Question about Moen 7437 Chateau Single Hole Kitchen Faucet with Side Spray Chrome...
Lever will not stay in position
Moen Kit faucet #7430, When you turn on water ,the lever slowly goes down on its own,therefore turning off water.What is the problem. thank you
  • Anonymous Mar 20, 2014
    LEVER WILL NOT STAY UP
  • 35 Answers
There is a nut in the handle mechanism that needs to be snugged up (adjusted). There is an exploded view of this faucet at http://www.moen.com/shared/pdf/7430pt.pdf
Let me know if I can help you further, -CompuWayne
Posted on Dec 31, 2008
My kitchen faucet is a single handle Moen and is approximately 20 years old. Lately it has been acting up which I have been ignoring in the hope it would heal itself. It has been difficulet to turn the...
It may just be that you need a new cartridge. If you can replace cartridge without to much problem I would do that. Depending on your water quality the cartridge may be very hard to remove on a faucet that old. Also if the handle actuating hole is worn very much you may have to replace it also. By the time you buy parts you may have half or more of the price of new faucet, I would recommend that you replace faucet. Hope this helps. Thanks
Nov 17, 2010 | Moen Plumbing
My moen single lever faucet problem is no hot water. The water is warm at most and when you turn it off and on it goes to cold. The faucet is only 8 months old. The only way to get real hot water is to...
The hot side sounds like it has some junk in the hot side blocking the hot water from coming through check hot water line to make sure that it is coming through down below and if so you would need to take it apart and try to get the junk out of that side of the faucet.
Nov 14, 2010 | Moen 7437 Chateau Single Hole Kitchen...
Re: Moen single-lever kitchen faucet like the 7100. When I replace the lever, it only goes up. I can't get it to go down. I'm pretty sure the cartridge is in right, with the U-clip and the other screw-on...
The water supply should have no bearing on the working motion of the faucet cartridge or handle. On both models of Moen faucet, the handle needs to be hooked under the cartridge's top cam bearing. It is a bit tricky sometimes. Here's the parts view for 7300 and 7310 Moen Kitchen faucet. Parts view for 7100 Moen.
If you need further assistance please let us know.
Sep 16, 2010 | Moen 7310 Legend Single-Handle Kitchen...
Trying to change cartridge on Moen single lever kitchen faucet with sprayer. Now that it's been reassembled, gets no water from spout when turned on. When lever is turned on, sprayer goes off and...
Moen has a diverter built in that will need to be replaced.
use the same steps as when you replaced the cartridge, but this time you will need to remove the spout, there is a small diverter, you will see it when spout is removed.
take this part with you to the hardware store, along with the O Rings from the spout, as they will need to be replaced also
use a non silicone faucet lubricant when putting back together
Aug 08, 2010 | Moen 7437 Chateau Single Hole Kitchen...
Our Moen Kitchen faucet lever does not stay up
That's easy! My husband is a plumber. he says u have to take the lever off. Point the tip of the lever down and put back on. There's a little ledge of plastic that u have to get the metal handle on. It's difficult to explain!
Jan 03, 2010 | Moen 7437 Chateau Single Hole Kitchen...
HOW TO DISMENTLE OR REPLACE A MOEN SINGLE LEVER
shut water off at stops under sink. Unscrew water supply lines from directly below handles. Above them you will find plastic nuts, remove them. Disconnect pop/up lever and you should be able to lift faucet from sink.
Sep 24, 2009 | Moen & One Handle Tub & Shower Faucet
Moen kitchen faucet. I changed the cartridge but
Single or dual lever? A new ball if single lever. Home Depot or Menards will carry them. Teflon tape if dual cartridge. Stay away from moving parts
Aug 14, 2009 | Moen & One Handle Tub & Shower Faucet
Need to fix a broken moen kitchen faucet
I had the same problem with my Aberdeen single lever with a pull-out sprayer a few months back. If you are the original owner of the faucet, it's under warranty; you shouldn't have to pay for any parts. Call: 1-800-BUY-MOEN (1-800-289-6636) and tell Customer Service what the problem is. They will send you the Handle Mechanism Kit at no charge. (Mine was part #93980 for my Aberdeen faucet, but yours may be a different part number.) It's tricky to take apart and get back together but my husband and I have zero plumbing experience and got it all fixed in about 20 minutes. The Moen.com website also has exploded parts diagrams of all their faucets so you can identify exactly what part you need, and they have some little videos and slideshows to show how to replace parts. If you can't reach Customer Service on the phone, you can go to "Contact Us" on their website and email them a description of your problem.
Jun 17, 2009 | Moen Plumbing
Water flow stops with lever in the up/on position
This unit uses a cartridge with some small washers. I have included a link of the expanded view for your faucet. Take it apart and replace the whashers in it. Hopefully this helps.
http://www.kohlerserviceparts.kohler.com/ServicePartsPage.aspx?DocumentID=0561a954de3942e3ac66f50127b98adc&ModelID=37de6e29350e443c8a60cfad797b4867
Apr 10, 2009 | Kohler K-12176-PB Fairfax Single Handle...
Moen 7437 Chateau Single Hole Kitchen Faucet with Side Spray Chrome... Logo
630 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
