My hdtv has no power
Does my samsung hdtv carries a power fuse and where is it located
    Master:
  • 505 Answers
Fuses are located inside the tv which needs to be pulled apart to changed
Posted on Dec 31, 2008
Where is Zeus board located
Samsung HP-R5072 50 in. Plasma HDTV Board ysus lg ...
www.fixya.com > ... > Samsung HP-R5072 50 in. Plasma HDTV
Samsung HP-R5072 50 in. ... LG 50PX1D, YSUS and ZSUS board replacement ... andZSUS boards and have found conflicting information. So... YSUS = .
Samsung HP-R5072 50 in. Plasma HDTV Ysus - Questions ...
LG 50PX1D, YSUS and ZSUS board replacement 1. ... right away I found a bad fuse on the ysus board and replaced it. if i unplug ysus board the unit stays on.
Jan 18, 2016 | Samsung Televison & Video
Location of the fuse box for samsung flat screen
It can be located at the main power supply regulator board itself. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 14, 2014 | Westinghouse LTV-37w2 HDTV
Samsung DLP fuse location
what fuse have you been ask, the primary fuse from the power supply?
Jul 18, 2012 | Samsung HLP4663W 46" Rear Projection HDTV
Please tell me where the fuse box is and the mother board
one fuse is located directly where the power board goes--set has as many as 6 other fuses inside in different areas--they are pico fuses which means not glass or fuse like in appearance.
Set dead with or without power light?
Apr 09, 2012 | Samsung HCN4226W 42" Rear Projection...
Hi , have opened back cover, where are the fuses ,can you send a diagram
If you are referring for the power supply's fuse, it is located near where the power cord's directly connected. See on the picture below.
Ceramic fuse is the one installed on that board. It is white in color or sometimes a multicolored one.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Aug 02, 2011 | Samsung HP-R4252 42 in. Plasma HDTV
My Samsung FPT5084 50 in. HDTV Plasma Television was working fine and now it won't power up when I try to turn it on. Is it possibly a blown fuse.
It's probably a blown fuse on the power supply circuit board, or if it has a circuit breaker maybe it can be reset.
Nov 11, 2010 | Samsung FPT5084 50 in. Plasma HDTV
Where can i find a ceramic fuse for my samsung Plasma TV model # FPT 5084X
any tv repair company will gladley sell you one ever the counter if you have the blown one take it with you if not ask them to check the right values
hope helps
Apr 24, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
Power flashed on and off then went off no indicator light at all now but still has power on optical connection. appears to have power at low voltage side but no high output
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Oct 22, 2009 | Vizio L32 32 in. LCD HDTV
Tv (LC3760N) shut off blinking power light will not turn on
Jun 25, 2009 | HP LC3760N 37 in. LCD HDTV
FUSE KEEPS BLOWING WHEN POWERING ON
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Link to a photo of the PCB. Make a note of the location of all cable connections then unplug them all. Un-install PCB, Check a Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Feb 01, 2009 | Philips 42PF9966 42 in. HD-Ready Plasma...
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
