Question about Logitech Quickcam Chat Webcam
Skype and Quickcam connect ??
Skype won't let me use web cam, I can only talk or do still photo when on Skype, why?? I checked off the spot on skype with my web cam's name.
Thanks H B
  • unique77 Jan 04, 2009
    President:
  • 8,637 Answers
Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Posted on Jan 11, 2009
  • Weldon Dube'
    Weldon Dube' Jan 11, 2009
    Hope this works, Bud
Camera getting connected and then dis-connected and my photo is coming in negative
Skype is a free software program that allows you to make phone calls through the computer. It also lets you text chat and place video calls. Since Skype is designed for use with web cams, it has the capacity to take snapshots both of you and of the person to whom you are talking in a video call. Plug your web cam into your computer and make sure it is on, open Skype, click on the "Skype" menu, select "Change your picture," and then click "Take Video Snapshot." After that, you can decide whether you want to keep the picture or trash it. Use this option if you want a picture that people can see in Skype almost immediately and don't want to bother with downloading or uploading anything. b>
Jan 19, 2013 | Samsung 2012 Vg-stc2000 Original Skype Web...
How do i install logtech web cam to use skype
Check On Skype Look on Sitting Look For SeeCam Connection then Configure Your Logitech Config matching with Skype
Oct 09, 2010 | Logitech QuickCam Connect Webcam
I have a Logitech QuickCam 6.0 and it has been working perfectly for months with Skype. Now I am still receiving incoming video but outgoing no longer works. I reloaded QuickCam without improvement. ...
Try to check if this issue occurs on Skype only or with all programs
If it is for Skype only:
You need to check the Video Settings in Skype.
Start Skype > Options > Video Settings > select the webcam that you are using.
If the webcam is not on the list, download and install the driver from the manufacturer website
Try to set Automatically Receive Video from - select Anyone or Only people in my contact list.
Jun 01, 2010 | Logitech QuickCam Connect Webcam
My web cam blur on skype.
Check if your webcam has a ring on the front of the lens you can turn to focus. Then go to the free webcam test site where you can see yourself, and turns the ring until you sharpen the image.
May 28, 2010 | Logitech Quickcam Chat Webcam
How do I get started using skype?
Simple!
Download Skype for your operating system via the following www.skype.com/download
Then you need to register a new account.
Assuming you already have connected a microphone and/or a web-cam you should then be ready to add contacts and make phone calls across VOIP.
If you need any more info please contact me.
Thank You
Scaasiboi
Jan 29, 2010 | Logitech QuickCam Express Web Camera
Pc restart when i try to use webcam on skype 4.1.0.166
hmmm! it may b ur RAM probz!!! chek cam settings! may tht USB port affecting ur RAM wich results in restarting!!
Nov 10, 2009 | Logitech QuickCam Pro 9000 Web Cam
Skype shuts down when I enable the video on Skype. I tried using an older version of Skype but still encounter the same problem, any ideas out there
With updating SKYPE your firewall must be updated as well.
Exit/Close your current Skype by clicking in system try Skype icon (down near the right corner green spot)
and choosing “Quit” from there if needed.
Open firewall, in programs, deletes Skype.
Run Skype and allow connecting
This also affects SP2 users who should follow above procedure.
With SP2 firewall.
Disabling external firewall will enable XP firewall by default.
So if you disable any other firewall XP firewall will now block your connections.
So remove Skype from XP firewall program list as well
dont forget to vote fixya rating
Sep 13, 2009 | Logitech QuickCam Pro 9000 Web Cam
Logitech Web cam freezes every few minutes when used with Skype
Look in device manager See if there is a memory conflict with another device
Jul 27, 2009 | Logitech QuickCam Connect Webcam
Quick cam chat to skype hookup?
Skype usually recognizes the web cam. If not try reinstalling Skype if your cam works
Feb 10, 2009 | Logitech QuickCam Express Web Camera
Webcam
Normal 0 Normal 0 First, download SKYPE by double clicking on thissite: (http://www.skype.com/intl/en/download/skype/windows/beta/).
and install it.
Then let all your family and friends know you’re on Skypeand give them your ID. After they get on Skype and you know their ID'sadd them to you Contacts in Skype. After you connect up with them you canturn the camera on so they can see you.
Skype is a free download and free to converse by computer withoutpaying and you can talk to several people at a time.
It only costs if you call a telephone number from yourcomputer while on Skype. Once you get the hang of it, you will enjoy it.
Normal 0
After you install Skype and have it operational with yourID. Go to "TOOLS", click on "OPTIONS," Then go to"Audio Settings" and click on it. Make sure both the Microphone andSpeaker's are correctly chosen. Then"make a free test call." Wait till the voice tells you torecord. Then when finished talking wait for the test persons voice toinsure your audio transmission is working. Then go back to options andtest your video settings. Click on Video Settings and proceed to set upyou video camera. Also, you can visit this site for additionalinformation to setup video.
http://www.skype.com/help/guides/video/
Jan 19, 2009 | Logitech QuickCam Express Web Camera
Logitech Quickcam Chat Webcam Logo
102 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
