Question about Panasonic KX-FL511 Plain Paper Laser Fax
"DRUM LIFE OVER" KX-FL511
Same message when newer drum and toner from a less used machine installed. How get it to print the 7 faxes in memory since the error.
Then there was a 10 hour power outage, but with power back on same messages appear: 7 new messages, DRUM LIFE OVER, CHANGE SUPPLIES, and the date
Remove and reinstall paper had no effect, printing setup instructions also had no effect. Print was clean and clear.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
Just change with new drum and toner.after replacing when msg gone just press start.u will receive ur faxes in memory.MIAN AKHLAQ
Posted on Jan 01, 2009
Panasonic KX-FL511 fax, have replaced the drum kit twice now, following the install instructions with drum (and same instructions in manual). Machine still will not reset counter or recognize the new...
after replacement of drum when you close the the cover just wait for few seconds to reset the drum
machine will take one cycle. do not open lid before comletion of reset cycle done.
Feb 12, 2010 | Panasonic KX-FL511 Plain Paper Laser Fax
Panasonic KX-FL512 fax drum life error
You need to follow the instructions that came with the drum as you need to reset the internal counter.
Dec 06, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
I have a Panasonic KX-FL511 and just changed toner now it prints copies with vertical lines thru them
The drum section may need to be replaced check the toner cart. that you installed is it spilling toner onto the drum section of the cart.
Aug 03, 2009 | Office Equipment & Supplies
Error Message Drum Life Over, Replace Drum
The "drum" referred to is the imaging drum which is replaced separately from the toner cartridge. The drum life is rated for a certain number of copies, and the printer is telling you it's time. Replacement drums are available at big-box office places and from many online sources. Just do a Google search for "kx-fl511 drum". The new drum just slides in much like the toner cartridge, so replacing it isn't difficult.
Apr 08, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Drum life over
have u changed it with new one or used .process in fax when we replace it with new one it take some time for running .when it complete his circle error finishes from memory .if machine is off in this time or any other trouble it will create the problem .just take a drum from any same fax and put this in fax after running i think error will disapeear.
Dec 16, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Keep Adding Toner to Panasonic KX-FL511
kindly follow this instruction
but doing this will erase all the message in the memory
press menu #9000*550 start
unplug the unit once heard the beep
after 10 seconds, plug it again
Jan 28, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
DRUM REPLACEMENT CODE
How to Reset the “Replace Drum Cartridge Soon” Message on a Panasonic KX-FL511
[Menu]
[9000]
[*] (Will display P-SF)
[6722]
[Fax Start]
[Menu]
Nov 18, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
Panasonic KX-FL511 Plain Paper Laser Fax Logo
812 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
