I replaced the flasher, and the turn signal switch. The bulbs are also good. The hazards work perfect. When i pull the nob to turn on the lights the turn signal indicators in the guage cluster stay lit up, and when i flip the signal switch to a certain direction that directional indicator light will just shut off. Also when its flipped in a direction, that corresponding light will stay lit up on the front of the truck, and the rear light wont do anything.
SOURCE: 87 Jeep Comanche, turn signal issues
You will find that there are two flasher units on the fuse panel. Turn on the four ways to identify which flasher serves that circuit. Then, move the flasher to the other position (where the signal flasher is) Your directionals should then work. You then can buy another flasher and install it when you have a chance, putting it in the 4 way position. The 4 ways get used so infrequently, you always have a reliable spare signal flasher there!
SOURCE: 1998 wrangler turn signal/brake light short
your socket may not be grounded properly, I have seen this before, and the simplest way to fix is change the socket with a new one.Not another used one it may also be bad.
SOURCE: left rear turn signal and brake light dont work
You have a broken wire to the turn/brake light portion of the light as they use the same wire. Or where the plug goes into the light assy could be bad. Torsion mount lights are horrible and you should think about replacing with a universal light that you can wire direct.
SOURCE: my jeep wrangler hazard lights, turn signals and
replace the flashers, check fuse, check that the switch is grounded properly
SOURCE: turn signals hazards flasher don't work jeep
I NEED TO LOCATE THE SWITCH WHERE IS IT ?
MY INDICATORS NOR HAZARD LIGHTS ARE WORKING I DONT KNOW WHAT IS WRONG WITH IT CHANGED BULBS BUT NOTHIGN THEY ALL WENT OUT AT THE SAME TIME
SO THERE MUST BE A RELAY SWITCH SOMEWHER BUT DONT KNOW WHERE ?
THANKS FOR HELPING
Hazard and turn signals usually use separate flashers, switch the flashers to see if turn signals work and hazards don't, if so replace the flasher
you need to replace the blinker flasher unit
it is different from the hazard unit
they cost about 4 bucks
the flasher unit is the big round thing in the fuse panel in the dashboard
