Question about Sport & Outdoor - Others
My ski went side ways when going down the trail
Its an old 1985 sp formula and the ty rod looks fine the left ski works fine and the right ski wont turn when iu try to turn it it only does it by its self and it will go all the way back words does any one have any idea what could be wrong with it ??? thanks
The ty rod is probably broke or disconnected from the steering colum inside the hood.
Posted on Dec 31, 2008
I have a1998 skidoo 500 grandtouring handles horrible all over the trail. Darts all over. Ski adjustment? Suspension?
first check that your scags are good or new , now look at alinement of skis ,they should have a little toe in when looking from front of machine, if there strighr a head that will cause drifting left and right because skis get cought in ruts from other machines and causing pulling.
,also look for worn tie rod ends, or linkage from steering
.good luck hope you have fun out there .
Woody
Feb 15, 2015 | Cars & Trucks
How do I get rid of the trail card lock message that pops up on the screen when I turn my camera on ?
on the SD card on the left side of the card is a tiny switch,make sure it is pushed all the way up towards the contacts
Oct 27, 2014 | Moultrie Game Spy Mini M-80XD Infrared...
99 ford taurus rear tires wearing onthe inside.how do i fix
It sound like the Camber is off in the rear. Did you have an alignment done after the new struts wear installed?
Jan 03, 2013 | 1999 Ford Taurus
Cannot get 5th and reverse gear. Feels like neutral. 1, 2, 3 and 4 work fine.
the linkage is loose or poping out! check to c if trans is tightend down
Aug 22, 2012 | 1995 Dodge Neon
There is a lot of play in the front skis on our 2005 arctic cat 600 M7. So when you are crusing on a trail, feels like you are out of control and throws you all over. Any suggestions? My husband has been...
Assuming all the steering linkages and bushings are in good order you need to adjust your toe in. If you have a camber adjustment check that first. If you remove the skis and run a metal rod through the ski on on side it should pass just under the the ski mount hole on the other side (about 5 degrees). The degree angle can vary from model to model. After you set the camber on one side then set the camber on the other side. Now adjust ski angle. The front of the skis should be toed out 1/8 to 1/4 of an inch.
Jan 17, 2010 | Interactive Toy Concepts Crossfire Arctic...
Clutch push rod broke !!!
Chances are the prior owner installed some aftermarket springs that are too strong. This puts extra pressure on the push rod. Just pull the left and right cover of then remove the clutch assembly. put the new rod in from the left side then re-mount the left cover. Put the clutch back on then the right cover. The parts book shows a two piece push rod assembly. I wonder if a hardware store rod was installed because the factory rods are near impossible to find. The substitute rod probably couldn't handle the pressure and heat.
If not found elsewhere, google motorcycle salvage suzuki and see if you can find a used rod set.
Sep 22, 2009 | 1985 Suzuki GSX-R 750 F
1996 Lincoln Continental inflated up al the way, wont deflate.
check your leveling unit that attaches to the trailing arm, see if the rod is still attached if not unit may be bad
Jun 26, 2009 | 2007 Lincoln Continental
Garage door won't stay closed
Check the down limit:
 If the light bulb(s) on your operator are on the front and/or back, the limit adjustment screw is on the left side of the operator (looking from the back of the operator and facing  the garage door).. If the lights are on the sides of the operator then the limit adjustment screw is on the left side (looking from the back of the operator and facing  the garage door)
Jan 03, 2009 | Electrical Supplies
My ski went side ways going down the trail any i dea what could be wrong with it
It was on the wrong boot. Just switch these and you will be fine.
Jan 01, 2009 | Sport & Outdoor - Others
Its a 1985 chev 350, approx 160 hp.
remove the intake most of the time it wont go past the galley but you cant ussally get it out through the small holes they come through
Jun 08, 2008 | 1983 Chevrolet Silverado
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
