Question about Kenmore 15718
Sewing Machine Thread Tension problems
Hi, I have a Kenmore 385.15616
I'm trying to sew upholstery fabric and the tension on both the top and the bobbin seem to be off. The bobbin thread bunches up underneath the garment and the thread on top pulls through too quickly, making it skip off the spool and reel around the spindle.
I've tried various tension settings and stitching. It works fine for non-upholstery weight fabrics. Ideas?
  • gabeandnancy Dec 31, 2008
    A Universal one... I know, I know... do you think that will help?
    Scholar:
  • 140 Answers
What size needle are you using?
Posted on Dec 31, 2008
  • David Robinson Dec 31, 2008
    Yes it can make a difference.You should be using a green needle, size 18(110), for upholstry fabrics. Also when sewing heavy material it's a good idea to lubricate the machine before you start. Let me know if this works for you. Please rate me so I know if I helped you. Thanks.
Do the omega 420 handle upholstry thread
Most domestic machines would have difficulty using upholstery thread. Upholstery thread is generally very heavy so the tension settings would need to be adjusted on the machines. Evenso, the tension mechanisms adjustments still may not be enough to accommodate heavy upholstery thread.
Even if your machine can accommodate the thread, your machine's motor could be compromised trying to sew upholstery fabric.
Oct 19, 2017 | Omega Sewing Machines
Thread tension problems when sewing with nylon upholstery thread
Your thread may be too large for the machine to use. Try using the highest setting on the tension.
Aug 21, 2017 | Sewing Machines
My pfaff 1475 CD thread is loopy on bottom and breaks on top.
Look very closely at your sample stitching and determine which thread (top or bobbin) is looping and which is breaking. That will narrow down where the problem exists.
A top thread that loops and makes thread "barfs" under the fabric is generally an upper thread tension problem.
Try: Remove the top thread. ALWAYS RAISE the presser foot and rethread from the beginning. Set the upper tension to the midway point (probably will need to tweak this tension depending on your machine).
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Understanding Thread Tension Threads
Sewing Machine Tension
Apr 12, 2017 | PfaFF Sewing Machines
Threads bunching up on singer 7256 when i start sewing
1. I believe that your bobbin tension is too tight.
2. Your top tension should be at about four.
3. When you do your top threading check the tension before threading the needle. It should have some tension but it can't be too loose. Do this with the foot down.
4. If you have adjusted the bobbin more loosely replace it and turn the hand wheel with some fabric in place. It should come out with a nice stitch. You may have to do very small adjustments to the top tension to make the stitch perfect.
Nov 04, 2016 | Singer 7256 Sewing Machine
What are the correct top & bottom tensions for this machine?
Both tensions are preset at the factory. Normally, the bobbin tension is the last one to adjust. Most often tension adjustments are made to the top thread. The factory standard setting for the upper thread is the midway point between the high & low numbers, however, each machine is different and may need slight readjustment.
The tensions are correct when both, the upper and bobbin, threads meet in the middle of the fabric. Tension is not static. Differing fabric weights, thread, or needle sizes may necessitate a change to tension. Lighter weight fabrics like chiffon will require a different tension setting than heavy fabrics like denim. Always test first on scraps of the fabric you plan to sew. Get the tension set the way you want it before you begin sewing your project.
Learn the Ins and Outs of Troubleshooting Sewing Machine Tension
Adjusting Sewing Machine Tension to Prevent Problems
How to Adjust Tension Sewing Machine
Mar 04, 2016 | Sewing Machines
I have a Kenmore sewing machine - 12 stitch model which I bought in the 70's. I am having a tension problem and can't seem to fix it. What is the normal setting for the top, and bottom?
Hello
Load your Kenmore sewing machine with the right thread and bobbin thread for your project. If you use the wrong weight thread for your fabric or severely uneven weights of thread, this can cause the appearance of a tension problem when it is, in fact, a thread weight problem or a problem with your sewing speed. If you go too fast, you will break the thread. If you go too slow, you can cause loops. Uneven pressure can cause stitches to vary greatly.
