Question about E-Machines eMachines Desktop PC
My pc wont go up
I have a ? i had turned off pc cuz we were having trouble and they had to turn off power now i go to boot up pc and all i get is fan running nothing else wont even open the cd
  • 24 Answers
Try replacing the power supply.
Posted on Jan 02, 2009
Laptop wont boot up
Sounds crazy but try removing the battery unplug from power hold power button for 15 seconds Then plug in and try to turn it on
Mar 17, 2014 | ASUS U52F-BBL9 Laptop
4600 Sluggish Boot Up
sounds to me like a failing psu, you may need to test it with a psu tester if you have one available, if not any local pc repair shop should have one
Oct 31, 2009 | Dell Dimension 4600 PC Desktop
E-machine wont boot up. It has power,feels like
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes Pc
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
Sep 28, 2009 | E-Machines eMachines Desktop PC
Compaq presario a900 model a931nr wont boot, help!!!?
Sounds like the battery is in trouble (discharged) or the charger is bad. If you have access to a voltmeter, read the voltage across the power cable plug with the pack plugged into the house outlet socket. Does a lamp work when plugged into the same socket? If the pack checks ok, then the battery may not be able to receive charge. Have it checked by a dealer.
Jul 16, 2009 | Computers & Internet
No display and wont boot
A Blinking Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Power supply is easier and cheaper to replace.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 12, 2008 | Dell Dimension 4700 PC Desktop
PC wont Boot/start
The first thing you should do is swap the power supply for a known good one,
If this is a new build that hasn't worked from the start follow the instructions here:
http://forum.pcmech.com/showthread.php?t=132409
Aug 27, 2008 | Computers & Internet
Has power but wont boot up
It could be that your motherboard might be dead. Do you plug your pc into a surge protector, as sometimes there could be a surge of power that could blow circuits on the mobo. Did your computer BEEP at you. I know that sounds daft but all pc do a post b4 booting and if there is a problem the computer BEEPs, not exaclty handy as it tells you there is a prob, but not what it is.
Is the pc still under warranty. If it is then go to makers site and ask the tech guys there. If not, are you competent to take pc apart and check the internal components. It could be something simple to fix, like a loose processor fan, power couplings coming loose, or possibly your RAM has blown.
if you can supply any more details than whats in your post it would help out alot.
Jul 11, 2008 | Gateway GT5220 PC Desktop
PC powers up but wont boot
I would start with a new power box, then a motherboard. then the hard drive.
Dec 23, 2007 | Computers & Internet
E-Machines eMachines Desktop PC Logo
71 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
