Question about RCA G36705 36" TV
RCA CTC-197CE2 HI I have a Model simalar to the one in the Photo, originally it had a HV problem, I fixed that part, now have raster, menu,and no station Audio, however when setting up in the menu, it scans for channels, when done it says "0" channels put into memory or something like that, I had a different RCA set with the same problem, replaced the tiny dual SIP Chip in the Tuner and fixed it, I have done this twice already on this one with no luck, any other ideas as too what might be the problem? Mark
4 Suggested Answers
  • 12 Answers
SOURCE: I have an RCA converter box hooked up to an RCA tv
Basically, you cannot use the coax connections for both the VCR and the RCA converter box. I would hook up the phono/cinch connectors from the VCR to the TV if you can (these are also called RCA connectors, but I'm avoiding using that name so we dont confuse the digital receiver with a cable/connector name that is the same here). There should be a yellow one for video and red/white ones for left and right stereo. I believe the RCA converter comes with a three headed cable that can do this for you. With this configuration, you can set the TV to input on these connectors and the VCR should always output there. Once that is set, you can still use the converter box to receive the signal from your antenna, then run the coax to the VCR. Now, the VCR will always have to be set on channel 4 in your setup and you will need to manually change channels on the converter box for it to record a show. Does this make sense so far?
Posted on Feb 27, 2009
  • 4 Answers
SOURCE: Manual menu button not working after adding channel-no RCA remote only disconnected DirecTV remote
Normally if you unplug the tv for 10 min everything resets, if not look behind for a reset button
Posted on May 13, 2009
  • 8457 Answers
SOURCE: Need 1992 Remote Control For RCA ColorTrak TV Set
Tries 1-800-Factory remotes originals Website.
U get same as the original remote.
Posted on Aug 17, 2009
Tv thomson black screen
this a problem from Raster, coming from HV flyback, rectifiier, horizontal output, and circuit from HV. repair.or go to the repair shop TV for fix it.
However you must reset the code, download from www.fitness.manualsonline. com or memorex.com or www. remotecodelist.com and try it again.
God bless you
Jul 22, 2012 | Thomson RCT311DA1 Remote Control
I have an old sylvania 6419 ctc 19 inch TV. I have a DVD player input in to the RCA inputs in the front of the TV but I do not have the remote. Is there any way to switch the TV to Video mode from the...
Tries tv manual channels buttons up or down few times some analog tv will let go into the video mode.Not,try website like Remotes.com to buy the tv original remote.
Jun 13, 2011 | Sylvania 6419TE 19" TV
I need a datasheet of TV RCA odel FXR, year 1988
Necesito un plano de TV RCA Modelo FXR 425-E, un amigo necesita conocer con que Voltaje trabaja el Fly Back
Jan 29, 2010 | RCA F32450 32" TV
Ctc 179 service program
No need for the answer I have the setup instructions for the rca tv. I am a tv and computer technician and always carry a sheet with these instructions as I work for company like Sears on tv, projection tv, audio and other electronics, thanks for the help.
Dec 30, 2008 | RCA G35831AT 35" TV
RCA 32F530T
No you can get a replacement from Suburban Electronics
1-800-341-5353
Give the model number or if you can fine the CTC # they can get you a sub for around $18.00 plus SH
Jul 23, 2008 | RCA Televison & Video
Turns on then off
That model has a history of bad flybacks and HV splitters. Can you look on the rear tag and let me know which chassis version you have either a CTC or PTK number?
Jul 21, 2008 | RCA P52926 52" Rear Projection Television
Rca ctc 169
Did you replace the STK convergence IC's yet? If not, thats your trouble, or you have a plug in the wrong place. i doubt if the yolk is bad, as that would most likly blow out the horizontal output transistor and the set would be dead. Good Luck, Please do not forget to rate this thread.
Dec 07, 2006 | RCA P46924 46" Rear Projection Television
How would I locate the IC's
hi this model rca sounds framilure but model num on rca are more for cometic purpuses look on back and post chassis num ctc ext. and simpton mybe i can help with your convergence prob doc
Aug 14, 2006 | RCA P52960 52" Rear Projection Television
Picture bows on top and bottom of picture......
Your problem is the convergence IC'S. They have STK ###-### the # are numbers. You can get parts at http://partstore.com. If your not a tech and an experimenter or a handi person Pease be aware of the hi voltage inside these sets. Also be aware your going to need to unsolder and resolder the ICs in and from the printed circuit board. Good Luck
Aug 11, 2006 | RCA P46924 46" Rear Projection Television
RCA G36705 36" TV Logo
44 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
