Question about Cobra 19 DX IV CB Radio
Receiving fine but transmitting bad??
Me and one of my buddies bought one of these from walmart, we wanted something cheap when we go off roading. we got them all hooked up and he came by to see if everything is working ok. when i transmit it is crystal clear on his but when he transmits it doesnt sound real clear, it does have any back ground noise and you can understand what people are saying if you listen close, but his sounds like your on the phone.we havent tuned our antennas & i have tried searching to see what effects and out of tune antenna can have but just got stuff on how to tune it with a meter. so is my cb messed up or is his? is it the out of tune antenna causing it, but his is clear with no tune eithe? what could it be? thanks and sorry for the long story
  • 1 more comment
  • tdill49 Mar 20, 2009
    I bought a new 19 also with the same TX problem
    Turns out it was not new.It had been monkeyed with.
    If nothing else take the lid off and check if all the wax seals are still on the coils.
    Check if you can tell if CT1 ( adj trimmer cap in pll circuit ) has been turned.
    That was the problem with mine.
    PS. Don't expect a lot anyway.
  • Dutyacx May 11, 2010
    Are both transceivers exacty the same ?
    If so, try swapping the mikes.
    A bad VSWR could be causing this effect too, also too close by as proposed by s60six, but by swapping the mikes first can give you an answer. If not, try swapping the whole transceivers and hear what happens.
    The effect however sounds really like a mike issue.
  • s60six May 11, 2010
    if you have rf gain on your radio try adjusting it up and down,you may be too close to each other,
    Guru:
  • 200 Answers
First off, that radio will not transmit very well anyways.  but for just off roading it should suffice.  You really should adjust your antenna's both of you.  First off this is almost definitely the problem if you can recieve but not send.  Also if you use the radio without a properly adjusted antenna it will destroy the radio over time, sometimes instantly.  pick up a cheap SWR meter and follow these steps: Plug the SWR meter into the radio, and the antenna. Start on channel 1, the meter should have a switch with 2 settings, one for adjustments and one for reading.  Key up (hold down talk button on mic) with the switch in adjust mode and adjust the knob until it reaches the adjustment marker. flip the switch to reading and key up again. Your goal is to get this reading as close to 1.1 as possible, anything above a 2.0 will damage your radio. if the reading is within range repeat for channels 20 and 40. good luck!
Posted on Jan 22, 2009
My radio is not transmitting what could be wrong
When the batteries are reaching the end of their life or in need of charging the first thing that is likely to happen is that the unit will be weak when transmitting while receiving just fine. This is because it takes a lot more power from the batteries to transmit than to receive. Try a new set of batteries or if rechargeable then try charging the unit. With regard to regular batteries, make sure your batteries say "alkaline" on them somewhere since they will last much longer and also are more likely not to leak inside which can ruin your radio. Ignore labels on batteries that read "super heavy duty" or other such nonsense. Look for one and only one word "alkaline" on them and buy any brand you want to since cheap or expensive they are basically the same. Don't waste your money or risk your radio by using anything but alkaline batteries.
Hope this helps.
Dec 08, 2014 | Radio Communications
Transmitting and Receiving Signals
Modulation being muffled could be the mic or it could be an adjustment in the unit.
May 21, 2013 | Cobra 19 DX IV CB Radio
My remote wont work for my alarm and i need to know how to reprogram my remot
take it to a dealer, have them test the remote to make sure it is transmitting. if not replace the battery, they are cheap at walmart. if the remote is transmitting the dealer can program the car's receiver to recognize the transmitter. costs about 15 bucks unless you have it done in conjunction with some other service then it can be free.
May 05, 2011 | Chevrolet Silverado 2500 Cars & Trucks
In dec. of last year i bought a 19 lcd hdtv and now something happend to it it doesnt want to turn on it just makes a little noise. do i take it back to walmart and return it?
It depends on if you bought an extended warranty at Walmart or not. If you did, see the extended warranty information for the appropriate contact information. Otherwise you will need to contact the manufacturer (I hope your TV had a 1 year warranty).
I hope this helps.
(most electronics have only a 30 day return at the store; some stores have a shorter policy.)
Aug 20, 2010 | Audio Players & Recorders
2002 Honda GL 1800 Gold Wing CB radio receives but won't transmit
Hi, Ohenry428 for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
New CB Radio in 02 GL1800 Won Transmit
cb radio no transmit GL1800 Information Questions goldwingdocs com
Honda GL1800 Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
http://goldwingchrome.com/Manuals/GL1800/Honda%20Goldwing%20GL1800%202003%20Owners%20Manual.pdf
Jun 20, 2010 | 2002 Honda GL 1800 Gold Wing
Denali GMC 700C Women's road bike wrong tires!!!
Can you explain why you think the tires are too big? Do they NOT fit the rims? What condition was this bike in when you bought it? If the brake pads line up with the rims then the wheels are correctly sized for the frame.
May 06, 2010 | GMC Denali 700cc Women's Road Bicycle
When i click the mic i get no transmit
If the receive works ok,sounds like a mic
problem,try another mic if you can find a
buddy who has a Cobra that may let you
try it most all Cobra mic will work but not all.
Good Luck
Sep 08, 2009 | Cobra 29 LTD CB Radio
Cobra 29 LTD Classic not transmitting or receiving
ant. light should only come on if you have a high vswr a bad thing did you check that cb/pa switch is set to cb check your swr this is not a good place to mount ant. as it is close to metal of back of cab
Dec 20, 2008 | Cobra 29 LTD CB Radio
Keys up and everything dims and does not transmit.
Moving the volume/on/off knob to make the radio work again is interesting and a good clue. On most CB's, the pot is probably soldered directly to the printed ciruit board.
It's possible that there is a bad solder joint to the power connections on the pot that turn the radio on & off. If the solder joint is bad, it can still make a connection but the connection will have added resistance in line. The on/off switch can be bad too.
Switches arc each time they are used and over time, the contacts become pitted and make poor connection.
I had a stereo receiver where the tuner lights flickered and there was electrical noise in the receiver. It turned out to be a bad on/off switch.
This resistance may be low enough not to affect the radio when in the receive mode but when you transmit and draw more current that resistance will be noticable during transmit.
The fact that you rotate or move the volume/on/off knob and the radio starts working again, tells me that there may be a bad connection in the radio.
A cheap thing you can try is spraying some electrical contact cleaner into the pot and rotate the pot back & forth several times and turn the switch on & off several times to clean it.
Please let me know if I can be of further assistance to you.
- Jim
Feb 08, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
E68 error
E68: Hard Drive Error
Sorry to say you got a bad hard  drive. Call MS or take the system back to walmart for a new 1 because I dont think they will give you a new hard drive. Who knows they might, call and ask!
Oct 12, 2007 | Microsoft Xbox 360 Console
Cobra 19 DX IV CB Radio Logo
538 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
