Question about Dryers
Roper Dryer Won't Turn On
I have a Roper dryer that wont work. Model # RED4440SQ0 I have checked the switch and it is fine, I have also made sure there was power coming from the house. Any suggestions would be helpful. Thanks!!
  • kathy kat Jan 14, 2009
    i changed the switch and didnt work i even changed the push to start button but no success, can it be anything else?
  • Dryers Master
  • 8,220 Answers
Roper Dryer Won't Turn On - 2b3eba2.jpgThis fuse mounts on the rear blower housing. If lint builds up in the dryer this puppy will melt and shut down the dryer door circuit. It will be just as if you opened the door. Simply replacing it will get the dryer going again but failing to properly clean out the dryer will result in more fuse failures.
Posted on Dec 31, 2008
Dryer too hot
dryer has a safety a high limit switch in back of dryer at heater element should be only 2 wires small round size of a nickel turn power off first
Jun 20, 2012 | Roper Dryers
Roper electric dryer model mod# red4440sq0 just quit heating up?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 17, 2011 | Dryers
I have a roper dryer red4440sq0 that will not turn on.. I have checked all power its going to the dryer and hitting what it needs to hit and suggestions?
I bought this dryer 2 years ago. After exactly 1 year, the heat stopped working completely. It turned out to be the Thermal Cutoff device ($20). Then, just last week, the thing stopped working completely. It took me all of 10 minutes to determine that it was the Thermal Fuse (http://www.appliancepartspros.com/part_details.aspx?part_id=3132867), just by using my continuity detector on the two terminals. I unhooked the terminal wires, stuck them together, and the dryer turned on fine. They count on people buying new dryers completely whenever one of these dinky little parts made by child laborers in Asia fail. The fuse is $10 at the site I just linked.
Nov 09, 2009 | Dryers
Dryer not turning on
Yes sounds like bad timer. Price is retail but should be available online cheaper via eBay or amazon.
Aug 24, 2017 | Roper RES7646KQ Electric Dryer
I have model red4440sq0 and it it not heating..
It's the Thermal Cutoff device. Mine stopped working after exactly 1 year. (http://www.appliancepartspros.com/part_details.aspx?part_id=3094244).
Jul 10, 2009 | Roper Dryers
Dryers Logo
391 people viewed this question
Top Dryers Experts
