Setting up dual monitors with vista
Trying to set up dual monitors running vista with a nvidia 9800 gx2 which supports dual dvi. system is not recognising second monitor. main monitor is lg flatron l246 wh and second monitor is samsung syncmaster 2443bw.
  • warlock61
    warlock61 May 11, 2010
    are you using windows or the nvidia setup?
    Champion:
  • 254 Answers
1.both monitors work in single mode ok.
when you start the nvidia contol panel under the display heading
you have setup multiple displays. What does this say.
are you using the nvdia drivers or the cards oem drivers ?
plug one monitor in then start the computer when that monitor works ok , turn off and plug in the other ...
hope this helps
Posted on Dec 31, 2008
Need help with a new video card I install in my dell precition 360 don have video
Hello there,
This is the supported Graphics Cards the computer you have can use
Graphics Support . . . . . . . . . . . . . . . . . . . . . . nVIDIA® Quadro 4 280 NVS 64MB DDR, AGP 8X, available in single or dual VGA and single or dual DVI
nVIDIA QuadroFX 500, 128MB DDR, AGP 8X, dual monitor (VGA and DVI or two VGA)
ATIæ Fire GLô X1, AGP 8X, 128MB, dual monitor (VGA and/or DVI)
3Dlabsæ Wildcat4ù 7110, AGP 8X, 256MB DDR, Dual monitor (VGA and/or DVI)(Desktop chassis only)
let me know the Model of the Video Card you are trying to install and we can start fixing the problem
Thank you don't forget to Rate
Jan 25, 2011 | Dell Computers & Internet
I tried to set up dual clones monitors and set the display too high for either monitor now i cant see to reset the video display. Is there a way to reset the card to factory setting with seeing the...
Hello dave, the only way you can change default setting on resolution is go to > Nvidia Control Panel > Display > Change resolution and click apply. If this option does not work you can go to start> control panel> uninstall a program and remove your old nvidia driver from you computer and reinstall latest driver again, restart computer. I hope this helps you.
Nov 26, 2010 | BFG Technologies 3DFuzion 3DFR6200LEE...
Does Intel DG31PR Motherboard suooorts Nvidia
Your mobo has pci express slot for grafics card. so it supports all the pci express cards and i think that the 9800 is pci express.
Oct 10, 2009 | Intel DG31PR Motherboard
Video card/dual monitor set up
If the card has dual monitor dvi out puts your set if not your going to need a new card
Apr 03, 2009 | Computers & Internet
Dvi port doesn't work with 23'' samsung monitor
yeah, you can set the display setting as extension display your DVI
Intel, ATI,Nvidia have tools also to set up,
i have ATI and use the ATI Catalyst tools and autodetect the monitors that i connected to my docking station, intel and nvidia also have this utility.
it depends on setting if u wanted the external monitor as CLONE monitor of your laptop or extension Monitor...
or they might have problem on DVI port of your docking station.
download and install the video utility ( must have .net installed before you install the utility)
the utility will detect your video ports (VGA,DVI,S-video)
let me know the update ..
Mar 23, 2009 | HP Compaq 6710b Notebook
P223w
This is known as Dual-Link DVI, it is a requirement for many high resolution large wide screen LCD monitors. (WQXGA 2560 x 1600 resolutions and such) You are correct, you must ensure that the display adapter you are using supports Dual Link and you are using a 24 pin Dual Link DVI cable
http://en.wikipedia.org/wiki/Dual-link_DVI
Feb 05, 2009 | Acer P223Wwd LCD Monitor
Nvidia FX5200 DVI 1680 x 1050
Sounds like an issue i get but when using dual monitors. Most likeley windows just doesnt support that resolution with DVI. As you stated.
There may be some update but most likely not. There probably isnt a solution really.
Now, if the background image is not set to strech or handle that then you need to use a different background.
Some default back ground images for windows arent set to go to a certain size or dont resize correctly.
Try opening the display settings and tinker a bit if you havent already.
Jan 22, 2009 | Nvidia G-Force FX5200 256M DDR 8X AGP...
Blank screen using Vista x64 with Nvidia Forceware Drivers 8600GT
Most like the sound card you have is not compatible with Windows Vista. You need to check the manufacturers website to see if there is any patch for Windows Vista
Oct 02, 2008 | Computers & Internet
Nvidia GeForce 7200 GS PCIE - Multi-Display does not work
This card does not allow you to Multi-Display with the VGA port and the S-video port. If you put a DVI to VGA port adaptor (not supplied) on the DVI port, you can Mulit-Display two VGA monitors and (presumably) a VGA (from the DVI port) and S-video monitor.
This is not explained anywhere and the card does not come with a DVI to VGA port adaptor, so I wa only able to work this out after I bought the DVI to VGA port adaptor.
May 21, 2008 | Nvidia GeForce 7200 Graphic Card
HI would you
This graphics driver is compatible only windows VISTA 32 bit,
and supports the following card:
  • Supports GeForce 6, 7, 8, and 9 series GPUs including these newly released GPUs:
    • GeForce 9800 GX2
    • GeForce 9600 GT
    • GeForce 8300
    • GeForce 8200
    • GeForce 8100/NVIDIA nForce 720a
    • NVIDIA nForce 730a
  • If you found any errors in this combination, please install the chipset drivers of the motherboard to become the system stable.
    more info about 174 here is the info: http://www.nvidia.com/object/winvista_x86_174.74.html
    May this help,
    melnavz
    PS:pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
    Apr 21, 2008 | Computers & Internet
    Computers & Internet Logo
    620 people viewed this question
    David Payne
    David Payne
