Question about All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater
All Pro 170t kerosene heater is throwing raw fuel out the burner
It worked fine when we got to the shop. We turned it off for a while and when we started it back up it just threw raw fuel out the end and would not ignite. We let it sit for an hour and then it worked, when I turned it off it smoked out of the rear end. It was blue smoke so it was diesel. Any help would be appreciated.
  • sivartz Jan 15, 2009
    i have the same heater, lights, gets hot and runs about 3 minutes and then smokes out the end.shut it off and restart and 3minutes later the same thing.cleaned filters and checked air/fuel mixture.
  • Anonymous Jan 28, 2009
    the heater will run about 3 min. and shut of i have drained the tank and cleaned the filters and the lines, but none of that has seemed to work so i just keep cutting it off and on but it is really getting old.
It sounds like it is currently working .. is that right? Or does it only work if you let it sit for an hour, still? The blue smoke probably is from the residual fuel not burnt when it "threw raw fuel out the end" some the fuel probably drained to a low point ..outside of the combustion chamber and then may have ignited after shut down.. to cause the blue smoke out the back... when you turned it off.
If when your starting it up... it doesn't start the first time.. wait 10seconds then try again.. noting what it apparently does.. and doesn't do. does it just 'through fuel for 5 seconds.. does the fan spin .. and push air at the same time when its starting? If yes for both, does the ignitor ignite the fuel/air mixture, briefly then it shuts off.. ?? Hope this line of thinking helps you out
md
Posted on Dec 31, 2008
Does the 170T use desil as well as kerosene
Yes diesel can be used in torpedo heaters, but you should only use #1 diesel or #1 fuel oil or #1 kerosene. #2 fuels are dirty and will crud up the heater faster. The other problem with diesel fuel is that it gels at very cold temperature. Anti-gel additives are available.
Jan 06, 2014 | Reddy Heating & Cooling
Sometimes the heater throws out raw fuel out of the burner and sometimes if I cut it off and wait a little bit it will ignite and come on and then it will work normal with the thermostat. Is there...
turn the adjustment srcew clockwise a little to raize the pressure.. check your gap on the spark plug /igniter .060. also check the air pressure should be 6.5#
Jan 23, 2011 | Reddy Heater-170,000 BTU Kerosene Deluxe
Can you burn diesel fuel
Hi, If this heater is the Reddy 170,000 b.t.u. heater, model # 170t professional series, then yes you can.It is a multi-fuel heater. Fuels it can use are Kerosene, JP8, Jet A fuel, 1&2 Diesel fuel, and 1&2 fuel oil. It must be this model 170T.
Sincerely,
Shastalaker7
Jan 19, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
All pro heater runs for a couple of minutes.then
it only shuts down because of an overheating condition or the lack of fuel. if you have an ohm or multimeter, check the ohms on the fan and see if you have any resistance. If you do the fan is good but may still not be putting enough air across the heat exchanger to safely alloww the heater to run without causing a fire.
Dec 19, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
Is thier a filter that needs to be changed for the fuel system on a 170t
There is a inline fuel filter, small plastic filter-looks like a small space ship located behind side panel.It has a hose attached - one going to tank, one going to nossle
Oct 25, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater Logo
1,499 people viewed this question
Top All-Pro Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
T bone 1963
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
