Question about D-Link DSL 200 (DSL-200) Modem
Modem keeps disconnecting, and slowww speeds.
In the past 24 hours my D-Link DSL-200 has disconnected at lest 10 times, and it has never done this before (8 months of use). It simply goes from full green status into the dull orange or no colour status, though not the full red disconnect. Also, when it reconnects, the speeds have been much lower than they have been. Normally Rx Download is around 6400-6900kbps.. but at the moment it ranges between 400kpbs and 4200kbps after each reset. Is this possibly a phone line complication or driver error or simply something to do with the modem itself. Thanks for any help!
    Problem Solver:
  • 14 Answers
--is your dlink directly connected to the internet cable ( rj 11) --if it is having a modem in between --we need to check with the modem status also --the problem might also accure with the internet service provider --check with them if they have any sort of outage in the area. --as well as our doubt about the telephone line might also b correct --as well as check if your router is not placed on floor --your router should be near about five feet above the ground level. --it may create a static and interuppt the signals --make sure that you dont have any electro magnetic devices near by our router --maybe satellite/Direct T.V. or fax machine, etc
Posted on May 06, 2007
Can I use AT&T 2701HG-B 2W Wireless Gateway DSL
yes, you can use them together. they'll find each other at protocol layer 2 (bridge) and layer 3 (router),
and route packets appropriately. Check their manuals to make sure that their HTTP management page ip addresses are different - say 192.168.0.0 for one router and 192.168.1.1 for the other - so that you
can manage them separately without disconnecting them.
You'll want to manage them separately to assign them different wireless-N channels. Channel 6 is
the default, and allowing both to compete on the same channel is a bad idea - give each its own
wi-fi channel. There are 11 wireles 802.11n channels, labeled 1-11.
Diagram: DSL === AT&T 2701HG-B ---------- NetGear router --------------- desktop computer
Each link in the diagram above is an ethernet (802.3 10baseT) cable (except the DSL cable,
which is twisted pairs), and wireless devices can
hop onto the Internet by wirelessly connecting to either the AT&T 2701 or the NetGear router.
Jul 08, 2011 | Gateway Computers & Internet
Many time net disconnected
Your router has small NAT table and when this table overflows, router hangs and Internet connection disconnects. You can solve router disconnects with Router Commander software. This software accelerate your router using dynamic NAT feature and other technologies that speed ups router and prevent it from disconnecting. You can get it from www.routercommander.com . Good Luck.
Oct 17, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Only the power and ethernet lights come on
power it off completely for 5-10 min...and then try connecting the wire and check
Nov 29, 2009 | Arris High Speed DSL Modem
Xp home wont run vodafone speed modem200
goto control panel and open " phone and modem options" in that go to "Modems " Tab , U can see there option to "Add" the modem . Click that , it will automatically search for the modem connected to your system. After detecting the modem your search for the option "Query Modem" , access that and add the modems speed as 560000 kbps ..thats it ..your modem will work.
Sep 02, 2009 | D-Link DSL 200 (DSL-200) Modem
My d linkflashing and disconnected after minute or
turn off the power and turn it on. how long its happening.go to command prompt . type the cmd ipconfig u ll get the default gateway open the internet explorer and type the default gateway u ll get the d link page and check if the router is connected to the ur isp, if not click on connect, if its asking for user name contact ur isp to get connected to ur isp. if its happening frequently need to b reported to the isp as it might be isp issue
Jun 03, 2009 | D-Link DSL 200 (DSL-200) Modem
Modem keeps disconnecting and needs rebooting every time I use it
Yes, this can be a problem with the modem that you have first thing that you need to do here is to reset the modem and reconfigure it back, but if after that still have the same problem better contact your ISP and ask them if everything is working from their end...
Hope that helps...............
Oct 12, 2008 | D-Link DSL 302G (DSL-302G) Modem
I own a D Link DSL-G604T Wireless Modem. When i connect through any other modem, the connection is perfect, but when i attempt connecting through D link, all appear okay, including diagnostics and port...
Go into control panel network connections and make sure it is active and not disconnected in there. Sometimes they disconnect and you may find it is an install problem. If it says that it is connected uninstall and reinstall software and see if that helps the only other thing I can think of without seeing pc with this info is it maynot be fast enough for your net connection what sort of net you runnig through it? speed
Jul 26, 2008 | Computers & Internet
I need DSL-200 in Windows Vista
i need DSL-200 installation on windows vista.
please help me.
warm regards
Jun 04, 2008 | D-Link DSL 200 (DSL-200) Modem
Need help reconfiguring my modem
Huh?! You just go to all programs/dlink then click on configure.
Mar 15, 2008 | D-Link DSL 200 (DSL-200) Modem
D-Link DSL 200 (DSL-200) Modem Logo
272 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
