Question about Apple Ipod Nano Second Gen. Green (4 GB) MA487LLA MP3 Player
Hi, I need help getting started. Basics-turning it on. step 1, 2 ect... Can you walk me throught it? Jackie
    Sergeant:
  • Apple Expert
  • 250 Answers
Hi jmn,
get the manuals and follow it's instructions. It's very well written for people new to the ipod.
You can download the manuals from here:
http://support.apple.com/manuals/#ipodnano
All the best
Sean
PiDigital.co.uk
Posted on Dec 31, 2008
How do get netflix working
i can help you connect netflix to your wifi network but for that i need to call you and walk u throught steps , let me know when i can call you if u r in US
Dec 16, 2013 | Samsung BD-P1500 Blu-Ray Player
Evaluate 88ft/sec*1mile/5,280ft*3,600sec/hr
Take it in two steps.
Multiply 88 ft / sec by 1 mi / 5280 ft to get 88 ft*mi / 5280 ft*sec. 88 / 5280 is 1 / 60 and ft*mi / ft*sec is mi / sec so it simplifies to 1 mi / 60 sec.
Multiply 1 mi / 60 sec by 3600 sec / 1 hr to get 3600 mi*sec / 60 sec*hr. 3600 / 60 is 60 and mi*sec / sec*hr is mi / hr so it simplifies to 60 mi / hr or 60 mph.
Mar 04, 2013 | Cars & Trucks
I have a 2000 Nissan Xterra with 2 error codes: PO325 and PO303. What needs to be repaired/replaced?
P0325 knock sensor 1 circuit malfunction bank 1 or 1 sensor, the knock sensor should be check/replaced. You can buy Haynes Repair Manuals at Pepboys that will walk you throught the process step by step.
P0303 is a cylinder misfire in cylinder 3 which may mean it could either be the spark plug, coil or the injector.
May 03, 2011 | 2001 Nissan Xterra
Cdrom is unfunctional i cant install the printer, what can i do?
connect to the internet and go to the following page: http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=41661&prodoid=46048263&BV_UseBVCookie=yes&infoType=Downloads&platform=Windows32&x=24&y=9
This is the driver for the Epson Stylus Printer.
So after downloading this driver.
Step 1 Turn on computer. Step 2 Connect Printer to computer Step 3 Walk throught the Windows found hardware menu Step 4 When asked about driver point to the newly downloaded driver.
Viola your printer is setup.
Please don't forget to rate this answer.
Apr 11, 2011 | Epson Stylus C86 InkJet Printer
Treadmill seems to slip in all speeds when weight is put on it. Changed mother board and checked belt tension all were good. Should this machine be lubed?
Pull the hood off. Stand on the sides of the walk platform and start the belt at 4mph. Take one foot and step on the walk belt hard. Look at the pulley on the front roller. Does the pulley continue to turn while the roller stops? If so, the pulley is slipping in the roller (which is a press fit). Replace the front roller or remove the motor belt from the pulley.Align the pulley with the pulley on the motor by tapping with a mallet. Drill an 1/8 hole throught the pulley and roller. Countersink the pulley hole so a small head screw will be under the pulley groves. Install screw in this hole. This is called pinning and is a pemanent fix. If both the pulley and the roller stop together when the belt is stepped on the motor belt is loose. If only the walkbelt stops when stepped on, the walkbelt is loose.
Jan 15, 2011 | Epic 425 Mx Treadmill EPTL88105 !
How do I fix a problem with the belt slipping?
hi there
it could be 2 things of this problem
1 walking belt slips easy ti fix
1th step; put treadmill in speed of 4 mph and step on side and try with one leg to stop it (be carefull) if you see walking belt stops with align key give more tension from the back of treadmill rear rollers by turning both bolts clockwise same degree with small turns till stops
if it does not help it is probably drive belt
you need give more tension on motor by using 9/16 wrenches
Nov 22, 2010 | Proform Sport 1000 Folding Treadmill...
Whirlpool Cabrio - How do I tell if my heating
If you are comfortable useing a volt meter and a ohm meter I can walk you throught the steps otherwise you need to call a repairman, If you are not getting any heat and the tumbler is turning it is possible the element is bad again only a test meter can tell for sure or you can take the dryer apart and look at the element to see if it is broken make sure the power is turned off at the breaker first also unplug the dryer.
Apr 16, 2010 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
How do I use rf barcode scanner ls4278?
Hello, if you download the user guide or product ref guide, these will walk you throught the steps you need to configure your scanner
Mar 08, 2010 | Symbol LS 4278 Barcode Scanner
I cant get the door open in shrek
i still need help on solving this shrek ps2 door to open
Feb 03, 2009 | Sony PlayStation 2 (PS2) Console
1994 2.2L toyota camry radiator fans do not work
Hi.....
The Normal Temperature Range to the Fan Start is: A/C ON 181 F.
A/C OFF 199 F. When the Engine Reach this Temperature the Fan should start.
OK. Do this simple test.
1---- Start the engine, Desconnect the ECT Switch located on the Radiator,
See if the Fan come ON. If yes, if not go to step #2
Connect the ECT SWITCH and leave the car Running and with a Temperature gage.
See the temperature, if the Temperature go more than 199 F.
Turn the Engine OFF.
Disconnect the ECT sensor and check for Ground at the WHITE/BLACK wire.
If ground exist, Replace the ECT switch.
But if not. Check the wire for any damaged, and the ground at the Front Left Fender.
Repair as need.
2---- check the Fuse link RDI FAN . 30 amp.
Check the Fuse link CDS FAN 30 amp.
Replace if need.
And Return to step # 1.
Check the Radiator fan Relay, Rad fan relay 2 and 3. Replace if need.
Ok. I hope this help on your question.
I can give to you the WIRING DIAGRAM of the Fans, But I need a E-MAIL adress to do that.
Thank you for use fixya....
Sep 25, 2008 | 1994 Toyota Camry
Apple Ipod  Nano Second Gen. Green (4 GB) MA487LLA MP3 Player Logo
81 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
