. Unplug monitor from mains ( the auto exit button should flash red after about five seconds and you hear a popping sound.) plug monitor back in mains. hold down + and - on the monitor now hold down power button on monitor let go of power when power button when the green led lights up let go of + and - buttons wait a few seconds and press menu, a hidden menu will appear in the top right use the + and - buttons to move the highlighted option over the auto colour option in the menu push the menu button.
Jun 08, 2007 | iiyama ProLite E434S 17" LCD Monitor
Xerox XG-91D 19" LCD Monitor Logo
110 people viewed this question
Top Xerox Computers & Internet Experts
Aditya Agarwal
saurav777
Level 1 Expert
Jim LeVerso - IT...
Jim LeVerso - IT...
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
