Question about Roper RES7646KQ Electric Dryer
Roper Dryer Won't Turn On
I went to turn on my dryer and it wont work. I have checked the door switch and it is fine. I do have power from the house. It is a Roper model RED440SQ0. Any help would be great. Thanks
  • 4 more comments
  • kristaandtra Dec 31, 2008
    Thanks will try that!!
    I replaced the thermal fuse and still nothing!??
    Is there a second thermal fuse in my dryer?
    Electric bill is paid. LOL And all the door stuff works fine. While trying to check things out it just started on its own and then wouldn't start again??
  • rickisme Jan 16, 2009
    I have 'almost the same problem,' but the dryer was working and I opened to check on the one item that my daughter was drying and it wouldn't turn back on. If the thermal fuse blew from heat related to lint, seems strange that it only happened after I checked it...might it more likely be the switch....Can you tell me how to test the door switch. Thanks
  • Anonymous Jan 18, 2009
    my maytag smell like something burnt and now wont start
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
Ok...almost same problem...resolved by replacing thermal fuse by blower....so I guess the thermal fuse can just go with a little surge from opening closing door switch if it was already on its way out...or something...but simple fix anyway....thanks for giving me the order of things to try!
Posted on Jan 16, 2009
  • Roper Master
  • 8,220 Answers
Quick check list starting with the most likely to the mostly likely NOT:
Fuse Roper Dryer Won't Turn On - edfbadd.jpgmounted on the blowers housing this puppy is wired in with the door switch. If the lint in the dryer gets to blocking the exhaust then this puppy gets all hot and bothered and melts, causing the whole machine to come to a screeching halt just as if you have opened the dryer door. Clever ain't it? Clean out the lint and replace this fuse.
Posted on Dec 31, 2008
  • 2 more comments
  • Dan Webster
    Dan Webster Dec 31, 2008
    Of couse the fuse is the most likely but if it turns out to be good then the door switch itself would be next followed by the door switch actuator, followed by the timer, followed by the motor, followed by the electric bill being unpaid. Thank you Kimosabe for your excellent rating
  • Dan Webster
    Could be the start switch. Did you try reseting the breaker, check the cord, the receptacle, and the power terminal where the cord connects to the dryer. If all of that is good then I would say you are down to a bad motor or a bad timer.
  • Dan Webster
    Their is not a 2nd fuse. The hi limit would not kill the power to the motor. The door switch actuator could be broken. This dryer has a little arm which sticks out a hole and when the door gets shut on this arm then the switch will have continuity.If that arm breaks then the dryer will not work.
  • Dan Webster
    Dan Webster Jan 01, 2009
    Are you checking each component for continuity with one wire removed so that you will not get a false reading?
Kenmore model 110.60817990 will not start
I would check the door switch first. Lot of times you can tell right away if it is broken the lever will be loose or you cannot hear a click when you wiggle it. If that is fine you remove the back cover and check the skinny fuse mounted on the filter housing next to the control stat. If it is open remove and clean out the filter chute before replacing that fuse.
I recently worked on a roper dryer which is identical to yours:
Aug 16, 2012 | Kenmore Dryers
My roper dryer worked fine yesterday. It won't work today
remove back cover then locate the blower housing in the back,its round on this is a thermal fuse appx. 1" X 1/4" with 2 wires from it,this is the thermal fuse test it,if its open on continuity its bad and the dryer wont operate the pat number is FSR# 3392519
May 21, 2012 | Roper REX3614KW Electric Dryer
Timer clicks on dryer but want work
A lot of times the small white fuse will melt and kill the door switch circuit on these.
I removed a bunch of junk from this one's blower housing/filter chute:
So if your door switch is fine check the thermal limit:
Ya might want to give that Roper dryer a good going over. I did a complete overhaul of a Roper dryer and took some photo's for DIY folks: Roper dryer tuneup
Nov 02, 2011 | Roper REX4634KQ Electric Dryer
My kenmore dyer about 16 yrs old died on me in mid dry. It will not start now. I checked circut breaker in home was fine. I checked continuity in push to start switch,Hi limit thermostat, 250 degree therm,...
Hello there and thank you for choosing fixya
If your dryer doesn't work at all, it could be because of problems with:
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker. Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. To determine if the door switch has failed, watch the part testing video at the bottom of this page. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.) To determine if the thermal fuse has blown out, watch the part testing video at the bottom of this page.
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block that it is attached too
Jul 31, 2011 | Roper REX4634KQ Electric Dryer
I have a roper dryer (REL3612BW2) that will not turn on.
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Here is a link to the part you will need. Below is a video to walk you thru the repair process for the switch.
Dec 31, 2010 | Roper Dryers
Dryer wont start on my roper dryer. Timer is working but wont start
Check for a blown thermal fuse. It's about an inch long and is located inside the rear of the dryer usually attached to or near the exhaust duct. It can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a blown thermal fuse. Sorry for your trouble and I hope this helped. Best wishes.
Sep 23, 2009 | Dryers
2b3eba2.jpgThis fuse mounts on the rear blower housing. If lint builds up in the dryer this puppy will melt and shut down the dryer door circuit. It will be just as if you opened the door. Simply replacing it will get the dryer going again but failing to properly clean out the dryer will result in more fuse failures.
Dec 31, 2008 | Dryers
My roper dryer stopped working
right above the door where it closes, there should be a door switch actuator, although your closing the door it might not be activating door switch.
Feb 24, 2008 | Roper REX4634KQ Electric Dryer
Roper RES7646KQ Electric Dryer Logo
1,618 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
