Question about Mitsubishi WD-62825 62" Rear Projection HDTV
Im tryn to hook up my playstation3/blue ray dvd system with the hdmi card but cant find it on the tv
  • 179 Answers
Looking at the rear of the set it is on the left side. it si marked mono-link. remember this is only a 1080i set.
Posted on Dec 31, 2008
LG blue ray won't play sound from RCA sound bar. HDMI cable is hooked into HDMi slot on TV
the details you provided were very vague, however from my experience when a device is connected to another device via and audio capable hdmi cable, that device renders it audio output to the device its connected to and normally turn off all other audio outputs beside optical- I would assume there is an option in the blue ray player to turn off hdmi audio, which will in turn activate other audio outputs- you may also look for audio out port on your tv, it is ideal to connect the sound bar directly to the tv set audio out ports. To sum this up,
if you plan to use your player via hdmi cable you need to turn off hdmi audio output on the blue ray player and the plug an audio cable from your blue-ray player to your sound bar
you may also as i said connect your sound bar directly to your tv, the issue is most tv sets now a days do not have an audio out port, if you do then everything you play thru your tv will have audio via sound bar
there are several way to go here but unless your sound bar has hdmi av switching capabilities (im sure not) this is one of the most simple--Good Luck.
Jan 29, 2013 | Audio Players & Recorders
Best way to hook up TV with one HDMI to blue ray DVD and RX-V465 receiver with Direct tv
Has Direct tv STB HDMI output?
Best is to connect all your sources (BD, DVD, STB, PS3) to yamaha receiver and connect yamaha hdmi-out to TV's HDMI-in.
Dec 29, 2009 | Yamaha RX-V463 Receiver
I just bought a Blue Ray player but my surround sound has a dvd player built in and only one input which I have my new Sharp TV plugged into. How can I hook up my Blue Ray . I have the HDMI cables
Depending on if your surround system has a hdmi input or not. if it does you can connect the blu-ray player to it. If it doesn't have an hdmi input you will have to run the hdmi cable from the blu-ray to the tv then run a set of rca cables (red and white plugs) from the tv audio out to the surround systems' audio input jacks to get sound through the surround system. Most surround systems don't have an auxiliary input for another video device.
Nov 21, 2009 | Onkyo TX-SR606 Receiver
No owners manual can't get new blue ray dvd player to work on tv
Here is the manual:
http://www.hdtvsolutions.com/pdf/JVG%20HD52G56G.pdf
When using the HDMI connections you may have to tell the DVD to output to that port.  Also you may have to connect additional sound cables from the DVD output to the TV.
Jun 02, 2009 | JVC HD-52G786 52" Rear Projection HDTV
Blue ray lap top to hook up to tv with cable
If your laptp has Blue Ray DVD it likely has an HDMI out jack. Connect this to the HDMI input of you tv. If you TV does not have and HDMI jack but had a DTV jack then get an HDMI to DTV adaptor.
Apr 26, 2009 | Televison & Video
I bought a panasonic 50" viera plasma tv (50hd18) a panasonic suround sound sytem (scpt956) and a panasonic blueray player (pbd35ak) Im trying to hook this system up using the hdmi cables but my...
See if oyu can buy a HDMI selector box, does the sound system have a dvd player in it? IF so I would go with S-video instead of hdmi, save the HDMI for the blue ray player. What is the very first item you have listed up there? PAnasonic what? LEt me know, hope this helps.
Dec 11, 2008 | Panasonic Televison & Video
Best way to connect new system
After trying several ways, we decided the best picture was to run the blue ray (out) directly to the TV (in) with an HDMI and another HDMI from the sat. box(out) to TV(in), then optical audio from TV (out) to receiver (in). This way you don't have to change channels on the reciever when switching from TV to DVD. Remember that HDMI is one cable that supports audio and video. If you are using all Samsung products and want to use one remote, using the Anynet feature, I think it has to be connected with an HDMI. I'm going to try connecting an HDMI too from the reciever to the TV to see if this feature will work. It does with the Blue Ray.
Nov 21, 2008 | Samsung HT-AS720ST Theater System
Home cinema system whafardale to my matsui lcd tv
You need an audio cable as well. It is stupid i went into currys and they said for your home cinema system to work you need a HDMI cable and a audio cable its stupid that they don't come with the system really.
Nov 09, 2008 | Wharfedale DVD-M3 DVD Player
Mitsubishi WD-62825 62" Rear Projection HDTV Logo
37 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
