Question about Lexmark X83 All-In-One InkJet Printer
X83 lexmark A06 error (paper jam)
There is no paper jam....I power off and it does the same thing over. the paper does not feed through.
    President:
  • 8,637 Answers
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 29, 2009
Paper feed problem
The clicking noise is an indication that something's not right in the printer. But try taking out the cartridges from the printer. Then, close the cover. Remove all sheets of paper. Unplug the power supply from the printer. The power supply is the black box behind the printer where the power cord is attached. Wait at least 10-15 seconds before plugging it back in. Once printer's ready, reload the cartridges. Load some paper and try to print again. If this doesn't help and you're still getting that continuous clicking noise, it's a hardware issue. If that's the case, I strongly suggest you contact Lexmark Technical Support for further assistance. I hope I can assist you more on this.
May 28, 2010 | Lexmark X83 All-In-One InkJet Printer
Paper will not feed through the printer . . , ''paper jam'' message appears . How can i open the printer to check for a paper jam? I have a Lexmark X83 printer/copier/scanner.
behind the printer there is the tray that can be opened easily to check if the printer is jammed in or the paper feed sensor is stuck up.just open the back tray of your printer and check.
get back if you require more assistance on this.
thanks.
Jul 08, 2009 | Lexmark X8350 All-in-One Plus Photo with...
How do I remove the cover of my lexmark X83? The paper will only feed part of the way then I get a paper jam message.
there is a cover there at the back of your printer, pull it down then remove the paper hang on their, then after you remove , check if there is another paper to hang, after that try to print
Jul 01, 2009 | Lexmark X83 All-In-One InkJet Printer
Lexmark X83 has system error A04.
Try to do the following:
  1. Reseat both cartridges in the printer and unplug the power cable for 30 seconds.
  2. Plug the power cable back in.
If you still experience issues please let me know.
-Serge
Mar 30, 2009 | Lexmark X83 All-In-One InkJet Printer
Lexmark x83
Sounds like there is something like a part of a sticky address label, or a piece of other paper stuck inside.
Take a heavy piece of card stock and feed it through the paper path. Chances are, when you get the card stock all the way through, it will push out the offending object that is hung in the paper path.
May 19, 2008 | Lexmark X83 All-In-One InkJet Printer
Lexmark X4850 paper jam
  1. Turn the printer off and open the access cover.
  2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
  3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
  4. Watch the paper as it feeds through and try to determine where the jam is occurring.
  5. Check to see if all the rollers are turning.
    If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
    If not, there is probably a feed motor or a gear problem and the printer may require service.
  6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
  7. Turn the printer off.
  8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
  9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
May 09, 2008 | Lexmark X5470 All-In-One InkJet Printer
Won't move paper
Never remove paperjams from the back. this will damage the feed roller. get sandpaper (1 layer) insert it in tray start print and whatever you do DO NOT let go of the sandpaper until the printer is quiet. It should work.
Nov 03, 2007 | Lexmark X83 All-In-One InkJet Printer
LEXMARK X83 PRINTER 1) A few times papers jammed too far back to pull out from the front so i pulled them out the back. Now when the paper feeds there is a clicking noise and the papers feed only...
Oct 10, 2007 | Lexmark X83 All-In-One InkJet Printer
Lexmark X83 all-in-one printer
Hi gerby, need to eliminate a few issues to get to the cause. First, check for a jam. Paper jams can be so tiny you can barely notice them. Use a torch and check thoroughly down back of unit in paper feeder, open cover, let cartridge carriage roll left and settle. Now look inside thoroughly too. If no jam, check rollers are even and look same on each side. Post back if no good.
Sep 01, 2007 | Lexmark X83 All-In-One InkJet Printer
Lexmark X83 All-In-One InkJet Printer Logo
211 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
