Question about HP Compaq Presario C500t Notebook
Compaq Presario Keyboard
How did you pop the plastic cover off by the power button? I have to replace my keyboard. thanks.
  • 4 Answers
Carefully! Make sure there are no screws at the back which hold it down, then use a guitar pick or small rubber sleeved screwdriver to pry one corner of the cover up. The clips are usually VERY tight as the cover is installed once and never usually removed again, but they do give with a bit of force.
Posted on Mar 19, 2009
I hae a compaq 9010 laptop and the on off button has come unclipped from under the keyboard. anyone kow how to lift the keyboard up.
Above the Keyboard, and directly under the LCD screen is the Keyboard Cover. This cover contains the various LED lights, and Power On button.
1) ALL power to the laptop is removed. The AC adapter (Charger) and Battery.
2) Two Philips head screws are removed from the back of the laptop, which fasten the hinge cover portion of the Keyboard Cover to the laptop.
3) A thin flat-bladed screwdriver is used to gently pop the Keyboard Cover up.
On the Right and Left sides of the Keyboard Cover, and also the middle, (Side towards the Keyboard), a small flat-tipped screwdriver is used to gently pry the Keyboard Cover up.
Use care so as to not damage the plastics, nor the wireless antenna.
This is the download page for the Service Manual,
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?lang=en&cc=us&prodClassId=-1&contentType=SupportManual&prodTypeId=321957&prodSeriesId=321850#2
Under the Service Information heading click on - Service Manual
This is a PDF file. Allow time for the first page to come up, and additional time may be needed for the file to fully download.
Should you have any questions please post in a Comment.
Regards,
joecoolvettte
Apr 10, 2011 | Compaq Computers & Internet
I dont know why is my key board is didn't work can you show me how to unlock my key board
restart your computer. on boot it will say press del for bios. do that. in case it enters the bios menu then keyboard is fine. probably some virus in windows. if not then your keyboard is damaged.
Mar 03, 2011 | Compaq Presario CQ60-220US PC Laptop
How do I take apart my compaq presario. I take all the screws out and I still cannot get the plastic to sepreate
There should be a panel usually right above the keyboard that covers the hinges and usually has the power button, wifi, sleep, etc. on it. this panel should pry off with a little help and expose a few more screws that hold the keyboard down and casing together. Hope this helps.
Feb 15, 2010 | Compaq Presario 700 470024-192 Notebook
How do you remove the actuall keyboard on a compaq presario 1200 notebook computer, i have removed all screws and access doors on bottom end, along with the memory etc.
First remove the top plastic strip piece (where the power button is located) and then use a phillips screwdriver and unscrew the screws holding the keyboard in place. Gently pry it out and then remove the ribbon cable that connects the keyboard to the mainboard
http://www.refurbished-laptop-guide.com/how-to-replace-laptop-keyboard.html
Nov 04, 2009 | Compaq Presario 1200 Notebook
I need a replacement power button board for a Compaq Presario CQ50 139WM . Can you help?
This is the plastic bezel that contains the power button itself
http://cgi.ebay.com/COMPAQ-CQ50-PLASTIC-KEYBOARD-COVER-ASSE-486626-001_W0QQitemZ270454770470QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3ef85c4b26&_trksid=p3286.c0.m14
Sep 25, 2009 | Compaq Presario Notebook
I have a Compaq CQ50 laptop, there seems to be a short or bad connection somewhere just under the power button or keyboard. I say this because the power button is not working, I press the botton and...
I was working in a computer with the same problem, when you remove the keyboard and the keyboard cover at the right side of the power button you can see an small plastic cap with two wires, is the num lock led, when the wires are under the top cover and the screws of the keyboard or the cover are too tight the wire is damage and make contac with the earth shuting down the power supply, check the wires, repair if broken and take care that its not under the top cover when you assembly.
Sep 24, 2009 | HP Compaq Presario CQ50-110US Laptop
Broken keyboard keys on Compaq Presario C500 laptop
yes, all laptop keyboards can be replaced. do you have the manual for the laptop? it shows you have to remove it and take it apart. or you can download the manual from their website. you can buy a used keyboard from ebay. I don't think they are thay expensive.
Good luck
Apr 10, 2009 | HP Compaq Presario C500t Notebook
My keyboard proablem
You need to replace the keyboard. Here is a source:
http://www.machinaelectronics.com/store/buypart.cfm?id=5628&model=1958
The screws holding the keyboard are under a plastic trim strip that needs to be removed.
Nov 22, 2008 | Compaq Presario R3000Z Notebook
Presario R4000 Keyboard removal
Is this one of the keyboards that has the little plastic tabs that are springloaded holding it in at the top?
Oct 27, 2006 | HP Compaq Presario R4000 Notebook
Computers & Internet Logo
73 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
