Question about TTGI SUPER FLOWER 520W quad fan switching power supply (TTGI520QUAD) Power Supply
Using TTGI 520W 20 PIN Power supply with 24 PIN Motherboard
I have a Super Flower TTGI 520w 20 PIN power supply that I would like to convert to a 24 PIN Motherboard.
  • xsandman_02 Jan 01, 2009
    I must have read your mind. Already did it!
  • 341 Answers
Here is a adaptor for 2 bucks.Hope this helps.
Posted on Dec 31, 2008
520w power supply fuse
I recommend replacing the power supply at the same rating, It is brand new with full warranty. Changing the supply fuse will involve replacement of semiconductors and perhaps additional parts. Power Supplies are so cheap it is the best solution.
Mar 10, 2012 | Dell OptiPlex 520 PC Desktop
Need a new power supply for a soyo mother board Crown model fp-
All you need to know is if your motherboard has a 24-pin or 20-pin power connector. You can just count the pins if you don't know. There connector is located on the motherboard. It looks like this: moondogwst75_3.jpg
So if it's a 24-pin, order a 24-pin power supply. If it's 20-pin, order 20-pin. Hope this helps!
Aug 28, 2011 | Computers & Internet
My motherboard takes this: 1 x 8-pin ATX 12V power connector My PSU (power supply) only has the 4-pin 12V power connector. Can someone please point me to a product that will convert the 4-pin to an...
Hi Andrew.
Just had a look arouund on Amazon, and if you do a search for
EPS 8-Pin Power to ATX 4-Pin Cable
There are a couple that turn up.
Hope this helps.
Apr 16, 2011 | Computers & Internet
about three years ago i built a computer it was mxtx 24 pin board and i had a atx20 pin power supply i bought an adapter to convert the atx ps to a matx 24 pin and had this problem the cpu kept restarting after hours of problem shooting i narrowed it down to the power supply i went out and bought a 24 pin ps instaed of trying to convert 20 to 24 problem was solverd what im trying to say is check your power supply disconnect from board and reseat it see if that helps or try another power supply
Aug 28, 2010 | Intel D945GCCR Motherboard
Replaced a bad power supply and now won't pass POST.
Power supplies are one of the most common failures for computers but as you have found they are also very easy to replace and a nominal cost.
I probably average 4 power supplies a week on my bench and always do as you did and suggest to clients to get a higher rated supply.
Jul 14, 2010 | Syntax SV266A SKA KT266A Motherboard
My computer won't start. Power supply (ttgi 450ss) has a blinking green light and the power supply fan starts when plugged in. Motherboard (asus m2npv-vm) has a green light illuminated between the pci...
See if you plugged in the 4 pin power connector on the motherboard besides the main power connection on the power supply (usually black colored and its a plastic 4 pin connector)
Try another power supply if all else fails. If new power supply does not work with this unit then its a motherboard which is blown and motherboard needs replacing.
Hope this helps
Mar 16, 2010 | TTGI SUPER FLOWER 450W quad fan switching...
How to use ATX-250-12z SMPS with 24 pin
Chances are that 250w power supply is not going to power a motherboard with a 24 pin connector, but you can try.
You will need to purchase a 20 to 24 pin adapter cable.
Google Search Terms: 20 to 24 pin adapter
Oct 27, 2009 | Gateway Emachine Bestec ATX-250-12E PS...
Atrix 9006-C4 Black Midi Case 520W fitting for lcd display
There will be "headers" on the motherboard for some case fans. Look for 2/3 pin connections on the board marked "sysfn" or something similar. Any other fans you will have to fit to a spare Molex power connector from the power supply ... you can buy 2 or 3 way "splitter" cables to give you more power connections from one Molex for this purpose. BTW make sure you connect the cpu fan to the "cpu fn" header !!!!! That one is rather important :-P
Dec 20, 2008 | Atrix (CSCI-C8001-C43) ATX Mid-Tower Case
Problems with P35neo2
Check your M/board manual for setup if it should have an 8 pin power connector you will need a power supply to suit it if you continue trying without it you could also be up for a new motherboard and CPU
Aug 05, 2008 | Super Flower Computer Super Flower Cable...
Power Supply Question
hi you can buy a new 20 pin to 24 pin adaptor from ebay for a few pounds, or most new power supplys do have a 24 pin slot for your motherboard power let me know if you need anymore help regards steve,
Mar 18, 2007 | ASUS A8N32-SLI Deluxe Motherboard
TTGI SUPER FLOWER 520W quad fan switching power supply (TTGI520QUAD) Power Supply Logo
170 people viewed this question
Top TTGI Computers & Internet Experts
David Payne
David Payne
Are you a TTGI Computer and Internet Expert? Answer questions, earn points and help others
