Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Paper jam and i can not find it
I was coping something and a paper jam happened. i looked for the jam and can not find it. what do i do/
    President:
  • 8,637 Answers
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 29, 2009
Too much paper into shredder red light on paper is jammed
Some shredders have reverse mode
to eject jam. Otherwise its a slow job - Unplug from mains Remove each piece of paper as close to the jaws of the shredder as possible. Then hopefully when plug in and turn on will not find too much resistance and be able to cope with the paper and drag the jam through until clear.
May 25, 2016 | Shredder Office Equipment & Supplies
How can I fix the following paper jam?
Look for something obstructing the paper path.. where the paper stops look in that area .. a small piece of paper or staple or something is blocking the paper path
May 03, 2014 | Office Equipment & Supplies
Paper jam
when coping or printing? make sure paper is in the tray the way you set it up in the tray settings on the control panel and the driver. paper size, orientation, and media type all make a difference. clean the roller and make sure the lift plate moves freely.
Jan 12, 2013 | Konica Minolta Bizhub c203 Copier
Paer prints half the PAGER AND THEN JAMS ... I
The paper must be hitting something to cause it to jam. Take the drum/toner cart out also the paper tray. Unplug it and hold it upside down and see if something shakes out. Do not do this over carpet. If that does not do try a test page. look at the leading edge for dings and bends. If you find a bent spot on the leading edge thats where the problem is. Its almost always a small piece of paper Steven 818-888-0006
Mar 08, 2010 | Dell 1710n Laser Printer
Paper keeps jamming in the paper drawer 1 and the right side. I have switched to paper drawer 2 and the same thing happens. Drawer is set to letter size but keeps jamming. What's the problem?
It sounds like you have something interferring with the paper path... Look for any small pieces of paper in the paper path, staples, paper clips etc...
If you can't find any then a service call will be the order of the day!
All the best! If I can help further please contact me : johno@execs.com
Oct 25, 2009 | Canon imageRUNNER 4570 Copier
Error message on Lexmark x5470
hi there: we have the same printer and we had the same paper jam problem to correct: this we opened it up as normal and than got a flashlight and looked real closley at it and there was a verry small piece of paper in the side of it folded and caught in it we took a pair of tweezers and removed it and the paperjam was cleared try that ok the smallest piece will give you this error and wont continue untill it is cleared
best of luck mike
Feb 09, 2009 | Lexmark X2500 All-In-One Printer
Quit coping
RealMT I need to know more.  What's the make and model of the copier.
Oct 19, 2007 | Office Equipment & Supplies
Paper shifts
Does it happen both off the copy glass & thru the document feeder or only off the document feeder. If both - check the side guides inside the cassette to make sure they are tight against the paper. If it only happens when using the feeder- the feeder tray needs to be adjusted. There is usually 2 screws under the document tray that when loosened allow for side to side adjustment. Moving the tray should solve the problem if it is only happening when you use the document feeder.
Mar 30, 2007 | Canon imageRUNNER 2000 Copier
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
