Question about Garden
Ariens ST724 carb issue
A friend sold me a very old Ariens ST724 for $100 a few years back and it worked like a champ until recently. While cleaning the carb I noticed the brass pin was bent - I tried to straighten it and it broke. I think if I could find a replacement pin in a rebuild kit I would be in good shape - but I can't figure out what I need to buy. I bought "tecumseh carb kit 31840" Which arrived today and it does not fit. Any clues? Thank you very much.
  • 76 Answers
You'll need the model and serial number and also the carb will be helpful, if you take that info and the carb to your local lawnmower shop they will be able to supply you with the right kit.
Posted on Jan 01, 2009
Parts not available for Ariens ST724 7hp snow blower?
As far as the bolts you should be able to match them at a small engine and lawnmower repair shop and as well if you take the old recoil they might be able to get you what you need.
Nov 10, 2014 | Garden
Parts not available for Ariens ST724 snowblower?
No you do have the model number and hp should do it ..go in on your computer and just put the name,model number,hp and model in that order .or better yet go in on eBay and put that in and most likely you will find it a a reduced cost..good luck
Nov 10, 2014 | Ariens Snowblower Belt 72098, 8hp 1/2 X 37...
Ariens st24e leaking gas from carb body
As you said, it's probably got a stuck float. If stored without draining and fuel petcock turned off, gas evaporates from carb bowl and sticks float down, allowing fuel to flow all the time.
Solution: Remove carb and fully clean. Carb dip can be effective if left long enough but it will not clean out totally closed-up holes or clogged passages. Cleaners can only dissolve varnish if they can get to it and totally clogged passages won't allow cleaner to flow to where it's needed. Pros use a hot bath of cleaner and/or ultrasonic cleaners.
Start with a carburetor rebuild kit and use as many parts as necessary. Be careful to remove rubber parts like O-rings and gaskets before cleaning with solvents. Adjust mixture screws to factory recommendations and fine tune after you get it running. Good idea to purchase an engine service manual for you particular engine.
Dec 15, 2012 | Ariens 34 In. Zoom Series Riding Mower
2 year old Ariens tractor won't start
It could be anything from a carb issue to a spark plug or bad fuel.
May 24, 2012 | Ariens Garden
I bought an ariens 932027 ST724 W/ 7HP Tecumseh HSK70 130266S Engine. It seems to have a problem running for longer period of time than 5 or 10 min. after that it starts back firing and shuts down. It will...
Almost certain, having had this problem with this mower several times, that your petrol cap which is suposed to let air into the tank does not. after a few mins of running suction develops and the engine stops. you check the fuel level and its ok so you restart and it goes fine for another 5 min. by removing the petrol cap you let air in and temporarily fixed it. Clean out the arangement of screws and springs and filters under the fuel cap.
Dec 28, 2010 | Sport & Outdoor - Others
Why does only the right auger turn?
You most likely have a shear pin sheared on that side.
If you engage that slip diff., it engages both wheels like a posi-trak.
Dec 26, 2009 | Garden
I recently replaced a carb kit on my ariens model#938010 ss322 and it will not keep running,it does not have a diaphram.any suggestions?
We're talking about a briggs or kohler motor with a bowl type carb- correct? Im assuming you are sure you are dealing with a fuel issue.
To what extent did you rebuild the carb? Did you replace the needle? Make sure all passages are clear? check the float level? Check the setting of the idle air screw ( if present)?
Did you check the quality of fuel coming out of the fuel line and did it have good flow? Its easy to have water in your fuel system and inadvertantly fill your clean rebuilt carb up with water/ bad fuel.
In short, once you've narrowed it down to a fuel issue, youve either missed something in the carb and will need to go through it again or there is bad fuel in your system or the fuel is not reaching the carb.
Dec 10, 2009 | Ariens Garden
Ariens ST 724 impeller does not move under stress?
i have a old ariens ST724 snowblower engine will only run with full choke.
Jan 29, 2009 | Farmall Cub Tractor Radiator
Ariens snowblower ST724 leaks gas from the carbourater
The little metal peice with the wire ataches to the float at the hinge part of the float, if you use yahoo type in tecumseh carburetor diagram then click on Parts and Diagrams and the web address is it will show you a breakdown of a carb and how it goes together. It may not bee your exact carb but they are all pretty much the same. It also sounds like you may need to rebuild your carb. If you get it back together and it still leaks, I suggest you take it to a small engine repair shop and have them rebuild it for you only cause you need a special tool for the seat and the float will have to be set.
Dec 27, 2008 | Ariens 34 In. Zoom Series Riding Mower
Garden Logo
648 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
