Question about GE VG4054 VCR
VCR Malfunctioning I insert a tape into the reciever and it goes down, then the display flickers like a pulse and the tape is stuck. I was able to take the lid off and found a way to get the tape out, but the problem still occurs. At one point, It took the tape without any problems, but when I hit the play button, it relapsed. I was unable during both times to hit the eject button and get it to respond. The best way to explain the "flicker" is that it seems to shut off and turn back on every time. Thank you for any ideas or fixes.
  • 4,234 Answers
The power supply is starting to fail. If you can solder, you should be able to fix this. If memory serves me correctly, there are 2 capacitors that may be causing this. Look for a cap in the 22ufd range on the primary side of the power supply. This cap will be a 160V electrlytic cap. Replace it with a new one. That may resolve it. In the meantime, I'll look up your model for additional specifics.
Posted on Dec 31, 2008
I have a sony slv-d100 combo. DVD works fine, vcr NOT!
this is a mecanical problem, is some gears is broken.
Pease send to repair shop, to check
Nov 27, 2009 | Sony SLV-D100 DVD Player/VCR
A video tape has become stuck in my Mitsubishi VCR
Hi, Suggest call a local tv repair shop. Thanks.
Sep 22, 2009 | Televison & Video
JVC HR-S7600U VCR. Playback issues with VHS & SVHS tapes.
super vhs tapes has an extra hole on the side where you lift the flap to see the tape the pin inside the machine must be stuck.I have had no problems with this as i have jvc super vcr s as they are great machines also take the lid off and clean the heads around the drum see how you go.
Jan 25, 2009 | Pioneer VSX-D710S Receiver
VCR running badly
The 180 tape is thinner than regular 120's, and they tend to stretch. Your VCR "knows" the speen and that there is information on the tape by looking at and counting the pulses on the "control track" which is like the sprocket holes on a film. The control track is a series of pulses (regularly spaced pips or electronic clicks) on the edge of the video tape. (They are magnetic and can't be seen with the naked eye.) There is a counting mechanism which - based on HOW MANY pips there are - helps the machine to determine whether it an SP, EP or LP recording, and whether there's a recording at all.
If the tape stretches, the number of pulses becomes very irregular and the machine goes haywire. (There are normally about 60 pulses in one second of tape - 59.94 to be exact!)
If the count - because of stretching - is too far away from the norm the machine the machine will "hunt" (and never find out the real speed) - trying to figure out what speed the tape ACTUALLY is running at. If there's no control track at all the machine will just stop.
Your problem is any or all of the above. Throw the tape away.
Aug 14, 2008 | Televison & Video
Tape stuck in vcr
Carriage has been set out of alignment due to improper extraction- need to repair or replace the carriage loader...accordianman
Jul 10, 2008 | Symphonic SC319C 19 in. TV/VCR Combo
VCR repeatedly tries to play and eject when tape deck is empty
the tape carriage is probably stuck, or something stuck inside blocking the tape sensor.
feed a tape in and see if it does it "with" the tape too
hope this helps
Jan 08, 2008 | Sylvania 6313CB 13 in. TV/VCR Combo
VCR Tape Stuck
Unplug the VCR, take the cover off, find the motor (probably on the right side of the mechanism) and turn its shaft with your fingers until you have run the tape back out. Now plug it back in and try it again with a scarificial tape. If it continues to fail, replace all the rubber belts in the mechanism.
Hope ya fix it!
Jan 05, 2008 | Panasonic AG-1330 VHS VCR
VCR Tape Stuck
my tape got stuck too, i opened the bottom, then located the mechanism that started the eject program. After turning some wheels the eject automatically started. Try that...
Aug 17, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
VCR kicks out cassettes
Sounds as if something got bent in the loading mechanism when you freed the stuck tape. Careful examination of the loading operation with the cover off may reveal the problem, but you may require a service shop, as there are hazardous voltages present inside, even when switched off.
Jul 13, 2007 | Toshiba MW24F52 24" TV/VCR/DVD Combo
Televison & Video Logo
91 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
