Question about Palm Tungsten E2 Handheld
Unable to recharge
My palm won't recharge and i can't find a repairer in australia. the battery power was low and when i went to recharge my palm pilot it didn't do its usual "bleep"
  • 4 Answers
Hi Soukie: I have dealt with wide of Palm of repairs, especially E2 Palm Tungsten, so let me know if you are still having problems and I can assist you. Yes, there is someone who can repair palms in AUS, me.
Posted on Oct 01, 2007
  • 29 Answers
Hi Here is a link for the Palm AU site. You could probably place a support request in there and get the relevent phone numbers for repair. http://www.palm.com/au/ Repair :: http://www.palm.com/au/support/contact/repairs.html In the Asia Pacific region, Palm offers 90 days of complimentary telephone Technical Support on most Palm-branded products from the date of first contact. After 90 days, telephone Technical Support is available for US$12 per incident. 1 800 350 535 Phone 02 9475 1241 Fax Monday - Friday, 8:30am to 6pm (AEST) For support on the Treo 650 BlackBerry Connect solution, please contact your mobile operator directly: Optus: 1300 130 765 Telstra: 1800 010 253 Technical Support For technical questions such as synchronisation, software, upgrades and other technical-related issues: Learn more Customer Care For sales assistance with Palm handhelds, mobile managers and smartphones: anz.service@palm.com Repair For repair of Palm handhelds, mobile managers and smartphones: Learn more Have a Great Day!!
Posted on May 04, 2007
Low battery icon on, won't recharge
Hi. If you do some research, you will find that this is a common issue with the Harmony One remote. I suggest using an elastic band to hold the remote firm onto the charger. That works for me.
Aug 03, 2011 | Logitech Harmony One Advanced Universal...
Camera turns off itself
This is likely because:
  1. You are using the wrong types of batteries (Alkaline, Ni-Cd or Ni-MH batteries are recommended for digital cameras) NOTE: don't mix different types.
  2. The battery is out of charging cycles and won't retain charge. (Most rechargeable batteries can be charged only about 1000 times after which they won't hold charge)
  3. The batteries aren't 'powerful' enough. (low quality rechargeable batteries with low capacity shouldn't be used on digital cameras, Always buy batteries specialized for cameras (from camera stores or studios))
  4. The wrong battery type is selected in the camera's settings. (Most cameras let you select the type of battery you are using from it's settings. Browse through the settings and see if this is the problem)
Hope that fixed it. Good luck.
Apr 28, 2011 | Nikon COOLPIX L4 Digital Camera
Completely dead. new battery won't work. need to retreive info
Probably the firmware of the mobile is corrupt better that you take it to a Palm sevice centre and get it repaired.
There would be a loss of data if the firmware is changed.
Apr 20, 2010 | Palm Treo 650 Handheld
My Palm T/X would not recharge. I thought it was
ime 358046014376751
sharp t_mobile side kikck
enter coed to enable sim card
Jul 07, 2009 | Palm TX Handheld
Can I get my z22 repaired?
actually palm does not want u to change the batt they want u to buy a new device from them but u can do it
first check the charger voltage thru volt meter or confirm from other ways that ur charger is working fine , i am pretty sure that ur battery is Dead and it is difficult to replace but can be done if u have little expertise becoz Palm does not want u to replace the batt they want u to buy a new one when the batt is dead but u can do it thru following procedure
First check the specs on batt by taking it iut like this
How to Replace the Battery on a Palm Z22
The Palm Z22 is powered by a rechargeable lithium-ion battery which, in theory, can be recharged an infinite number of times. In practice, however, the lifespan of a rechargeable battery is finite. Replacing the battery yourself is possible if you have some skill with tools and a bit of patience.
Instructions
Difficulty: Moderate
Things You’ll Need:
* Star-bit screwdriver
* New z22 battery
* Palm z22
What to Do
Step1
Pull down on the back cover of your Palm Z22, and remove the cover from the device.there is a trick to it. The little translucent bezel surrounding the USB connector can be snapped out, revealing two T-5 (Torx) screws. Remove the bezel and the two screws and the other three sides will separate with some gentle prying as you have already discovered.
The best way to remove the bezel seems to be to slip a knife (or a thin fingernail) into the joint closest to the display. It's a tight fit but you don't have to separate it very far to get it to pop out.
The battery is not "user replaceable" - i.e. it is soldered in place, but you can buy one online if you're prepared to do the solder work.
Step2
Loosen and remove the screws from the Z22's casing using a star-bit screwdriver.
Step3
If there are tabs present on the circuit board, you will need to stop immediately. Consult with a technician about removing the tabs.
Step4
Find the battery. Move it out of the case so you can have better access to the power supply lead.
Step5
Pull the power supply lead from the battery. Grasp the base of the plug firmly and disconnect in one smooth motion.
Step6
Remove the old battery from the case and insert the new battery into the same position and with the same orientation.
Step7
Replace the rear cover on the Z22 and charge the new battery for at least four hours before use.
Tips & Warnings
* Use firm steady pressure to open the case. Sharp blows and delicate electronics do not mix.
* A star-bit screwdriver is not the same as a Phillips screwdriver. The star-bit has a six-flanged head which looks a little like an asterisk when viewed head-on.
* If your battery has a blue casing on it, do not attempt to change the battery.
How to Buy a Replacement Battery for a Palm Z22
The Palm Z22 is powered by a rechargeable lithium-ion battery. This means that you can use it forever, right? Well, no, because even rechargeable batteries wear out eventually. Since Palm currently does not offer replacement batteries, you will have to track one down yourself. Here is how to buy a replacement battery for a Palm Z22.
Instructions
Difficulty: Moderately Easy
Things You’ll Need:
* Palm Z22
Step1
Write down the technical specifications of the Palm Z22 battery. The battery is 3.7 volts and delivers 950 mAH.
Step2
Shop at your favorite local retailer, electronics store or battery specialty store. Take advantage of the sales staff’s knowledge in your hunt for a battery that is compatible with the Z22. Bring your Palm Z22 to the store to be sure that the battery fits.
Step3
Search for an online retailer who carries the Z22 replacement battery. Once you have found a couple of vendors that have the goods, shop for the best deal. Remember to include shipping costs into your decision.
Step4
Get information about return policies or money-back guarantees before shelling out any money. Returns may not be an option for the Z22 replacement battery due to the specific complications involved with lithium-ion rechargeable batteries.
Tips & Warnings
* You will need a tool kit to change your battery. The screws on a Palm Z22 require a star-bit screwdriver to loosen the shell.
* Correct use of your battery charger will prolong the life of your batteries, whether the original issue or replacement.
* Be sure that your batter is compatible. You don’t want to fry the Z22 with a high-powered, incompatible battery.
Mar 16, 2009 | Palm Z22 Handheld
Battery Low Message - Won't recharge
did u try connecting it to your computer like i do mine
Jan 24, 2009 | SanDisk Sansa e250 MP3 Player
Palm tungsten e2 will not turn on, replaced batttery,
Plug you E2 into your PC for 8 hours to slow charge. Press reset button on back and later in life your E2 will come on by itself.
Dec 23, 2008 | Palm Tungsten E2 Handheld
After down loading music player went off won,t recharge
This player is effectively destroyed by using it on a computer that runs either Windows Media Player 11 or Vista. You can try doing a repair in Philips Device Manager, but this is very nearly an obsolete mp3 player.
Nov 27, 2008 | Philips GoGear HDD1830 MP3 Player
Palm Tungsten E2 Handheld Logo
288 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
