Question about Mitsubishi WS-55805 55" Rear Projection Television
Adding external speakers
I have a Mitsubishi HD 1080.  I wanted to connect external speakers to the unit, but when I did, nothing happened.  No sound from the speakers I connected.   Is there something I am doing wrong?  What is it that I need to do or need to have in order to make these speakers work.
  • calfrend Dec 31, 2008
    Thank you for the information which you provided regarding my wanting to connect external speakers to my televison.  Thanks to you I will now have an increased movie watching experience, with all the sounds.  Thanks again
    Genius:
  • 1,199 Answers
I think you will need to run the tv audio outputs out to an amp (inputs) and have the speakers connected to the amp! the TV does not have enough power to make the speakers work! but will send the signel out to the amp and in turn power the speakers!
If this answer helps Please rate my answer and help keep this site free!
Posted on Dec 31, 2008
My mitsubishi medallion hd 1080 doesn't show content from component cable
Some of the older Mitsubishi with HD 1080 have only one component input for HD---it is marked on rear as DTV----also a model number may allow me to give another suggestion--Some of these sets (ws, wt, vs models) will on occasion lock out or disable the input/s.
Depending on model number most also have 3 hidden menus---one is the option menu----it allows with the Mitsubishi remote via a 4 digit number (by model number) to enter there and do a hard reset of the set----sets every setting back to factory original---seen it "cure" all kinds of odd problems from missing rear inputs, no sound, odd video issues---you name it.
Get me the model number and I will see if can find the code for yours--you can also try hooking first direct a 1080 blue ray or Dvd if you want to see if the input is active or not first.
Apr 14, 2012 | Televison & Video
Can i cannoct external speakers to my Logik L22DVDB11
THANK YOU EVERYONE!! THE SPEAKERS ARE ****! they fell from just a tiny height aswell#!!! ive just added on external speakers to it using a aux cable sound quality is much better too!!!
Jan 19, 2012 | Televison & Video
I have a Mitsubishi HD 1080 55
Your unit has some sort of Thermal problem either with the PSU fault, or a thermal problem elsewhere that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur. T
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Jan 24, 2010 | Mitsubishi WS-55805 55" Rear Projection...
How do I reset big screen tv to 1080 on remote
You don't.
It should automatically switch to 1080 when and only when there is a HD signal present. Otherwise it will be in 480 and you will need to use the format button on the remote to change the picture size. If it does not switch to 1080 and you know for sure you have a true HD signal present, there is a problem with the unit.
Hope this helps,
Skyassoc
Jun 28, 2009 | Mitsubishi WD-62531 Projection Television
Mitsubishi HD 1080 series model ws-65807 no volume.
You need a remote. There are places that sell them, but you can usually get by with your cable box remote or some other modestly programmable remote. It would help if you had an owner's manual. You can probably find one on line. It is a bit of a dance to make the menus work correctly.
My set is gone, but you have fairly ordinary on-screen menus. One of them is for sound on or sound off to the internals. That so that there isn't the conflict between speakers from a receiver based audio setup. You should have external speaker outlets on the set itself. If you do, plut in a speaker you're not worried about. you should get sound out from there.or use an audio out connection to a receiver, etc.
Jan 17, 2009 | Mitsubishi WS-65809 65" Rear Projection...
No color on mitsubishi 1080
1080 is a High Definition setting. If your Television is HD capabilities you need to make sure that the programming that you are viewing is being broadcasted in 1080. If it is not then you will see a difference in picture quality and sound. If no color at all and program being watch is HD programming check your connections on back of Television. depending on what kind of input the Television is receiving you might need to try new cables or a new input. Good luck
Oct 18, 2008 | Mitsubishi WS-55613 55" Rear Projection...
No sound in hd 1080 mode.
check to make sure that you have all the cables plugged in for that model you need a total of 5 cables for the HD input. 3 component(red,green,blue) and 2 audio(red,white)
Mar 18, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi WS-55805 55" Rear Projection Television Logo
157 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