Test your Kenmore sewing machine's tension by sewing on a piece of scrap fabric. If your tension is way off, then test on some basic cotton or a firm blend simply to get your tension right. Do not try to start adjusting your tension on silk or leather. Get a base adjustment on a more standard fabric first.
Look at the top threads and bottoms threads. If the tension is off on one side, it will usually affect the other side slightly. So select the side that looks more maladjusted to start adjusting the tension.
If the top thread is too loose or too tight, you will need to adjust the tension dial. This dial is usually located a few inches above the needle on the Kenmore machine body. Usually, your machine will have markings to indicate which direction tightens the tension. If these have worn off over the years, watch the dial as you turn it. If it appears to move toward the machine body, then it is tightening.
If the bottom thread is too loose or too tight, then you will need to open the door to the bobbin case. On some Kenmore models, there is a little screw near the bobbin case that can be adjusted slightly to adjust the tension. On other Kenmore models, there is a screw on the bobbin case itself--not on the bobbin, but on the bobbin's casing. This will also adjust the bottom thread tension. Adjust the bobbin thread tension to make slight changes.
If the thread is looping severely on one side, the thread weights might be off. For instance, look to see if you have a lightweight thread on the bobbin and a heavyweight one on the top. If the thread keeps breaking, the top tension or bottom tension could be too tight or the thread is too lightweight for the material you have selected. Check your combination of threads and material. Also make sure you are using the right weight needle and the right foot for the sewing step or project you are working on.
If your Kenmore sewing machine's tension is off severely or if you have not used your Kenmore in a long time, then you might need to take your machine in to be serviced. Sometimes, the inner parts need to be oiled or the entire machine might need to be cleaned and calibrated by a professional. If you sew a great deal or if your machine sits idle a lot, both situations will usually require some servicing to keep your Kenmore sewing machine and its tension in perfect working condition.
Jul 11, 2011 | Kenmore 15358
No bobbin tension
If the thread is loose on the bottom of the fabric, it's actually the top thread is too loose. Think of 2 little elves playing tug of war in your machine, one on toip and one underneath. If you have loops on bottom, the top needs to pull harder (tighten top tension)
Mar 18, 2009 | Kenmore 15516 Mechanical Sewing Machine
Kenmore sewing machine older model 1345381
hi! there wind thread on bobbins winder 4 times by your hand rotate clockwise,insert in shaft bobiins winder on top of your machine near hand wheel push latch to engage loop thread on disc winder tension start your machine on pedal foot automatically winder disengage if already filled up of thead pull this winder and insert to bobbins casing insert thread to slot and pull out winder 6411c87.jpgshould rotate clockwise as shown.insert on shuttle hook casing and close cover needle plate.next thread your upper
97b52e8.jpgthreading tension as shown on red threading from spool pull threading and loop to dial tension threading and insert thread to lever needle and to needle hole tip. pull tread under the needle foot and feeder tooth.rotate hand wheel counter clockwise to hook up thread bobbibs and appear at top of needle plate,teo thread shoul appear,set dial tension to # 3 and stich to # 8 range to # 12 depend on fabric and layer of fabrics and set on straight stich sewing,let needle on upper position insert fabric for trial sewiing.put down foot needle lever. manually by hand rotate for assurance needle is free to sew if obtruction on loop bobbins thread occurs adjust all tension gradually then try again until free from sewing w/o problem star sewing.
Aug 08, 2008 | Kenmore Drop-In Bobbin 505S-21BH...
Sewing with drapery material
Switch back to regular thread. Upholstery thread is used for seams that will get lots of stress (as in upholstery; although I use regular thread in upholstery and have no problems). For draperies, regular thread is fine.
Jul 24, 2007 | Husqvarna Viking 1
Sewing Machines Logo
343 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
