Question about JVC DR-MV7 DVD Recorder/VCR
Recording from VHS to DVD
HOW DO i KNW HOW MUCH DVD ROOM IS LEFBE T SO I MIGHT RECORD MORE ON THE SAME DISK AND HOW O I FINISH A DISK SO IT CAN'T
  • 8,596 Answers
First, you will need to know if the program was recorded in XP mode, SP mode, LP mode, or EP mode. To find out how much room there is left, put the dvd in the tray and press the Disc Menu/List button on the JVC remote. This will display the title and how long it is - write that number down. It will also say either "XP,SP, LP, or EP" - write down that mode. In XP mode, a DVD will hold 1 hr and 20 mins worth of prgramming - MAXIMUM. SP mode = 2 hours. LP mode = 4 hours. EP = 6 hours. So, if your program is one hour, and you recorded in LP mode, you have 4 - 1 = 3 hours of space left for recording on that disc.
If you finalize a disc, you will no longer be able to add more programs to that disc, unless the disc is a + or - RW disc. Also note that finalization requires some disc space, so if you recorded a program that is exactly 1hr and 20 mins long, and you recorded it in XP mode, then the disc will probably not finalize correctly.
That being said, the finalization directions are on p. 23 of your manaul: Title --> Finalize --> => --> find finalize --> Enter --> OK --> Enter
Now it will play on other players.
Here is a link to the user manual:
http://resources.jvc.com/Resources/00/00/93/LPT1133-001A.pdf
-Tha Mp3 Doctor
Posted on Dec 31, 2008
How do I finalize my disk once I have finished recording from VHS tape. How do I get the finalize to light up on menu on screen?
If they are +RW discs they cant be finalized and can only be played on +RW compatible players. Use +R, -R or -RW if you need a wider compatibility (DVD-VIDEO). Finalizing is quite easy following directions in the manual.
Apr 20, 2013 | Magnavox ZV427MG9 DVD Recorder/ VCR
What is the difference between a DVD+RW and a DVD-RW.
DVD-RW
It is the re-recordable version of the DVD-R. To use this type of media you will need to buy a DVD-RW recorder. The DVD-RW recorders usually record DVD-R, CD-R and CD-RW media, too. Similarly to what happens to DVD-R, DVD-RW disks can be played in newer commercial DVD players without any problems. Older commercial devices cannot recognize the media, refusing to play the disk. To play a DVD-RW disk, commercial players need the disk to be finished. After finishing the disk, you can only record new data in it by reformatting it, which makes you lose all the recorded data.
DVD+RW
It is the re-recordable version of the DVD+R and everything that was said about the DVD+R is valid for the DVD+RW. Only the newest DVD players play movies recorded in disks using this format. There are recorders on the market that can record both DVD-RW disks and DVD+RW ones. These recorders are called DVD?±RW. Similarly to the DVD-RW, the disk needs to be finished to be played in commercial DVD players, and to record new data in the disk after having finished it requires reformatting it, which makes all the data in it to be erased. DVD+RW recorders are usually capable of reading DVD-RW disks (but not of recording them) and vice-versa.
There you are.
Aug 22, 2011 | Acer Computers & Internet
When recording two vhs tapes back to back on one disk, it will not finalize. But, will finalize if one tape is recorded. Mind you now each tape only has one half an hour recording on them, and the disk is...
The disc requires some space for the finalizing process. Two half-hour tapes take up all the room on the disc and leave nothing for the process. You'll need to record at a lower speed.
Feb 26, 2011 | Cameras
How to record a vhs tape to dvd on a samsung 1080
Hello
1.The VHS/DVD player must have recording capabilities.
2 Connect both players to a television so that you can make sure you are recording the appropriate content. You can also monitor the speed at which the VHS is copying to DVD.
3. Place the VHS in the VHS player and the blank DVD in the DVD recorder. You will need to use your remote and go through the menu options to choose the correct format for recording. The formats should be clearly labeled and outlined in your instruction manual. Choose the option that will read something like "VHS to DVD." You may also have to choose recording speed, which varies per blank DVD that you purchase. Every player is different, and every menu will vary slightly. If you have questions, refer to you individual manual.
4. Select the option that works best for you and hit "Play" on the VHS player and "Record" on the DVD recorder. To play the finished DVD, you will select the playback option.
THANK YOU
Dec 14, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
I have old home movies on these tapes.. I am looking into buying the Pinacle Dazzle DVD Recorder (convert) will this convert my tapes to DVD? Does anyone know?
You already have Movies on TDK E-HG 120 VHS tapes; All you want is to Transform the media on the tapes into another record Media or on DVD.
The following process would make possible the project
1. A DVD Recorder device would transform the movies already on one media to another media.
Note: The recorder that would be acquired should have a feed area for the VHS tapes on one hand, to be played, while on the other hand, a DVD disk area from which disk medium would be recorded.
Important Notes.
The devices required to make the process achievable includes
1. The DVD Recorder or Player alsoo known with multi perpose functionality for signal convertion capability
2. The DVD recordable disks on which to record a movies onto.
Caution
The process of recording would require selection features determinable on the recorder device else would produce movies with undesireable features
For example; VHS movies are appear in decodeable formats integral when displayed on VHS players. The caution is to select a signal conversion format suitable for movies that have to transform between recordable media.
1. A DVD disk medium has formats as design specification and on which requires consideration when attempting to transfer multi media or motion pictures.
Type of formats of decodes
NTSA standards
PAL standards
Mescem standards
NOTE;
Whenever the option is available, select NTSA or PAL for appropiate code transformation
Your DVD RECORDER DEVICE SHOULD HAVE THE OPTION TO RECORD CONSIDERING MOVIES ACROSS MEDIUM TYPES
REMEMBER;
consult professional advise before acquiring an devices and mediums
If any consultation is required, refer to user guides or manuals of the devices in question.
Consult a technical expert when the need requires it.
Dec 02, 2010 | TDK E-HG 120 VHS Tape
I need help converting vhs tapes to dvd+r
If you have both a VCR and DVD recorder there is no problem. Just connect the A/V output from the VCR to the A/V input of the DVD recorder. Start the tape and press record on the DVD recorder. (these connection are RCA type ans coloured white, red, abd yellow. Just connecxt them colour to colour. Couldn't be simpler. When the recording finishes, transfer to an optical disk. After finalizing, the VOB files from the optical disk can be converted to mpeg4 or any other format you desire using your PC.
Jul 10, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Losing Audio Halfway Through Recording
The audio failure sounds more like a VHS player failure than a DVD software/recorder failure. Both audio and video are transferred at the same time to the DVD, and as long as the DVD recorder is working, that's really all there is. I would check the VHS player and confirm that the sound actually works all the way through.
Mar 02, 2017 | Pinnacle Dazzle DVD Recorder
How to finish a transfer from VHS to DVD?
When you finish recording from VHS then press Stop on dvd recorder and finalize dvd, this option would be available in dvd menu.
After finalization, that burned dvd can be playback on any dvd player.
Apr 19, 2009 | Televison & Video
Panasonic dvd recorder wont record or play
It is also possible that you are trying to record using an already used -R or an unformatted RAM disk.
Mar 07, 2009 | Panasonic DMR-E55 DVD Recorder
JVC DR-MV7 DVD Recorder/VCR Logo
170 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
