Question about Polaroid FLM-3732 Television
No signal and blue screen
Ok i turn the tv on and i have to wait like 5 seconds and then the blue screen apairs and then i try to change the channels and keeps blinking and some channels said no signal and blue screen.
  • Jyackle5
    Jyackle5 May 11, 2010
    Are you on the right input to watch the tv.
    Problem Solver:
  • 14 Answers
Hello
i think you might have a blue screen of death on your tv
--full str pka
Posted on Dec 31, 2008
How do I get Amazon Fire TV resolution set so I get more than a blue screen?
Select the input channel for your Fire TV - Turn on your TV and select the input channel for the HDMI port you used to connect your Fire TV. You should then see a loading screen with the Amazon Fire TV logo 4.
Jul 04, 2017 | TV Box Televison & Video
Why does my LCD HDTV go to a blue screen when changing channels
if using a box it may be normal but not nice, I would suspect the set is a bit slow reacting to signal change. I remember some nasty JVC sets that when going up or down a channel the screen would blank for about two seconds and come on, normal since all those had that feature(no channel surfing)>
Sep 03, 2012 | Vizio 42 in. LCD TV
Screen has gone to blue screen.....
OK A Blue screen, indicate that there is, or the TV "Thinks" there is NO SIGNAL. Please Check your Antenna Connection. Unplug the TV, for 5 mins or so. You MUST prove either the TV or it's "Signal Source" the Antenna. Try the antenna on another TV, if possible, try another antenna,on the TV, Try feeding in a signal via the EXTERNAL inputs. IF ALL Inputs are proved OK, and the TV, still will NOT display any signal, then it would appear that you may have a "Tuner" fault, or some other underlying condition, that affects the reception. In my professional opinion, in that case is to get the unit looked at by a Toshiba, recommended service center, VERY IMPORTANT to do that. Ask for a "Quote" from that service center, and go from there.
Apr 16, 2010 | Toshiba 37AV500U 37 in. LCD TV
Rca 20F514TD blue screen
What to do if you have an all snowy picture (blue screen or the TV displays unusable signal-no signal or no sync)
1 – If you are using a digital cable box or satellite receiver (make sure it’s on) and be sure your TV is set for either CH3 or CH4 (which ever you usually view it on). If you usually view it through video inputs (video1 or 2 etc.) make sure the appropriate input is selected.
If you still don’t get a signal see if you get picture using the DVD or VCR (if available) if you do than plug the satellite or Dig. Box temporarily into the place of the DVD (unplug DVD) you may have to use some A/V cables (RCA yel./red/wht like the ones on the DVD) to hook to the tv from the sat./dig. box. If you get a signal then the sat./dig box is ok. If not the Sat./dig box is not sending a signal and is either defective or needs to be rebooted (unplug wait 5 min try again).
2 – If you are using standard cable or antenna (source) if possible check that the source is good by connecting to another TV. Otherwise try running the source into a VCR and then out to the TV using video inputs (RCA yel./red/wht like the ones on the DVD) and then selecting the appropriate input. Try seeing if the VCR plays using standard CH3 (or CH4)
If the VCR plays on video input but not when connected to CH3 (CH4) then the tuner of the TV may be defective – see if you can use the VCR to change channel using the VCR remote.
Be sure to vote/rate me if this helped Thanks!
Nov 05, 2009 | RCA 20F514TD 20" TV
Digital channels have stopped working, only blue screen!
Try resetting the TV:
  1. Switch on TV and switch to any analogue channel.
  2. On the TV: Press and hold the MENU button.
  3. Menu screen will appear on the display.
  4. Do not release the MENU until the menu screen disappears.
  5. TV will go blank for about 60 seconds and then display initial set up screen.
  6. Follow the on-screen prompts to re-tune the TV.
If this does not work then the problem is likely to be a loose ribbon cable or main small signals board inside the TV.
May 17, 2009 | Philips 37PFL5332D 37 in. LCD Television
26PFL5520D/50 DVT PROBLEM
If the lines across the screen are made up of coloured blocks, then the problem is likely to be a weak signal.
Digital channels are broadcast in groups called multiplexes. Sometimes one multiplex may have a weaker signal than others, and so you experience problems with up to 6 channels when all others are ok.
If it is only one or a few channels then just wait and see what happens, because it may be transmitter works.
If you have problems with all channels it could be a connection or antenna problem.
If the lines are just straight lines, then try resetting the TV as follows:
Switch on the TV
Press and hold the menu button on the side of the set. The settings menu will appear. Hold until the menu disappears again.
When you release the button, the TV will take up to about 90 seconds and then reset.
The TV will then show the original screen when the TV was new.
Press ok when shown.
Set language and country settings.
Move down the list and press ok to re-install all channels.
Feb 22, 2008 | Philips 26PF5521D 26 in. HD-Ready LCD...
Vcr and tv copy
Are you sure the VCR is getting your channel 5 signal? The TV when on ch 3 is seeing whatever the vcr is putting out.
Jan 01, 2008 | Philips Magnavox 20MT133S 20" TV
JVC AV27020
ok,i'm sure your tuner is defective,what you will do is try to resolder the tuner if not effective replace it with a new one.blue screen in your tv means that your blue back setting is on,and couldn't pick up a signal
Oct 12, 2007 | JVC AV-27020 TV
Apex 32" TV - Blue Screen & Channels keeping running/changing
blue screen indicares that there is a problem in blue cathode circuit. please check 1 blue video output supply. 2 blue video ckt defective 3 signal from chroma ic to blue cathode missing. 4 loose connector 5 crt base loose. 6 chroma ic defective. I think sound will be ok .
Sep 22, 2007 | Apex Digital PF3230 32" TV
Tv monitor turns blue during forward or reverse vcr search
On some TV's the screen will go blue if there is not a strong, solid video signal present. This is to prevent the showing of very snowy or all snow channels, or garbled, mixed-up external video signals. This is normal. On some VCR's the video signal changes when the FF or REW search feature is used, and this could trigger the TV to go to blue screen. The only way around this if you can enter the TV's menu and turn off the blue screen feature.
Jun 23, 2007 | Panasonic PV-V4020 VHS VCR
Televison & Video Logo
1,448 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
