Question about PC Chips MB PCCHIPS SiS746FX M848A V5.0 462 Motherboard
Cmos clock will not set !
Hi, i installed a PC Chips M848a v5.0 motherboard and the clock will not stay set. i replaced the onboard battery and no luck.
Any help on how to fix this - ? i set the CMOS jumpers per the manual.
thanks in advance  !
  • shahbazyusuf Dec 31, 2008
    thanks !
    there are three jumper pins on the board. the system powers up with the one of the two jumpers shorted. i am assuming that is pin 1 and 2. when i set it to pin2 and pin3 shorted the system will not power up. those are the only two combinations between the three pins. so i have left it in pos 1&2.
This manual for this board has the JP1 clear CMOS jumper shown reversed. I can't remember exactly what it was (maybe mis-labeled?), I think pin 1 is shown on top in the manual, but it is on the bottom on the board. Also, Panel one (power, reset, LED's, etc...) is upside down on the board compared to the manual. Hope this helps.
Posted on Jan 14, 2010
  • jsmith242 Jan 14, 2010
    My bad. I have an older board version. It looks like the manual was corrected with version 5.
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 150 Answers
Is the cmos clear jumper in the wrong position? if it is it will drain the battery and mess up the clock, You may have to flash the eeprom with a newer version BIOS obtainable from the manufacturer, check their website on this to see if it is a known issue ( I have seen this on multiple other manufacturers main boards). If this isnt it it is possible you have a bad clock chip
Posted on Dec 31, 2008
M863g v5.1a sempron cmos clock error solution
Hello here is the mainboards homepage:
http://www.pcchips.com.tw/PCCWebSite/Products/ProductsDetail.aspx?detailid=343&CategoryID=1&DetailName=Manual&MenuID=1&LanID=0
For downloading the manual.
The solulion is, to renew the cmos battery on the mainboard.
The battery is a cr2032 watch type:
Press the lid to release the cmos battery, and insert the new the same way.
Restart the pc, and you probably get this message:F1 or F2 for setup, or press the delete button to enter the bios.
You have to setup the bios, like clock,date,and boot settings for your drive.
Look in the manual, for detailed setup configure.
Good luck
Jan 19, 2012 | PC Chips MB PCCHIPS M863G V5.1C w/XP2400+...
I am running XP SP3 on a PC Chips K7 M848A motherboard (62-0707-001131-00101111-040201-SiS746-M848A). If I try to restart the CMOS memory is lost, I have to clear CMOS jumpers and run setup again. I have...
Check these:
1. Battery connectors. Are they clean and firmly tight on the battery?
2. Reset the cmos. Start up the pc, go at the bios settings and load the defaults. Save and reboot. Make any changes you'd like. Check the results.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
May 15, 2011 | Computers & Internet
What is bios?what bios is cmos
BIOS =Basic Imput Output System. CMOS is the onboard chip that stores the info for the BIOS.
CMOS chips pass information to the BIOS (Basic Input/Output System) when the computer is turned on (called bootup). CMOS stores information such as boot order (the order the computer looks for information, such as A drive first, C drive second, and so on), real-time system clock, calendar settings, hardware passwords, hard drive configuration settings, and the installed memory (RAM). Essentially the CMOS chip stores data for the BIOS so that a computer can boot up properly.
Aug 28, 2010 | Computers & Internet
Update for SiS 2615 Display Adapter to load windows XP pro
The PC Chips MB PCCHIPS SiS746FX M848A V5.0 462 motherboard does not have onboard video, correct? So if you can obtain the make and model of your video card, you can then find the Windows XP drivers online for download. Then you would be able to provide said drivers when the "system asks you to update SiS 2615 Display Adapter driver"
*Another quick fix would be to use a different VGA card, if you have one available?
*Now, I have never been prompted to update display driver before or during a windows installation or update. So that step I would require a little more detail on. I have only been prompted for mass storage drivers (as seen in screenshot).
Apr 19, 2010 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
Can not reboot: i have set cpu's clock i added some more MHzs like: 133Mhz to 160Mhz CPU's clock in cmos and save. when it restart again it not boot, do you know why ?
Try to clear CMOS settings using following steps:
Turn off the system
Disconnect power cables
Open the case and locate the CMOS batery on the motherboard
Take out the battery and wait for about 10 minutes
Reconnect battery
Reconnect power cables and turn on the system.
Mar 07, 2010 | PC Chips M756LMRT+ PII/III/Celeron...
Need drivers for PC Chips MB M848A
The MB you mention does not support SATA it has noSATA connectors
Jun 30, 2009 | ASUS P5LD2-VM Motherboard
I have a Dell dimension 9150 which is 2 1/2 years old. Does it have a battery that I need to be concerned about replacing. I remember that used to be a problem with computers but don't know if that is...
Every PC motherboard has a battery. That battery serves two purposes: to feed the configuration memory (also called CMOS) and to feed the real time clock of the computer (the one that show the date and the time).
An indication it is time to change the motherboard battery is receiving one of the following error messages when you turn on your computer: CMOS CHECKSUM FAILURE, CMOS BATTERY STATE LOW, CMOS SYSTEM OPTIONS NOT SET and CMOS TIME AND DATE NOT SET. Another indicator of a low battery is a clock that, after being set, runs well while the computer is on, but shows the wrong time when the computer is turned on the following day (it is late).
Apr 21, 2009 | Dell (2336V) Motherboard
Just installed new CPU on M848A v2.1 and pc will not POST
becose the processor not support that.replace it by a suitable one.
Jan 16, 2009 | PC Chips M848ALU Motherboard
PC Chips M848A Motherboard
Try clearing the bios/cmos using the jumper on the board, page 10 in you're manual. Than try booting. See if you're keyboard allows you to get into the bios/cmos. I'm guessing you tried another keyboard? You can also buy a PS2 - to -USB Y adapter. This is what one looks like.
http://www.cablestogo.com/product.asp?cat%5fid=104&sku=27225
If you bought an AGP graphics card lately you might have also received a single PS2 to USB adapter free. Like this one.
http://www.cablestogo.com/product.asp?cat%5fid=104&sku=35700
It's not uncommon for the the lights to function & yet the keyboard not function. A single pin within the PS2 on the keyboard could be bent or bad or not seating correctly in you're new board.
Mike
May 31, 2008 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
Jack call-outs and drivers
http://www.pcchips.com.tw/PCCWeb/Products/ProductsDetail.aspx?MenuID=24&LanID=0&DetailID=251
hope that fixes it for you :)
Jan 06, 2008 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
Computers & Internet Logo
212 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
