Question about Acer Aspire 3002LCi Notebook
Keyboard Fn key malfunction
Did U manage to fix the problem? Please, need help.
Seagull491@yahoo.com
Advent 9215 keyboard malfunction
The laptop keyboard will need to be replaced, go to www.ebay.com Type: make and model of computer, refine search to keyboard.
May 20, 2012 | Advent Computers & Internet
I type j and it comes out 1. can't fix.
Try this.
Press the Start key + R.
type osk in that box and hit enter
On this keyboard, try toggling numlock scrolllock and capslock a few times. does it help?
I think your numlock might be stuck on and your keyboard "num lock" key isnt working
Jan 04, 2011 | Computers & Internet
I am unable to activate wireless card. I have to press Fn f2 key but the f2 key on my keboard doesn't work. I tried connecting a wireless keyboard (it doesn't have Fn key), then pressed Fn on laptop, F2...
It could be a drivers problem... Unistall the drivers from the device manager and install a fresh one from the dell website.. Try pressing the FN+F2.. Still no go.. Try to check whether the keyboard is working.. Still no go - resaet the Wireless card... Still no go.. Replace the wireless card..
Sep 06, 2010 | Dell Inspiron 6000 Notebook
The keyboard on my laptop has numbers and keys on it
It sounds like the Num Lock is on.
Depending on the make of the laptop there is a few different ways to turn it off.
Either just hit the Num Lock key and see if it goes off, hold down Fn and hit the Num Lock key or hold down the shift key and hit the Num Lock key.
Regards.
Sep 22, 2009 | Computers & Internet
I have an old Dell Latitude cpx H and I have a weird keyboard problem. I have already changed out the old keyboard but the problem persists... or should I say problems. There are blue function keys on the...
1. this could be due to a loose flex cable to the keyboard and the motherboard.
2. It could be due to a malfunctioning keyboard assembly
Usually it is the latter.
Sep 15, 2009 | Dell Latitude CPX650 Notebook
Presentation mode is off appears when you try to FN F8 Dell Latitude E6500
check device manager to be sure your video card is functioning properly. If it looks good in device manager, shut off the pc, connect the external monitor/projector to the pc and start up the pc with the external device powered on. if no video from external device, then the video card/external connector is probably bad. Contact Dell if in warranty.
maybe the fn/f8 keys are not working. Can you get a safe mode boot prompt by repeatedly pressing the f8 key immediately following power up on the laptop? if no, f8 key is likely dead and you need a new keyboard. If f8 is okay, does the fn key work with other functions? if no, fn key is bad - new keyboard.
Hope this helps!
Aug 08, 2009 | Panasonic PT LC75U Multimedia Projector
Keyboard keys L/G/R acting weird
It sounds like the Windows is registering the "Windows Key" as being in the "Pressed" position. This is the key between control and alt on the left side of the keyboard. Press it a few times and see if that helps. If it does not it sounds like that key or the keyboard may need replacement.
May 20, 2009 | Compaq Presario 700 470024-192 Notebook
Keyboard trouble
you need to reload that software that came with the keyboard. Uninstall the keyboard from device manager :- Control Panel>system>device manager. Then reload the software for the keyboard, which should also have the drivers. If you do not have the software, let me know the make and model of the keyboard and I will see what I can do.
Hope this helps
Oct 28, 2008 | Gateway Computers & Internet
Keys Don't Work (U I O P & A)
These are the keys for the calculator feature. First try holding the fn key and press the nm lck key. if it's a numbers lock glitch this will take care of it. If this doesn't work, then check the connection. Still not working, then try uninstalling the keyboard drivers from the device manager, and reboot. The machine will find the keyboard and reinstall the drivers. If it's still not working, then you may have damaged the keyboard during the cleaning.
Aug 11, 2008 | IBM ThinkPad T40 2373 Notebook
Acer Aspire 3002LCi Notebook Logo
116 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
