Question about Kitchen Ranges
Maytag stove super capacity plus display not turn on
I have a Maytag stove call "super capacity plus", the display panel did not light up and I can not control (turn on) the oven but when I press any button (Cancel ,,etc), it lights up as "OFF", I checked an AC line with my voltmeter, it shows there is 120V AC from the line to the PCB board, is that means I need to replace the whole PCB? is the digital display come with the PCB? please advise who to do?
  • mjgundry Apr 14, 2009
    Same range, same problem. Issue started after resetting a blown breaker.
5 Suggested Answers
elhomspam
  • 58 Answers
SOURCE: Maytag gas super capacity plus
F9 relates to a bad door latch
either you need to reconnect a rod
or you have a bad latch(sometimes solenoid asembly depends on age)
Posted on May 02, 2008
SOURCE: Whirlpool Super Capacity 465
I have the same problem intermittently on my Super Cap 465. After reading the following quote from another site, "There have been cases where radio waves, electronic signals and sometimes something as strange as dimmers in lights have caused some weird problems with some computer panels in stoves like these", I tries turning off lights that might be on the same circuit and wouldn't you know it, the oven igniter circuit worked.
Posted on Jan 04, 2009
SOURCE: Jenn Aire Model SVE47600W
Thank you so much for this information. I can verify that this procedure worked (at least for me). I ordered the part from Digi-Key Corp (it was up to a whooping $.28), replaced the old capacitor, plugged everything back in and bam! A working display. There was a beeping and error message but after hitting the Cancel button on the stove, everything was working.
Note that this fixed the dimmed display only. All the other controls were still working--only the display was off. If you have other issues, this might not be a complete solution.
You need basic soldering skills, a small solder iron, a solder ******, and some rosin-core solder. The capacitor is labeled on the circuit board.
When taking the unit off the control panel the largest ribbon cable was clear plastic with embedded contacts. I'd never seen one of these before. The cable's contacts slide in behind the pins on the connector and are held against it by an insert in the connector. When I removed the insert, the clear plastic cable came completely out from the connector. I had thought I'd broken it. But just slide it back in behind the pins, aligning the cable contacts with the pins and put in the connector insert to hold them in place.
The Digi-Key part number for the capacitor is P10292-ND. I ordered 5, just to have a few spares. The 5 caps plus first class postage came to a total of $3.51. Quite a difference from the $160 for the whole unit!
Thanks again to ultigerfan for making this information available.
Posted on May 07, 2009
fixyourboard
  • 310 Answers
SOURCE: ge xl44 stove digital display clock stop working.
We see this failure due to two possible problems with the electronic control. Sometimes there is a failure that causes the display to shut off. Other times the display itself goes bad. The first case we can repair. If you send us the board we can check it out. If it is not repairable there is no charge. - www.fixyourboard.com.
Posted on Sep 30, 2009
The burners on my Maytag electric stove work intermittently. Advanced cooking system Super capacity model.
If intermittenly you mean they quit glowing at times is how mine work also and wife does not say they don't cook alright but they do turn off and on as heat requirement changes
Jan 11, 2015 | Maytag Gemini 30" Self-Cleaning...
I have a Super capacity plus maytag model MGR5750adw
-Oven igniter has bad connector. Or itself is bad.
-Or may be the On/Off switch is bad or bad connector.
Good luck
Mai
Dec 20, 2013 | Dryers
My maytag super capacity plus won't unlock after
this would be the best source look at link i hope it help out
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwjhpKi-i5TXAhVmyoMKHX_OAtMQFggnMAA&url=http%3A%2F%2Fproducthelp.maytag.com%2FCooking%2FWall_Ovens_and_Ranges%2FOven_Product_Assistance%2FHow_to_open_a_locked_oven_door&usg=AOvVaw3VNunJSAkZGld_PY0xGM3s
Oct 28, 2017 | Maytag Ovens
Maytag advanced cooking system/the super capacity plus
My Maytag , advanced Cooking system , super capacity gas stove has a problem with the oven. It looks like it lights, but most often, doesn't heat up, and I can sometimes smell gas. Anyone know what what cause this?
Jan 20, 2009 | Maytag Ovens
Maytag gas super capacity plus stove error code F9
May 02, 2008 | Kitchen Ranges
Kitchen Ranges Logo
448 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
